Discuss
Troubleshoot Aprilaire 700M Humidifier
 in
Heating, Ventilation, and Air Conditioning (HVAC)
Hello, I have an Aprilaire 700M Home humidifier that was professionally installed and worked well last winter. This winter I
Appliance Repair Forum > Appliance Repair Help > Heating, Ventilation, and Air Conditioning (HVAC) » Troubleshoot Aprilaire 700M Humidifier
  #1 (permalink)
Old 12-21-2013, 09:55 AM
Junior Member
jrossano is on a distinguished road
Default Troubleshoot Aprilaire 700M Humidifier
Model Number: 700M   Brand: -brand-   Age: 1 - 5 years
Hello,
I have an Aprilaire 700M Home humidifier that was professionally installed and worked well last winter. This winter I replaced the pad and turned it on bit it's not working. The pad had no moisture at all so i figured it was not getting any water. So I attempted the following troubleshooting.
The water flowed fine to the solenoid and the screen was not clogged. The orifice and hose leading to the evaporator pad were not clogged either. When I turned the humidistat up I heard a click, but no sound at all from the solenoid valve. I tested the voltage in the wires coming from the humidistat and it read 28. So I took those wires and attached the directly to the solenoid wires. Again there was no click from the solenoid when I turned up the humidistat. So I ordered and installed a new 24v solenoid valve (#4040).
But here is the problem - I have the same exact symptom with the new solenoid valve! I again connected the wires from the humidistat to the solenoid and hear nothing. There is 28v coming from the humidistat, but when I connect the wires to the solenoid and measure the voltage reads .1. I don not have a 24v transformer or Id try testing with that.
Does this give anyone a clue to what the problem might be?
Thanks,
Joe
Related Models
Hoover 701
Hardwick 70131 RANGE- F/S STD GAS
Hardwick 70138 RANGE- F/S STD GAS
Maytag 701C DRYER- GAS
Hardwick 70231 RANGE- F/S STD GAS
Hardwick 70238 RANGE- F/S STD GAS
Hoover 704
Hoover 704-01
Hoover 705
Hoover 706
Hoover 707
Amana 7096 MWAVE - FAMILY SIZE (60 HZ)
Maytag 70C DRYER- GAS
Hoover 711
Amana 7121.000 MWAVE - FAMILY SIZE (60 HZ)
Hoover 714
Amana 7154.000 MWAVE - FAMILY SIZE (60 HZ)
Hoover 716
Amana 7160.000 MWAVE - FAMILY SIZE (60 HZ)
Hoover 719
Amana 7190.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 7190.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 7196 MWAVE - FAMILY SIZE (60 HZ)
Kenmore 7198772780 Microwave Domestic
Kenmore 7198842780 MICROWAVE OVEN
Frigidaire 72-2547-00-01 Tap(v1) / Gas Range
Frigidaire 72-2547-00-02 Tap(v4) / Gas Range
Frigidaire 72-2547-00-03 Tap(v7) / Gas Range
Frigidaire 72-2547-00-04 Tap(v1) / Gas Range
Frigidaire 72-2547-00-05 Tap(v4) / Gas Range
Frigidaire 72-2547-00-06 Tap(v7) / Gas Range
Frigidaire 72-2547-00-07 Tap(v1) / Gas Range
Frigidaire 72-2547-00-08 Tap(v1) / Gas Range
Frigidaire 72-2547-00-09 Tap(v1) / Gas Range
Frigidaire 72-2547-23-01 Tap(v2) / Gas Range
Frigidaire 72-2547-23-02 Tap(v5) / Gas Range
Frigidaire 72-2547-23-03 Tap(v8) / Gas Range
Frigidaire 72-2547-23-04 Tap(v2) / Gas Range
Frigidaire 72-2547-23-05 Tap(v5) / Gas Range
Frigidaire 72-2547-23-06 Tap(v8) / Gas Range
Frigidaire 72-2547-23-07 Tap(v2) / Gas Range
Frigidaire 72-2547-23-08 Tap(v2) / Gas Range
Frigidaire 72-2547-23-09 Tap(v2) / Gas Range
Frigidaire 72-2547-66-01 Tap(v3) / Gas Range
Frigidaire 72-2547-66-02 Tap(v6) / Gas Range
Frigidaire 72-2547-66-03 Tap(v9) / Gas Range
Frigidaire 72-2547-66-04 Tap(v3) / Gas Range
Frigidaire 72-2547-66-05 Tap(v6) / Gas Range
Frigidaire 72-2547-66-06 Tap(v9) / Gas Range
Frigidaire 72-2547-66-07 Tap(v3) / Gas Range
Frigidaire 72-2547-66-08 Tap(v3) / Gas Range
Frigidaire 72-2547-66-09 Tap(v3) / Gas Range
Tappan 72-3651-00 RANGE
Frigidaire 72-3651-00-01 Tap(v1) / Gas Range
Frigidaire 72-3651-00-02 Tap(v1) / Gas Range
Frigidaire 72-3651-00-03 Tap(v3) / Gas Range
