Discuss
Replacement of A/C coil
 in
Heating, Ventilation, and Air Conditioning (HVAC)
Our Bryant heat pump is 10 yrs old and the coil inside the air handler has de veloped a leak.
Appliance Repair Forum > Appliance Repair Help > Heating, Ventilation, and Air Conditioning (HVAC) » Replacement of A/C coil
  #1 (permalink)
Old 03-26-2014, 02:20 PM
Junior Member
FourMaxK1 is on a distinguished road
Default Replacement of A/C coil
Brand: -brand-   Age: 5 - 10 years
Our Bryant heat pump is 10 yrs old and the coil inside the air handler has de veloped a leak. We put freon in it 8 mos ago & it needs it again - $ 280 each time for the service.
The A/C company has quoted us on replacing the entire unit inside and out with a new unit with higher SEER. I kinda don't want to spend that much.
Three options:
Replace entire unit, 10 yr warranty. $ 6000 to $ 8000 depending on SEER
Replace air handler inside, including coil, 10 yr warr. $ 2500 approx
Replace coil only, 1 yr warranty, $ 1500 to $ 1700.
Any opinions?
  #2 (permalink)
Old 03-26-2014, 03:51 PM
Junior Member
Default update on my thread
It looks like replacing the air handler is the way to go. If you replace the coil only it would be a copper coil that fits with the existing air handler & would not be compatible with future replacement of the outside condensor. The new coils are made from aluminum and are designed to withstand the higher pressures of the new refrigerant.
Therefore, if I replace the air handler/coil now, it will be compatible with up to a 14 SEER condensor that I may have to replace in the next few years.
All the installer will have to do is to put a valve on the new air handler/coil to bring the pressure down from 300 psi to 200 psi so that my old condensor unit can handle it & later remove the valve when I replace the outside unit with new.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
gas coil replacement buletbob Dryer Repair 0 06-11-2011 12:58 PM
GE Oven Igniter coil replacement jeffcorona Oven Repair (including Ranges and Cooktops) 1 01-07-2011 09:48 AM
Broiler Coil Replacement theholly44 Oven Repair (including Ranges and Cooktops) 0 08-23-2010 12:36 PM
Heater Coil replacement alvarezphotography Dryer Repair 0 02-16-2010 01:57 PM
Gas coil replacement Speed Queen docfiddle Dryer Repair 5 09-22-2009 10:17 AM
