Discuss
6EM40-2 Richmond 240V electric WH stopped heating
 in
Heating, Ventilation, and Air Conditioning (HVAC)
i have a 6EM-40-2 Richmond 240V electric WH installed 2-3 yrs ago at lake home (an hour drive away) which
Appliance Repair Forum > Appliance Repair Help > Heating, Ventilation, and Air Conditioning (HVAC) » 6EM40-2 Richmond 240V electric WH stopped heating
  #1 (permalink)
Old 07-05-2014, 05:39 AM
Junior Member
gb77 is on a distinguished road
Default 6EM40-2 Richmond 240V electric WH stopped heating
Model Number: 6EM40-2 Richmond   Brand: -other-   Age: 1 - 5 years
i have a 6EM-40-2 Richmond 240V electric WH installed 2-3 yrs ago at lake home (an hour drive away) which worked fine until now. water is not heating, reset switch is not tripped - flush to unit & no idea if i can force it to trip to reset it. house has well water which didnt lose pressure - water flows freely out any hot tap. moving temp setting from 105 to 125 changed nothing. looks like power for the WH & some baseboard heating runs thru a 2nd utility controlled meter outside. the wiring is similar to first pic. 2nd pic is identical to upper thermostat unit.
with power off: (1) checked 4500W elements & both read ~12.5 ohms (didnt disconnect any wires when checking) compared to 12.4 spec for comperable AOSmith elements & (2) high temp cutoff (T2) to power lead (L1) shows 0.3 ohms.
power on @ 30A breaker has 2 stranded copper wires @ 124V each going to WH using a flexible metal electrical conduit for ground (used this ground for all measurements). 124V @ all contacts - thermostats & elements.
not sure which (if not all) should read 240V (or 248 = 124+124). i checked the wiring @ the top of the WH with the incoming wires @ 124V & the green ground wire coming from inside the WH had 0 ohms to the flexible conduit ground. so i'm left with some failure i can't see in the wiring or the thermostats. i can pick up spare parts on the way to the lake. should i get both thermostats & an element or 2 (anything else) to swap out or is there enough info here for anyone to point to a likely culprit? what other tests could i do, and what would they indicate?
thanks for your attention & help
Related Models
Whirlpool 6ER9GTKXKS00 TOP MOUNT REFRIGERATOR
Whirlpool 6ER9GTKXKS01
Whirlpool 6ER9GTKXKS02 REFRIGERATOR
Whirlpool 6ES2FHKXRQ00 REFRIGERATOR
Whirlpool 6ET16ZKXWW00 Refrigerators*
Whirlpool 6ET16ZKXWW01 Refrigerators*
Whirlpool 6ET18DKXAN01 REFRIGERATOR
Whirlpool 6ET18DKXAW00 Refrigerators*
Whirlpool 6ET18DKXAW01 REFRIGERATOR
Whirlpool 6ET18GKXWW00 Refrigerators*
Whirlpool 6ET18GKXWW01 Refrigerators*
Whirlpool 6ET18GKXWW02 Refrigerators*
Whirlpool 6ET18RKXYW01 Refrigerators*
Whirlpool 6ET18ZKXAW00 Refrigerators*
Whirlpool 6ET18ZKXAW01 REFRIGERATOR
Whirlpool 6ET19DKXDN01 REFRIGERATORS