Frigidaire 72-3651-00-04 Tap(v1) / Gas Range
Frigidaire 72-3651-00-05 Tap(v1) / Gas Range
Frigidaire 72-3651-00-06 Tap(v1) / Gas Range
Frigidaire 72-3651-00-07 Tap(v2) / Gas Range
Frigidaire 72-3651-00-08 Tap(v1) / Gas Range
Tappan 72-3651-01 RANGE
Frigidaire 72-3651-23-01 Tap(v2) / Gas Range
Frigidaire 72-3651-23-02 Tap(v2) / Gas Range
Frigidaire 72-3651-23-03 Tap(v4) / Gas Range
Frigidaire 72-3651-23-04 Tap(v2) / Gas Range
Frigidaire 72-3651-23-05 Tap(v2) / Gas Range
Frigidaire 72-3651-23-06 Tap(v3) / Gas Range
Frigidaire 72-3651-23-07 Tap(v4) / Gas Range
Frigidaire 72-3651-23-08 Tap(v2) / Gas Range
Frigidaire 72-3657-00-01 Tap(v1) / Gas Range
Frigidaire 72-3657-00-02 Tap(v4) / Gas Range
Frigidaire 72-3657-00-03 Tap(v1) / Gas Range
Frigidaire 72-3657-00-04 Tap(v4) / Gas Range
Frigidaire 72-3657-00-05 Tap(v1) / Gas Range
Frigidaire 72-3657-00-06 Tap(v7) / Gas Range
Frigidaire 72-3657-00-07 Tap(v1) / Gas Range
Frigidaire 72-3657-00-08 Tap(v1) / Gas Range
Frigidaire 72-3657-00-09 Tap(v7) / Gas Range
Frigidaire 72-3657-00-10 Tap(v1) / Gas Range
Frigidaire 72-3657-00-11 Tap(v4) / Gas Range
Frigidaire 72-3657-00-12 Tap(v7) / Gas Range
Frigidaire 72-3657-00-13 Tap(v1) / Gas Range
Frigidaire 72-3657-23-01 Tap(v2) / Gas Range
Frigidaire 72-3657-23-02 Tap(v5) / Gas Range
Frigidaire 72-3657-23-03 Tap(v2) / Gas Range
Frigidaire 72-3657-23-04 Tap(v5) / Gas Range
Frigidaire 72-3657-23-05 Tap(v2) / Gas Range
Frigidaire 72-3657-23-06 Tap(v8) / Gas Range
Frigidaire 72-3657-23-07 Tap(v2) / Gas Range
Frigidaire 72-3657-23-08 Tap(v2) / Gas Range
Frigidaire 72-3657-23-09 Tap(v8) / Gas Range
Frigidaire 72-3657-23-10 Tap(v2) / Gas Range
Frigidaire 72-3657-23-11 Tap(v5) / Gas Range
Frigidaire 72-3657-23-12 Tap(v8) / Gas Range
Frigidaire 72-3657-23-13 Tap(v2) / Gas Range
Frigidaire 72-3657-66-01 Tap(v3) / Gas Range
Frigidaire 72-3657-66-02 Tap(v6) / Gas Range
Frigidaire 72-3657-66-03 Tap(v3) / Gas Range
Frigidaire 72-3657-66-04 Tap(v6) / Gas Range
Frigidaire 72-3657-66-05 Tap(v3) / Gas Range
Frigidaire 72-3657-66-06 Tap(v9) / Gas Range
Frigidaire 72-3657-66-07 Tap(v3) / Gas Range
Frigidaire 72-3657-66-08 Tap(v3) / Gas Range
Frigidaire 72-3657-66-09 Tap(v9) / Gas Range
Frigidaire 72-3657-66-10 Tap(v3) / Gas Range
Frigidaire 72-3657-66-11 Tap(v6) / Gas Range
Frigidaire 72-3657-66-12 Tap(v9) / Gas Range
Frigidaire 72-3657-66-13 Tap(v3) / Gas Range
Frigidaire 72-3662-00-01 Tap(v1) / Gas Range
Frigidaire 72-3662-23-01 Tap(v2) / Gas Range
Frigidaire 72-3977-00-01 Tap(v1) / Gas Range
Frigidaire 72-3977-00-02 Tap(v4) / Gas Range
Frigidaire 72-3977-00-03 Tap(v7) / Gas Range
Frigidaire 72-3977-00-04 Tap(v10) / Gas Range
Frigidaire 72-3977-00-05 Tap(v1) / Gas Range
Frigidaire 72-3977-00-06 Tap(v4) / Gas Range
Frigidaire 72-3977-00-07 Tap(v1) / Gas Range
Frigidaire 72-3977-00-08 Tap(v7) / Gas Range
Frigidaire 72-3977-00-09 Tap(v1) / Gas Range
  #2 (permalink)
Old 01-05-2014, 02:50 PM
Junior Member
nigne2011 is on a distinguished road
Default
hi, you can see this manual. Aprilaire Humidifier Service Manual | Air Conditioning Guide Book
  #3 (permalink)
Old 01-16-2014, 06:00 PM
Junior Member
Default
I bypassed the humidistat with a jumper wire and the original solenoid worked fine. So I ordered and installed a new humidistat and all is working again. I even got to return the new solenoid valve for a refund!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Humidifier zenith dannymaio Heating, Ventilation, and Air Conditioning (HVAC) 0 06-13-2011 11:31 AM
Humidifier zenith dannymaio Heating, Ventilation, and Air Conditioning (HVAC) 0 06-10-2011 05:18 PM
Humidifier Not Getting Water SaveSomeGreen Heating, Ventilation, and Air Conditioning (HVAC) 0 02-25-2011 11:10 AM
De-humidifier probs? slimjim Heating, Ventilation, and Air Conditioning (HVAC) 4 05-31-2009 07:03 PM
Humidifier Question ideburger Heating, Ventilation, and Air Conditioning (HVAC) 1 12-05-2008 07:49 AM
