Discuss
Gas log fireplace problem
 in
Heating, Ventilation, and Air Conditioning (HVAC)
I have a gas log fireplace with a switch on the wall that ignites the fire from a pilot light.
Appliance Repair Forum > Appliance Repair Help > Heating, Ventilation, and Air Conditioning (HVAC) » Gas log fireplace problem
  #1 (permalink)
Old 02-03-2014, 02:45 PM
Junior Member
bbones77 is on a distinguished road
Default Gas log fireplace problem
Brand: -brand-   Age: More than 10 years
I have a gas log fireplace with a switch on the wall that ignites the fire from a pilot light. The problem is, if I want to use my blower, I have to plug the blower into a metal box receptacle located in the service area under the fireplace, and then unplug it to shut in off. Since this wasn't very handy, I ran a 14-2 romex wire from the receptacle box to the flame switch box and wired it as an extension of the black wire to switch the blower on and off. I used a duplex switch so that I didn't have to change out the wall box to accommodate 2 separate switches. I think this is where I screwed up. I first tried the top switch for the flame. It started up and went out as it should. I turned on the bottom switch for the blower and it also started up and shut down as it should. But when I turned them on together, there was a small flash of fire and then nothing. The blower continued to run but the fire would not start.
Since the duplex shares a ground with both switches, could this have caused the problem? Also, I'm not sure what I now need to replace.
Thanks for your help!
bbones77
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Gas Log Fireplace Burner sdunlap20690 Heating, Ventilation, and Air Conditioning (HVAC) 0 02-15-2013 11:55 AM
Majestic gas fireplace - Thermocouple problem? chaskew1@gmail.com Heating, Ventilation, and Air Conditioning (HVAC) 0 01-02-2012 07:12 PM
Gas Log Fireplace arolds12 Heating, Ventilation, and Air Conditioning (HVAC) 9 04-25-2011 08:11 AM
Gas Fireplace hedgieaust20 Heating, Ventilation, and Air Conditioning (HVAC) 0 11-29-2009 12:13 PM
Low flame on gas fireplace LarryCz Oven Repair (including Ranges and Cooktops) 0 12-17-2008 08:58 PM
