Discuss
Issue With Carrier 58 MVP 100 14120
 in
Heating, Ventilation, and Air Conditioning (HVAC)
Hello. In a rental property I own (used to be our own home) we have a Carrier furnace installed in
Appliance Repair Forum > Appliance Repair Help > Heating, Ventilation, and Air Conditioning (HVAC) » Issue With Carrier 58 MVP 100 14120
  #1 (permalink)
Old 04-09-2014, 01:24 PM
Junior Member
whitedavidp is on a distinguished road
Default Issue With Carrier 58 MVP 100 14120
Model Number: 58 MVP 100 14120   Brand: -other-   Age: More than 10 years
Hello. In a rental property I own (used to be our own home) we have a Carrier furnace installed in 1999 which has been really pretty great. A week ago we had a problem where it simply would not start. It would try to do so and then click off in a cycle over and over again.
A technician came and told me that he found 3 different fault codes. If I got it right they pertained to: low fire pressure switch stuck closed, inducer outside valid speed range, and pressure switch calibration fault. He was, however, able to simply cut power to the furnace and when re-applied all was well again. He said this was common place. Since then, our tenant says the furnace has been operating just fine - better than before. Seems odd but there are circuit cards in there and perhaps, like most computers, they require a reboot now and then.
The other thing the technician said was that this furnace is basically at end-of-life which surprised the heck out of me. He said that repairing this would be very expensive and that replacing is likely the thing to do at this point. I have no way to confirm this one way or the other. It just seems a pretty short lifespan for a unit that was so expensive to begin with and that actually sees use less than 1/2 of the year. Maybe these are just not made like they used to be?
I was called by the service company and they are saying the the inducer assembly and the pressure switch assembly would cost over $1900 installed (1-1.5 hours labor). I have no idea what these entail or should cost. But I do know that in 1999 the cost to install the furnace (along with gas meter/pipe, direct venting, etc) was about $5000. I have to guess that it will be more than that now.
So can anyone speak to these issues? Are the parts prices over-stated? Are they even actually needed since the furnace seems fine since its "reboot"? Should the thing be tossed?
Thanks for your viewpoints.
Related Models
Kenmore 58051300 DEHUMIDIFIER
Kenmore 58051300000 DEHUMIDIFIER
Kenmore 58051450 DEHUMIDIFIER
Kenmore 58051450100 DEHUMIDIFIER
Kenmore 58051650000 DEHUMIDIFIER
Kenmore 58052300200 DEHUMIDIFIER
Kenmore 58052450000 DEHUMIDIFIER
Kenmore 58052450200 DEHUMIDIFIER
Kenmore 58052650 DEHUMIDIFIER
Kenmore 58052650000 DEHUMIDIFIER
Kenmore 58052650100 DEHUMIDIFIER
Kenmore 58053301300 DEHUMIDIFIER
Kenmore 58053509300 DEHUMIDIFIER
Kenmore 58053650200 DEHUMIDIFIER
Kenmore 58053701300 DEHUMIDIER
Kenmore 58054351400 DEHUMIDIFIER
Kenmore 58054351500 DEHUMIDIFIER
Kenmore 58054351700 DEHUMIDIFIER
Kenmore 58054351800 DEHUMIDIFIER
Kenmore 58054351900 DEHUMIDIFIER
Kenmore 58054501400 DEHUMIDIFIER
Kenmore 58054501500 DEHUMIDIFIER
Kenmore 58054501700 DEHUMIDIFIER
Kenmore 58054501800 DEHUMIDIFIER
Kenmore 58054501801 DEHUMIDIFIER
Kenmore 58054701400 DEHUMIDIFIER
