Discuss
1978 GE Funace burners wont light
 in
Heating, Ventilation, and Air Conditioning (HVAC)
The pilot lights, but the burners never fire up. The pilot stays lit. The blower never comes on but will
Appliance Repair Forum > Appliance Repair Help > Heating, Ventilation, and Air Conditioning (HVAC) » 1978 GE Funace burners wont light
  #1 (permalink)
Old 02-20-2014, 08:00 AM
Junior Member
rustbelt is on a distinguished road
Default 1978 GE Funace burners wont light
Model Number: BLU080F94ZB1   Brand: GE   Age: More than 10 years
The pilot lights, but the burners never fire up. The pilot stays lit. The blower never comes on but will run if manually set to on.
It is GE Ambassador II gas furnace.
Batteries in the tstat are good and it seems to be working fine. Breakers are on.
The pilot is nice and blue.
There is a sensor rod next to the pilot that the pilot heats.
The sensor goes to a relay that is wired to the gas valve.
The relay is marked White Rogers3049-111, WG 35X170.
I suspect this is the problem but I want to be sure.
I have a clamp meter and could not detect 24v on any of the wires going from the relay to the valve.
But "not" seeing something doesn't seem as certain.
Is there anything else I can do to verify this is the problem?
Are there other components that could cause these symptoms?
I did brush and vacuum the burners.
I also tried lightly cleaning the sensor rod with a wire brush.
Related Models
Amana BM20TBL REF - BOTTOM MOUNTS
Amana BM20TBW REF - BOTTOM MOUNTS
Norge BNEA3G1 RANGE- F/S STD ELE
Norge BNEA3H2X RANGE- F/S STD ELE
Norge BNEA3H9TZ RANGE- S/C F/S ELE
Norge BNEW3G1 RANGE- F/S STD ELE
Norge BNEW3H2WEV RANGE- F/S STD ELE
Norge BNEW3H2X RANGE- F/S STD ELE
Norge BNEW3H8TVEV RANGE- S/C F/S ELE
Norge BNEW3H9TZ RANGE- S/C F/S ELE
Whirlpool BNQ11CVANA0 AUTOMATIC WASHER
Maytag BNS22F5 REF - SXS
Maytag BNS22F5A REF - SXS
Maytag BNS22F5H REF - SXS
Maytag BNT15B4V REF - TOP MOUNT
Maytag BNT15B4VA REF - TOP MOUNT
Maytag BNT15B4VH REF - TOP MOUNT
Maytag BNT15H4 REF - TOP MOUNT
Maytag BNT15H4A REF - TOP MOUNT
Maytag BNT15H4H REF - TOP MOUNT
Maytag BNT17B4V REF - TOP MOUNT
Maytag BNT17B4VA REF - TOP MOUNT
Maytag BNT17B4VH REF - TOP MOUNT
Maytag BNT17H4 REF - TOP MOUNT
Maytag BNT17H4A REF - TOP MOUNT
Maytag BNT17H4H REF - TOP MOUNT
Maytag BNT21LE REF - TOP MOUNT
Maytag BNT21LEA REF - TOP MOUNT
Maytag BNT21LEH REF - TOP MOUNT
Maytag BNT23J9 REF - TOP MOUNT
Maytag BNT23J9A REF - TOP MOUNT
Maytag BNT23J9LA REF - TOP MOUNT
Maytag BNT23K9 REF - TOP MOUNT
Maytag BNT23K9A REF - TOP MOUNT
Maytag BNT23L8 REF - TOP MOUNT
Maytag BNT23L8A REF - TOP MOUNT
Maytag BNT23L8K REF - TOP MOUNT
Maytag BNT23L8KA REF - TOP MOUNT
