Discuss
Trane XE78 won't ignite
 in
Heating, Ventilation, and Air Conditioning (HVAC)
My Trane XE78 is going out. I need to identify what part if any I need to replace to get
Appliance Repair Forum > Appliance Repair Help > Heating, Ventilation, and Air Conditioning (HVAC) » Trane XE78 won't ignite
  #1 (permalink)
Old 03-12-2014, 10:13 PM
Junior Member
cyberjones98 is on a distinguished road
Default Trane XE78 won't ignite
Brand: -brand-   Age: More than 10 years
My Trane XE78 is going out. I need to identify what part if any I need to replace to get the furnace working.
One morning I woke up to a cold house, it was below freezing outside and a little over 40 degrees in the house. I checked the furnace and found that it didn't have any flame, but was still blowing cold air into the house. I was able to get it to light by cleaning it out with the shop vac and changing the filters. It worked for almost a month then stopped.
I found if I use the hair dryer inside the furnace, it would light. The furnace would work for a few days, then I would have to get the hair dryer out again. I did this for about a month. But today I was not able to get it to light even after using the hair dryer.
I tried to clean it up again using the shop vac and blew out any dust, it still didn't work.
This is what it does.
I press the safety switch
I hear a few clicks and the intake blower starts
The control board light begins to flash asking for heat
The glow plug turns bright yellow
The furnace waits till the glow plug is at its peak
You hear another click and expect the gas to ignite, nothing
The blower keeps going, and the light keeps blinking like it did earlier, but no flame
I turned the power off at the fuse box, waited about 10 secs. and turned it back on, it still didn't light. Any suggestions on what I should try to get this working again?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
trane furnace XL-80 arlo swalve Heating, Ventilation, and Air Conditioning (HVAC) 0 04-30-2013 06:24 PM
Trane XE80 No AC kimba725 Heating, Ventilation, and Air Conditioning (HVAC) 0 04-16-2013 11:49 AM
Oven won't ignite; front burners won't ignite SweetMary Oven Repair (including Ranges and Cooktops) 0 07-25-2011 11:32 AM
Trane xe 80 no heat robstuff Heating, Ventilation, and Air Conditioning (HVAC) 4 11-21-2010 08:16 AM
Is my Trane Gas/Electric overheating? gfergie Heating, Ventilation, and Air Conditioning (HVAC) 1 12-22-2008 10:12 AM