Kenmore 58054701500 DEHUMIDIFIER
Kenmore 58054701700 DEHUMIDIFIER
Kenmore 58054701800 DEHUMIDIFIER
Kenmore 58059600890 DEHUMIDIFIER
Kenmore 58066291690 MICROWAVE
Kenmore 58070074000 AIR CONDITIONER
Kenmore 58070122000 AIR CONDITIONER
Kenmore 58070188000 ROOM AIR CONDITIONER
Kenmore 58071056100 AIR CONDITIONER
Kenmore 58071073100 AIR CONDITIONER
Kenmore 58071082100 AIR CONDITIONER
Kenmore 58071121100 AIR CONDITIONER
Kenmore 58071122100 AIR CONDITIONER
Kenmore 58071184100 AIR CONDITIONER
Kenmore 58072053100 AIR CONDITIONER
Kenmore 58072056200 AIR CONDITIONER
Kenmore 58072059200 AIR CONDITIONER
Kenmore 58072066200 AIR CONDITIONER
Kenmore 58072077200 AIR CONDITIONER
Kenmore 58072082200 AIR CONDITIONER
Kenmore 58072083200 AIR CONDITIONER
Kenmore 58072087200 ROOM A/C
Kenmore 58072089200 ROOM A/C
Kenmore 58072093200 AIR CONDITIONER
Kenmore 58072104200 AIR CONDITIONER
Kenmore 58072124200 AIR CONDITIONER
Kenmore 58072124300 AIR CONDITIONER
Kenmore 58072126200 AIR CONDITIONER
Kenmore 58072127200 AIR CONDITIONER
Kenmore 58072128200 AIR CONDITIONER
Kenmore 58072144200 AIR CONDITIONER
Kenmore 58072184200 AIR CONDITIONER
Kenmore 58072187200 AIR CONDITIONER
Kenmore 58072187300 AIR CONDITIONER
Kenmore 58072189200 AIR CONDITIONER
Kenmore 58073053200 AIR CONDITIONER
Kenmore 58073069300 AIR CONDITIONER
Kenmore 58073069301 AIR CONDITIONER
Kenmore 58073082300 AIR CONDITIONER
Kenmore 58073083300 AIR CONDITIONER
Kenmore 58073089300 AIR CONDITIONER
Kenmore 58073093300 AIR CONDITIONER
Kenmore 58073103200 AIR CONDITIONER
Kenmore 58073104300 AIR CONDITIONER
Kenmore 58073123200 AIR CONDITIONER
Kenmore 58073144300 AIR CONDITIONER
Kenmore 58073184300 AIR CONDITIONER
Kenmore 58073189300 AIR CONDITIONER
Kenmore 58074053300 AIR CONDITIONER
Kenmore 58074054400 AIR CONDITIONER
Kenmore 58074055400 AIR CONDITIONER
Kenmore 58074066400 ROOM A/C
Kenmore 58074082400 AIR CONDITIONER
Kenmore 58074083400 AIR CONDITIONER
Kenmore 58074085400 AIR CONDITIONER
Kenmore 58074093400 AIR CONDITIONER
Kenmore 58074100400 ROOM A/C
Kenmore 58074103300 ROOM A/C
Kenmore 58074107400 AIR CONDITIONER
Kenmore 58074109400 ROOM A/C
Kenmore 58074121300 AIR CONDITIONER
Kenmore 58074122400 AIR CONDITIONER
Kenmore 58074123300 AIR CONDITIONER
Kenmore 58074124400 AIR CONDITIONER
Kenmore 58074125400 AIR CONDITIONER
Kenmore 58074126400 ROOM A/C
Kenmore 58074130400 AIR CONDITIONER
Kenmore 58074132400 AIR CONDITIONER
Kenmore 58074156400 AIR CONDITIONER
Kenmore 58074184400 AIR CONDITIONER
Kenmore 58074229400 AIR CONDITIONER
Kenmore 58074259400 AIR CONDITIONER
Kenmore 58074300400 AIR CONDITIONER
Kenmore 58075050500 ROOM A/C
Kenmore 58075051200 AIR CONDITIONER
Kenmore 58075051500 ROOM AIR CONDITIONER
Kenmore 58075051900 AIR CONDITIONER
Kenmore 58075052500 ROOM A/C
Kenmore 58075062500 AIR CONDITIONER
Kenmore 58075062501 A/C
Kenmore 58075063500 ROOM A/C
Kenmore 58075063700 A/C
Kenmore 58075080500 ROOM A/C
Kenmore 58075081500 ROOM A/C
Kenmore 58075085500 ROOM A/C
Kenmore 58075085700 A/C
Kenmore 58075100500 ROOM A/C
Kenmore 58075101500 ROOM A/C
Kenmore 58075119500 ROOM A/C
Kenmore 58075119700 A/C
Kenmore 58075121500 ROOM A/C
Kenmore 58075121501 A/C
Kenmore 58075123500 ROOM A/C
Kenmore 58075123700 A/C
  #2 (permalink)
Old 04-10-2014, 04:29 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
I would take Mr. Bates comments with a grain of salt.