Maytag BNT23L8L REF - TOP MOUNT
Maytag BNT23L8LA REF - TOP MOUNT
Amana BP22A2E REF - BOTTOM MOUNTS
Amana BP22A2L REF - BOTTOM MOUNTS
Amana BP22AW REF - BOTTOM MOUNTS
 BP6000ER Air Conditioner
Whirlpool BPAC0500AS0 AIR CONDITIONERS
Whirlpool BPAC0500AS1 Air-conditioner/heat pump
Whirlpool BPAC0500AS2 AIR CONDITIONER
Whirlpool BPAC0500AS3 AIR CONDITIONER
Whirlpool BPAC0500FS0 AIR CONDITIONER
Whirlpool BPAC0700AS0 Air-conditioner/heat pump
Whirlpool BPAC0700AS1 AIR CONDITIONER
Whirlpool BPAC0700FS0
Whirlpool BPAC0830AS1 AIR CONDITIONER
Whirlpool BPAC0830AS2
Whirlpool BPAC1000AS0 AIR CONDITIONER
Whirlpool BPAC1000AS2 AIR CONDITIONER
Whirlpool BPAC1200AS0 Air-conditioner/heat pump
Whirlpool BPAC1200AS2 AIR CONDITIONERS
Whirlpool BPAC1200FS0 AIR CONDITIONERS
Whirlpool BPAC1230AS0 AIR CONDITIONER
Whirlpool BPAC1230AS2 AIR CONDITIONER
Whirlpool BPAC1400BS0 AIR CONDITIONER
Whirlpool BPAC1800AS0 AIR CONDITIONER
Whirlpool BPAC1800BS0 AIR CONDITIONER
Whirlpool BPAC1800BS1 AIR CONDITIONER
Whirlpool BPAC1800BS2 ROOM AIR CONDITIONER
Whirlpool BPAC1800FS0 AIR CONDITIONERS
Whirlpool BPAC1830AS1 AIR CONDITIONER
Whirlpool BPAC1830AS2 AIR CONDITIONER
Whirlpool BPAC2400AS0 Air-conditioner/heat pump
Whirlpool BPAC2400BS0 AIR CONDITIONER
Whirlpool BPAC2400BS2 AIR CONDITIONER
Whirlpool BPAC2400FS0 AIR CONDITIONERS
Whirlpool BPAC2530ES0 AIR CONDITIONERS
Whirlpool BPDH2500AS0 DEHUMIDIFIER
Whirlpool BPDH2500AS1 DEHUMIDIFIER
Whirlpool BPDH2500AS2 DEHUMIDIFIER
Whirlpool BPDH2500FS0 DEHUMIDIFIER
Whirlpool BPDH4000AS1 DEHUMIDIFIER
Whirlpool BPDH4000AS2 DEHUMIDIFIER
Whirlpool BPDH4000AS3 DEHUMIDIFIER
Whirlpool BPDH4000FS0 DEHUMIDIFIER
Whirlpool BPDH5000BS1 DEHUMIDIFIER
Whirlpool BPDH5000BS2 DEHUMIDIFIER
Whirlpool BPDH5000FS0 DEHUMIDIFIER
Maytag BPNS24H9 REF - SXS/I&W
Maytag BPNS24H9A REF - SXS/I&W
Maytag BPNS24H9H REF - SXS/I&W
Amana BQ20RB REF - BOTTOM MOUNTS
Amana BQ20RBG REF - BOTTOM MOUNTS
  #2 (permalink)
Old 03-01-2014, 10:12 AM
Junior Member
Default
The flame sensor is good, and the 24v power supply is good.
Are there other things I can check?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Gaffers & Sattler 1978 Wall Oven emayfieldz Oven Repair (including Ranges and Cooktops) 4 03-27-2018 03:25 PM
Thermador burners wont light dsprague Oven Repair (including Ranges and Cooktops) 2 10-08-2012 04:27 PM
Burners won't light deebee Oven Repair (including Ranges and Cooktops) 0 11-25-2011 09:17 AM
2 front burners wont light - how to replace? mk01 Oven Repair (including Ranges and Cooktops) 0 12-30-2009 09:47 PM
burners on stove top wont light nagchunn Oven Repair (including Ranges and Cooktops) 2 07-22-2008 08:41 PM
