| » Timer set is not working |
Model Number: AWM-12BC Brand: White-Westinghouse Age: Less than 1 year
Hi!
I bought the air conditing AWM-12BC and i have a doubt regardin the timer set. I red the manual and there are two options: 1) Set the timer in the "standard way" Option On/Off 2) Set the timer in an inverted way, Option Off/On if you want the machine stop at an hour, then switch on again. I would need you to clarify this point. The option 1 (on/off) is working perfectly. The second option is working only for the first step (Off). The machine stop, but then the start again fails. My question is: is it an issue that needed to be repaired or the model i hove boght don't support the option 2? Thanks in advance for your support. Regards, Roberto Valenti Torregrossa Related Models |
| Display Modes | |
| Timer not working and heat not working | JP2 | Dryer Repair | 2 | 07-09-2009 04:19 PM |
| Timer not working? | Kennick | Dishwasher Repair | 0 | 04-04-2009 05:27 PM |
| Timer Not Working | antcrociata | Washer Repair | 1 | 12-10-2008 10:52 AM |
| Timer Not Working | TVGALHH | Microwave Repair | 1 | 09-23-2008 01:37 PM |
| timer in more dry setting not working | rdbsupply | Dryer Repair | 0 | 06-19-2008 12:12 PM |