I looked at his other posts and most of them just recommend calling a repair company.
Sort of defeats the purpose of this forum.
I am not a furnace pro so also take my comments with a grain of salt.
You may want to call another repair company or two to get quotes on the suggested repair. I am not even sure if you need it.
Cannot say as I do not know exactly what part they are replacing.
On another site I did find a pressure switch is about $100.00 and a draft inducer motor (not sure if this is what they are referring to or if it is part of an assembly) is about 325.00. But the prices are just for the parts and I do not know how much labor is required to replace them.
I would not toss it.
If the parts are actually bad then I would think that the error would re-occur.
Anything that uses a microprocessor may hang up once in a while and need re-booting (reset).
I can only relate my experience with a repair company. About 5 years ago I had a company in to professionally clean/check my furnace. They said the furnace needed replacing. Well it's been 5 years and the unit is still running just fine.
I do not want to accuse the company you used of anything shady as I do not know them and do not have the expertise but you have to be careful when taking advise that puts dollars into their pockets.
With luck a real HVAC tech will jump in and give you some guidance.
__________________
  #3 (permalink)
Old 04-10-2014, 10:23 AM
Junior Member
Default
Thanks. Mr. Bates's comments basically parrot what I heard from the tech and both may be right here. That is what I am trying to confirm. But to toss this now really irks me. Then again, I still drive the 1983 Volvo I bought new. So I tend to want to use everything until it really is dead.
I also looked around on the web for parts and found some, like you did, that appeared to be correct at prices lower than what I would have expected from the quote I received. Since the labor was supposed to be 1-1.5 hours (and they seem to charge around $100/hour) that leaves alot of room for part price inflation to reach $1900+. The draft inducer part they want to install is an "assembly" and they are not clear that it was the motor or what inside the assembly.
My experience is that most repair outfits do not want to tinker with repairing stuff, they want to replace stuff. I have a GE Profile fridge that had a problem and the repair tech told me that he could replace the brain card for $200 or so. But he also told me the issue was well known and if I had a soldering iron he would show me the joint that fails every time and I could fix it in about 5 minutes with $0.02 worth of solder. He said that his company policy prevented him from doing this. So I did it, gave the guy $20 for beer, and it has been fine ever since.
It is experiences like this that make me question the "expert" opinions when it comes to just replacing entire, expensive assemblies. That said, the labor involved to replace just a component inside an assembly may outweigh the cost of just doing the whole shebang. As a DIY, I don't really know.
Also, when I look at the way the furnace was warrantied, I can see that the longest part of the warranty is on the burner. So one would think (perhaps wrongly) that this is the part most likely to fail. And no one has said anything about the burner. So I assume it is ok. Of course, I also don't know if the tech even looked at the burner during his hour of "diagnosing" the problem.
Thanks!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Carrier Furnace noise radar12158 Heating, Ventilation, and Air Conditioning (HVAC) 0 01-13-2014 05:46 PM
Carrier Furnace Doesn't Work Dr_Zoidberg57 Heating, Ventilation, and Air Conditioning (HVAC) 1 11-18-2013 01:55 PM
Carrier Model 58ZAV ninohero Heating, Ventilation, and Air Conditioning (HVAC) 1 05-17-2010 06:36 PM
Carrier AC Intermittent Cooling loowens Heating, Ventilation, and Air Conditioning (HVAC) 4 08-24-2009 03:59 AM
Carrier Puron Condensor ray1216 Heating, Ventilation, and Air Conditioning (HVAC) 2 06-14-2009 04:40 PM
