Discuss
Auto works but Thermostat fan "on" does not
 in
Heating, Ventilation, and Air Conditioning (HVAC)
i have a trane xe80 furnace about 13 years old. air conditioner installed about 8 years ago. programmable thermostat -
Appliance Repair Forum > Appliance Repair Help > Heating, Ventilation, and Air Conditioning (HVAC) » Auto works but Thermostat fan "on" does not
  #1 (permalink)
Old 03-10-2014, 01:43 PM
Junior Member
officework13 is on a distinguished road
Default Auto works but Thermostat fan "on" does not
Model Number: Trane XE80   Brand: -other-   Age: More than 10 years
programmable thermostat - also 13 years old
Everything works good
EXCEPT.
when i turn the thermostat to 'ON' from auto nothing happens. (i.e. the fan does not run)
i want to leave the fan on all the time to circulate the air.
at one time the fan "on" worked, and it also worked after i had the AC installed as well.
perhaps the thermostat is shot.
any pointers on testing this. i have some electrical skills and understand most principles and know how to use a volt meter and that it is not a good idea to stick a knife into an electrical socket.
Related Models
Amana TRG16J REF - TOP MOUNT
Amana TRG18J REF - TOP MOUNT
Amana TRG18K REF - TOP MOUNT
Amana TRG18M REF - TOP MOUNT
Amana TRG18N REF - TOP MOUNT
Amana TRG18QB2L REF - TOP MOUNT
Amana TRG18QB2W REF - TOP MOUNT
Amana TRG18QB3G REF - TOP MOUNT
Amana TRG18QB3L REF - TOP MOUNT
Amana TRG18QB3W REF - TOP MOUNT
Amana TRG18QBG REF - TOP MOUNT
Amana TRG18QBL REF - TOP MOUNT
Amana TRG18QBW REF - TOP MOUNT
Amana TRG18SPH REF - TOP MOUNT
Amana TRG20J REF - TOP MOUNT
Amana TRG20M REF - TOP MOUNT
Amana TRG20SPH REF - TOP MOUNT
Amana TRG22J REF - TOP MOUNT
Amana TRGI18J REF - TOP MOUNT
Amana TRGI18QBL REF - TOP MOUNT
Amana TRGI18QBW REF - TOP MOUNT
Amana TRGI20J REF - TOP MOUNT
Amana TRGI22J REF - TOP MOUNT
Amana TRI-17D MISC / ACCESSORY
Amana TRI-17D-1 MISC / ACCESSORY
Amana TRI-17E MISC / ACCESSORY
Amana TRI-17LD MISC / ACCESSORY
Amana TRI-17LD-1 MISC / ACCESSORY
Amana TRI-17LE MISC / ACCESSORY
Amana TRI16K REF - TOP MOUNT
Amana TRI17E MISC / ACCESSORY
Amana TRI17LE MISC / ACCESSORY
Amana TRI18D REF - TOP MOUNT
Amana TRI18D MISC / ACCESSORY
Amana TRI18D-A REF - TOP MOUNT
Amana TRI18D-C REF - TOP MOUNT
Amana TRI18D-G REF - TOP MOUNT
Amana TRI18D-L REF - TOP MOUNT
Amana TRI18E MISC / ACCESSORY
Amana TRI18E-A MISC / ACCESSORY
Amana TRI18E-C MISC / ACCESSORY
Amana TRI18E-G MISC / ACCESSORY
Amana TRI18E-L MISC / ACCESSORY
Amana TRI18J REF - TOP MOUNT
Amana TRI18K REF - TOP MOUNT
Amana TRI18TE REF - TOP MOUNT
Amana TRI18TL REF - TOP MOUNT
Amana TRI18TW REF - TOP MOUNT
Amana TRI18V1E REF - TOP MOUNT
Amana TRI18V1L REF - TOP MOUNT
Amana TRI18V1W REF - TOP MOUNT
Amana TRI20K REF - TOP MOUNT
Amana TRI21S4E REF - TOP MOUNT
Amana TRI21S4L REF - TOP MOUNT
Amana TRI21S4W REF - TOP MOUNT
Amana TRI21VE REF - TOP MOUNT
Amana TRI21VL REF - TOP MOUNT
Amana TRI21VW REF - TOP MOUNT
Amana TRI22S4 REF - TOP MOUNT
Amana TRI22S4E REF - TOP MOUNT
Amana TRI22S4L REF - TOP MOUNT
Amana TRI22S4W REF - TOP MOUNT
Amana TRI22SRL REF - TOP MOUNT
Amana TRI25S5E REF - TOP MOUNT
Amana TRI25S5L REF - TOP MOUNT
Amana TRI25S5W REF - TOP MOUNT
Amana TRI25VE REF - TOP MOUNT
Amana TRI25VL REF - TOP MOUNT
Amana TRI25VW REF - TOP MOUNT
Admiral TRIS225BAW REF - SXS/I&W
Admiral TRIS225FAW REF - SXS/I&W
Admiral TRIS245BBW REF - SXS/I&W
Admiral TRIS245FBW REF - SXS/I&W
Frigidaire TRS20WRHD0 Tap(v1) / Refrigerator
Frigidaire TRS20WRHD1 Tap(v1) / Side By Side Refrigerator
Frigidaire TRS20WRHD2 Tap(v1) / Side By Side Refrigerator
Frigidaire TRS20WRHD3 Tap(v2) / Side By Side Refrigerator
Frigidaire TRS20WRHD4 Tap(v1) / Refrigerator
Frigidaire TRS20WRHD5 Tap(v1) / Refrigerator
Frigidaire TRS20WRHW0 Tap(v2) / Refrigerator
Frigidaire TRS20WRHW1 Tap(v2) / Side By Side Refrigerator
Frigidaire TRS20WRHW2 Tap(v3) / Side By Side Refrigerator
  #2 (permalink)
Old 03-11-2014, 02:59 PM
Junior Member
Default UPdated details - Green wire not attached
see attached picture
OK, so i looked at the wiring and think i know what is likely wrong.
4 wires go to the thermostat.
Red to R
Green to G
Purple to Y
Black to W
with thermostat on auto i have 24 Vac from red on thermostat to each of the 3 wires, turn thermostat from Auto to on and voltages to green drop to near zero.
checked out furnace wiring.
there are 3 sets of wires as follows
Wire 1 - to thermostat
Red to R, Black to W, Purple to Y, Green - taped off (not used).
Wire 2 - to air conditioner
Black to Y, Red to C
Wire 3 - to exhaust fan
Black to R, Red to G
So how this is set up from my understanding is that the fan kicks in when we turn on the exhaust fan.
However, i want to be able to turn on the blower fan without turning on the exhaust fan. in winter i am loosing heat by doing this, and in summer i am loosing cool air.
my question, can i hook up the green wire (from the thermostat) to the circuit board (G) so i can use the thermostat to run the blower without turning on the exhaust fan.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore "Auto Moisture Sensing"Sensor snags clothes dryersheet Dryer Repair 2 04-06-2013 08:29 PM
Crosley Dryer--will only turn on in "cool down" on auto setting lemichie Dryer Repair 1 05-10-2012 12:25 PM
How hard and what part for fixing "auto dry"cycle pickeychickey Refrigerator & Freezer Repair 0 09-21-2009 09:46 AM
Kenmore Dryer "Auto" Cycle trouble davidkochct Dryer Repair 1 07-09-2009 08:23 PM
Works on "rinse only" but stops on "wash". Bill E Dishwasher Repair 5 05-27-2009 04:00 AM