Whirlpool 6ET19DKXDN02 REFRIGERATOR
Whirlpool 6ET19DKXDW01 REFRIGERATORS
Whirlpool 6ET19DKXDW02 REFRIGERATOR
Whirlpool 6ET19DKXFW00 KITCHEN REFRIGERATORS
Whirlpool 6ET19DKXFW01 REFRIGERATOR
Whirlpool 6ET19DKXFW03 REFRIGERATOR
Whirlpool 6ET19PKXHW00 REFRIGERATOR
Whirlpool 6ET20DKXAW00 Refrigerators*
Whirlpool 6ET20RKXYW01 Refrigerators*
Whirlpool 6GC5THGXKS00 SIDE BY SIDE REFRIGERATOR
Whirlpool 6GD22DCXHW01 REFRIGERATOR
Whirlpool 6GD22DCXHW02 REFRIGERATOR
Whirlpool 6GD22DCXHW04 REFRIGERATOR
Whirlpool 6GD22DCXHW06 REFRIGERATOR
Whirlpool 6GD22DCXHW07 REFRIGERATOR
Whirlpool 6GD25DCXHS00 SIDE-BY-SIDE REFRIGERATOR
Whirlpool 6GD25DCXHS01
Whirlpool 6GD25DCXHS02 REFRIGERATOR
Whirlpool 6GD25DCXHS03 REFRIGERATOR
Whirlpool 6GD25DCXHS04 REFRIGERATOR
Whirlpool 6GD25DCXHS05 REFRIGERATOR
Whirlpool 6GD25DCXHS06 REFRIGERATOR
Whirlpool 6GD25DCXHS07 REFRIGERATOR
Whirlpool 6GD25DCXHS08 REFRIGERATOR
Whirlpool 6GD25DCXHS09 REFRIGERATOR
Whirlpool 6GD25DCXHS10 REFRIGERATOR
Whirlpool 6GD25DCXHS11 REFRIGERATOR
Whirlpool 6GD25DCXHS12 REFRIGERATOR
Whirlpool 6GD25DCXHS14 REFRIGERATOR
Whirlpool 6GD25DCXHW00 SIDE-BY-SIDE REFRIGERATOR
Whirlpool 6GD25DCXHW01
Whirlpool 6GD25DCXHW02 REFRIGERATOR
Whirlpool 6GD25DCXHW03 REFRIGERATOR
Whirlpool 6GD25DCXHW04 REFRIGERATOR
Whirlpool 6GD25DCXHW05 REFRIGERATOR
Whirlpool 6GD25DCXHW06 REFRIGERATOR
Whirlpool 6GD25DCXHW08 REFRIGERATOR
Whirlpool 6GD25DCXHW09 REFRIGERATOR
Whirlpool 6GD25DCXHW10 REFRIGERATOR
Whirlpool 6GD25DCXHW11 REFRIGERATOR
Whirlpool 6GD25DCXHW12 REFRIGERATOR
Whirlpool 6GD27DFXFS00 SIDE BY SIDE REFRIGERATOR
Whirlpool 6GD27DFXFS01 REFRIGERATOR
Whirlpool 6GD27DFXFS02 REFRIGERATOR
Whirlpool 6GD27DFXS00 REFRIGERATOR
Whirlpool 6GD2SHGXSS00 REFRIGERATOR
Whirlpool 6GD2SHQXKB00 REFRIGERATOR
Whirlpool 6GD2SHQXKB01
Whirlpool 6GD2SHQXKB02 REFRIGERATOR
Whirlpool 6GD5SHGXSS00 REFRIGERATOR
Whirlpool 6GD5SHGXSS03 REFRIGERATOR
Whirlpool 6GD5SHGXSS04 REFRIGERATOR
Whirlpool 6GD5SHGXSS05 REFRIGERATOR
Whirlpool 6GD5SHGXSS07 REFRIGERATOR
Whirlpool 6GD5SHQXKB00 REFRIGERATOR
Whirlpool 6GD5SHQXKB01 REFRIGERATOR
Whirlpool 6GD5SHQXKB02 REFRIGERATOR
Whirlpool 6GS2SHQXRQ00 REFRIGERATOR
Whirlpool 6GS2SHQXRQ01 REFRIGERATOR
Whirlpool 6GS5SHGXRS00 REFRIGERATOR
Whirlpool 6GS5SHGXRS01 REFRIGERATOR
Whirlpool 6GX0FHDXXY0 REFRIGERATOR
Whirlpool 6GX0FHDXXY1 REFRIGERATOR
Whirlpool 6GX0FHDXXY2 REFRIGERATOR
Frigidaire 6HA601A
Frigidaire 6HA601C
Whirlpool 6KCD1250V0 DISPOSER
Whirlpool 6KCDB250T0 DISPOSER
Whirlpool 6KCDB250T1 DISPOSER
Whirlpool 6KCDC250T0 DISPOSER
Whirlpool 6KCDI250V0 DISPOSER
Whirlpool 6KCDS250V0 DISPOSER
Whirlpool 6KCDS250V1 DISPOSER
Whirlpool 6LA5400XWF0
Whirlpool 6LA5400XWG0
Whirlpool 6LA5400XWM0
Whirlpool 6LA5400XWN0
Whirlpool 6LA5400XWW0
Whirlpool 6LA5400XWW1
Whirlpool 6LA5800XTF0
Whirlpool 6LA5800XTF1
Whirlpool 6LA5800XTG0
Whirlpool 6LA5800XTG1
