Discuss
C/A compressor shorted out. Is freon bad?
 in
Heating, Ventilation, and Air Conditioning (HVAC)
Hello, My Goodman central compressor wire leads corroded last year so it shorted out and terminals are melted beyond repair.
Appliance Repair Forum > Appliance Repair Help > Heating, Ventilation, and Air Conditioning (HVAC) » C/A compressor shorted out. Is freon bad?
  #1 (permalink)
Old 06-19-2014, 06:52 PM
Junior Member
nickstoyz is on a distinguished road
Default C/A compressor shorted out. Is freon bad?
Model Number: H23B223ABCA   Brand: -brand-   Age: More than 10 years
Hello, My Goodman central compressor wire leads corroded last year so it shorted out and terminals are melted beyond repair. I'm trying to get somebody in to check it out but how do you know if the freon is bad? and secondly if the freon is good what is the exact replacement compressor number. As of now i have H23B223ABCA. It ran fine until this happened of course. Thanks
Related Models
Hoover H2510
Hoover H2800--- HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover H2800050 HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover H28010RM UPRT-HD,LC,MID,GNS,NS,GMN,PR AS,COM,ID
Hoover H2850 HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover H2850050 HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover H3000--- HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover H3000001 HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover H3000006 HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover H3000011 HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover H3000020 HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover H30010RM HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover H3010--- HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover H3010020 HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover H3012020 HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Maytag H302RA HOOD
Maytag H302RB HOOD
Maytag H302RQ HOOD
Maytag H302RS HOOD
Maytag H302RW HOOD
Hoover H3030--- HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover H3030001 HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover H3030006 HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Maytag H303RA HOOD
Maytag H303RB HOOD
Maytag H303RQ HOOD
Maytag H303RS HOOD
Maytag H303RW HOOD
Maytag H304RA HOOD
Maytag H304RB HOOD
Maytag H304RQ HOOD
Maytag H304RS HOOD
Maytag H304RW HOOD
Hoover H3050 UPRT-HD,LC,MID,GNS,NS,GMN,PR AS,COM,ID
Hoover H3050010 UPRT-HD,LC,MID,GNS,NS,GMN,PR AS,COM,ID
Hoover H3060--- HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover H3060020 HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Thermador H30HQS RANGE HOODS
Thermador H30HQW RANGE HOOD
Hardwick H31000PAAD RANGE- F/S STD GAS
Hardwick H31000PAWD RANGE- F/S STD GAS
Hardwick H3100PPA RANGE- F/S STD GAS
Hardwick H3100PPW RANGE- F/S STD GAS
Hardwick H31103SAA RANGE- F/S STD GAS
Hardwick H31103SAW RANGE- F/S STD GAS
Hardwick H3110PPA RANGE- F/S STD GAS
Hardwick H3110PPW RANGE- F/S STD GAS
Hardwick H3110PRA RANGE- F/S STD GAS
Hardwick H3110PRW RANGE- F/S STD GAS
Hardwick H3120SPA RANGE- F/S STD GAS
Hardwick H3120SPW RANGE- F/S STD GAS
Hardwick H3120SRA RANGE- F/S STD GAS
Hardwick H3120SRW RANGE- F/S STD GAS
Hardwick H3131WRA RANGE- F/S STD GAS
Hardwick H3131WRW RANGE- F/S STD GAS
Hardwick H3131WTA RANGE- F/S STD GAS
Hardwick H3131WTW RANGE- F/S STD GAS
Hardwick H3131WUA RANGE- F/S STD GAS
Hardwick H3131WUW RANGE- F/S STD GAS
Hardwick H3131XRA RANGE- F/S STD GAS
Hardwick H3131XRW RANGE- F/S STD GAS
Hardwick H3131XTA RANGE- F/S STD GAS
Hardwick H3131XTW RANGE- F/S STD GAS
Hardwick H3131XUA RANGE- F/S STD GAS
Hardwick H3131XUW RANGE- F/S STD GAS
Hardwick H3137WRA-L RANGE- F/S STD GAS
Hardwick H3137WRV-L RANGE- F/S STD GAS
Hardwick H3137WUA-L RANGE- F/S STD GAS
Hardwick H3137WUV-L RANGE- F/S STD GAS
Hardwick H3177XRA RANGE- F/S STD GAS
Hardwick H3177XRW RANGE- F/S STD GAS
Hardwick H3177XUA RANGE- F/S STD GAS
Hardwick H3177XUW RANGE- F/S STD GAS
Hardwick H3221WRV RANGE-F/S CONT CLEAN GAS
Hardwick H3221WTV RANGE-F/S CONT CLEAN GAS
Hardwick H32315WAM RANGE-F/S CONT CLEAN GAS
Hardwick H32315WAV RANGE-F/S CONT CLEAN GAS
Hardwick H3231XRA RANGE-F/S CONT CLEAN GAS
Hardwick H3231XRW RANGE-F/S CONT CLEAN GAS
Hardwick H3231XTA RANGE-F/S CONT CLEAN GAS
Hardwick H3231XTW RANGE-F/S CONT CLEAN GAS
Hardwick H3231XUA RANGE-F/S CONT CLEAN GAS
Hardwick H3231XUW RANGE-F/S CONT CLEAN GAS
Jenn-Air H325 Hood
Jenn-Air H325A MISC / ACCESSORY
Jenn-Air H325B MISC / ACCESSORY
Jenn-Air H326 HOOD
Jenn-Air H326A MISC / ACCESSORY
Jenn-Air H326B MISC / ACCESSORY
Hardwick H3277VRA RANGE-F/S CONT CLEAN GAS
Hardwick H3277VRV RANGE-F/S CONT CLEAN GAS
Hardwick H3277VUA RANGE-F/S CONT CLEAN GAS
Hardwick H3277VUV RANGE-F/S CONT CLEAN GAS
Hardwick H3277VUW RANGE-F/S CONT CLEAN GAS
Hardwick H3277XRA RANGE-F/S CONT CLEAN GAS
Hardwick H3277XRW RANGE-F/S CONT CLEAN GAS
Hardwick H3277XUA RANGE-F/S CONT CLEAN GAS
Hardwick H3277XUW RANGE-F/S CONT CLEAN GAS
Hardwick H3432SRA RANGE- S/C F/S GAS
Hardwick H3432SRW RANGE- S/C F/S GAS
Hardwick H3478VRA RANGE- S/C F/S GAS
Hardwick H3478VRV RANGE- S/C F/S GAS
Hardwick H3478VVA RANGE- S/C F/S GAS
Hardwick H3478VVV RANGE- S/C F/S GAS
Hardwick H3478XRA RANGE- S/C F/S GAS
Hardwick H3478XRW RANGE- S/C F/S GAS
Hardwick H3478XVA RANGE- S/C F/S GAS
Hardwick H3478XVB RANGE- S/C F/S GAS
Hardwick H3478XVW RANGE- S/C F/S GAS
Hardwick H3500PPA RANGE- F/S STD ELE
Hardwick H3500PPW RANGE- F/S STD ELE
Hardwick H3510PPA RANGE- F/S STD ELE
Hardwick H3510PPW RANGE- F/S STD ELE
Hardwick H3510PRA RANGE- F/S STD ELE
Hardwick H3510PRW RANGE- F/S STD ELE
Hardwick H3520SPA RANGE- F/S STD ELE
Hardwick H3520SPN RANGE- F/S STD ELE
Hardwick H3520SPW RANGE- F/S STD ELE
Hardwick H3520SRA RANGE- F/S STD ELE
Hardwick H3520SRW RANGE- F/S STD ELE
  #2 (permalink)
Old 07-21-2014, 07:36 PM
Junior Member
hvac54 is on a distinguished road
Default
if your wires burned off the terminals, and the compressor is still intact, no holes blown in the compressor, then your freon should be ok. Problem is, if there is not enough stud to attach the wiring to, then you are going to lose
all that freon when the compressor or condenser is replaced. Just because the wires have burned off, and not that the terminals burned off the compressor, means all is lost, it all depends on how much you want to try to get this compressor back up and running. Even if all of the flat part of the terminal is gone there are still some junk yard tricks you can do, which I have done and see them run for another year or two that way. Not real pretty or pro looking, but at least its cooling your house.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Fridge and freezer not cooling. Fans and compressor working, possible freon leak? Excessumcarcer@yahoo.com Refrigerator & Freezer Repair 1 08-12-2012 04:31 PM
Low on Freon renatog Refrigerator & Freezer Repair 1 06-24-2011 03:36 AM
wrong freon mamapiglet1960 Heating, Ventilation, and Air Conditioning (HVAC) 1 06-06-2011 08:04 AM
Compressor current vs freon charge nlt99 Refrigerator & Freezer Repair 2 08-17-2008 11:31 PM
how do you know if you have a compressor problem or if you just need more freon? shane Refrigerator & Freezer Repair 1 09-10-2007 01:10 PM