Whirlpool 6LA5800XTM0
Whirlpool 6LA5800XTM1
Whirlpool 6LA5800XTN0
Whirlpool 6LA5800XTN1
Whirlpool 6LA5800XTW0
Whirlpool 6LA5800XTW1
Whirlpool 6LA5800XTW2
Whirlpool 6LA6300XTF0
Whirlpool 6LA6300XTF1
Whirlpool 6LA6300XTF2
Whirlpool 6LA6300XTG0
Whirlpool 6LA6300XTG1
Whirlpool 6LA6300XTG2
Whirlpool 6LA6300XTM0
Whirlpool 6LA6300XTM1
Whirlpool 6LA6300XTM2
Whirlpool 6LA6300XTN0
Whirlpool 6LA6300XTN1
Whirlpool 6LA6300XTN2
Whirlpool 6LA6300XTW0
Whirlpool 6LA6300XTW1
  #2 (permalink)
Old 07-07-2014, 04:06 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
I cannot say what is blown if anything.
You have to check for 240 volts (supply voltage) at the upper thermostat (black to red)
Using the white Neutral or ground (the conduit) will not tell you if you are getting the correct voltage.
Note that Neutral and ground are the same thing.
Neutral is not part of the heating element circuit.
One side of the elements is probably always connected to one side of the line so you will see it on both sides of the element as long as the thermostat contacts are closed.
Have you tride flipping the breaker off/on slowly a couple times.
Sometimes you can loose half the line without actually tripping the breaker.
FYI. I am do not know how much electrical knowledge you have so below is a blurb on how it works.
Your house wiring is actually 2 supplies (L1 and L2) which share a common Neutral.
Each supply is 120 volts but they are 190 degrees out of phase.
Therefore when one is at positive 120 volts, the other is at negative 120 volts.
If you measure between them you get 240 volts and this is what runs your heating elements.
The Neutral/ground is just connected as a safety. If one side of the line (element) shorts to the water heater then it will blow the circuit breaker instead of putting 120 volts onto the water heater case.
__________________
  #3 (permalink)
Old 07-07-2014, 04:37 AM
Junior Member
Default
thanks for the reply. when i measure across L1 & L2 the voltage goes from 1v to 0 to -1v. from what i've read this happens if they are in the same phase cancelling themselves. i'll have to test from the breaker to see if it's happening there too next time i'm at the lake.
  #4 (permalink)
Old 07-07-2014, 04:49 AM
Senior Expert
APP Volunteer
Default
Yes it looks like you have lost half the line at the water heater.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Heater not getting 240v JCTex Dryer Repair 1 03-19-2011 07:20 PM
Old Electric Oven Suddenly Stopped Heating dms3305 Oven Repair (including Ranges and Cooktops) 1 07-20-2009 02:18 PM
Heating element stopped heating JSP38G0T1BB Gravity Railroad Oven Repair (including Ranges and Cooktops) 1 06-23-2009 02:10 PM
Electric dryer does not have 240V on heating element. fwk009 Dryer Repair 1 04-10-2009 07:57 AM
