Discuss
Carrier Heater doesn't turn on please advise
 in
Heating, Ventilation, and Air Conditioning (HVAC)
Hello, My 1990 Carrier 58PAV075-JC doesn't turn on. I have a Carrier model # 58PAV075-JC (---product # 58PAV075-111JC). The unit
Appliance Repair Forum > Appliance Repair Help > Heating, Ventilation, and Air Conditioning (HVAC) » Carrier Heater doesn't turn on please advise
  #1 (permalink)
Old 11-19-2013, 11:43 PM
Junior Member
advo is on a distinguished road
Default Carrier Heater doesn't turn on please advise
Model Number: 58PAV075-JC   Brand: -other-   Age: More than 10 years
Hello,
My 1990 Carrier 58PAV075-JC doesn't turn on. I have a Carrier model # 58PAV075-JC (---product # 58PAV075-111JC). The unit is not turning on. I see that the ignitor piece glows bright orange, but I dont see/smell gas going in (missing the hissing sound and blue flames). I'd opened up the unit and there is a self test procedure sticker. I had touched the 2 terminals and the unit cycles through its fan, ignitor, relay, blower etc. I'd even took the cover off for the control board. The 3 amp fuse looked good. I then tried to measure voltage at the blue wire (going into M1 terminal) and brown wire going into C2 at the gas valve. There isn't any voltage at all. I'd used a multimeter set on auto Volt and measured across both terminals and even from each terminal to ground..still no voltage. I got 90 ohm resistance measuring the 2 prongs in the switch at the gas valve. I suspect the relay for the gas valve is bad because when I jumped 24 volts to the gas valve manually, it opened. Is it possible to buy just the relay or do I have to buy the whole board. Please advise and thank you in advance.
Adam
Related Models
Frigidaire 5908A AIR CONDITIONER
Hoover 593
Kenmore 59650002100 REFRIGERATOR
Kenmore 59650003100 REFRIGERATOR
Kenmore 59650004100 REFRIGERATOR
Kenmore 59650009100 REFRIGERATOR
Kenmore 59650012100 SIDE-BY-SIDE REFRIGERATOR
Kenmore 59650013100 SIDE-BY-SIDE REFRIGERATOR
Kenmore 59650014100 SIDE-BY-SIDE REFRIGERATOR
Kenmore 59650019100 SIDE-BY-SIDE REFRIGERATOR
Kenmore 59650392000 REFRIGERATOR
Kenmore 59650392001 REFRIGERATOR SXS
Kenmore 59650392990 SIDE-BY-SIDE
Kenmore 59650394000 REFRIGERATOR
Kenmore 59650394001 REFRIGERATOR SXS
Kenmore 59650394990 SIDE-BY-SIDE
Kenmore 59650399000 REFRIGERATOR
Kenmore 59650399001 REFRIGERATOR SXS
Kenmore 59650399990 SIDE-BY-SIDE
Kenmore 59650692000 KENMORE SXS REFRIGERATOR
Kenmore 59650692001 REFRIGERATOR SXS
Kenmore 59650694000 KENMORE SXS REFRIGERATOR
Kenmore 59650694001 REFRIGERATOR SXS
Kenmore 59650699000 KENMORE SXS REFRIGERATOR
Kenmore 59650699001 REFRIGERATOR SXS
Kenmore 59651672100 26 SIDE-BY-SIDE REFRIGERATOR
Kenmore 59651673100 26 SIDE-BY-SIDE REFRIGERATOR
Kenmore 59651674100 26 SIDE-BY-SIDE REFRIGERATOR
Kenmore 59651679100 26 SIDE-BY-SIDE REFRIGERATOR
Kenmore 59652672200 KENMORE REFRIGERATION
Kenmore 59652672201 KENMORE REFRIGERATOR
Kenmore 59652672202 KENMORE REFRIGERATION
Kenmore 59652673200 KENMORE REFRIGERATION
Kenmore 59652673201 KENMORE REFRIGERATOR
Kenmore 59652673202 KENMORE REFRIGERATION
Kenmore 59652674200 KENMORE REFRIGERATION
Kenmore 59652674201 KENMORE REFRIGERATOR
Kenmore 59652674202 KENMORE REFRIGERATION
Kenmore 59652679200 KENMORE REFRIGERATION
Kenmore 59652679201 KENMORE REFRIGERATOR
Kenmore 59652679202 KENMORE REFRIGERATION
Kenmore 59653462300 KENMORE REFRIGERATOR
Kenmore 59653462301 KENMORE REFRIGERATOR
Kenmore 59653462302 KENMORE REFRIGERATOR
Kenmore 59653463300 KENMORE REFRIGERATOR
Kenmore 59653463301 KENMORE REFRIGERATOR
Kenmore 59653463302 KENMORE REFRIGERATOR
Kenmore 59653464300 KENMORE REFRIGERATOR
Kenmore 59653464301 KENMORE REFRIGERATOR
Kenmore 59653464302 KENMORE REFRIGERATOR
Kenmore 59653469300 KENMORE REFRIGERATOR
Kenmore 59653469301 KENMORE REFRIGERATOR
Kenmore 59653469302 KENMORE REFRIGERATOR
Kenmore 59655652500 KENMORE REFRIGERATOR
Kenmore 59655653500 KENMORE REFRIGERATOR
Kenmore 59655654500 KENMORE REFRIGERATOR
Kenmore 59655659500 KENMORE REFRIGERATOR
Kenmore 59655662500 KENMORE REFRIGERATOR
Kenmore 59655663500 KENMORE REFRIGERATOR
Kenmore 59655664500 KENMORE REFRIGERATOR
Kenmore 59655669500 KENMORE REFRIGERATOR
Kenmore 59657002600 KENMORE REFRIGERATOR
Kenmore 59657003600 KENMORE REFRIGERATOR
Kenmore 59657006600 KENMORE REFRIGERATOR
Kenmore 59657009600 KENMORE REFRIGERATOR
Kenmore 59657012600 KENMORE REFRIGERATOR
Kenmore 59657013600 KENMORE REFRIGERATOR
Kenmore 59657016600 KENMORE REFRIGERATOR
Kenmore 59657019600 KENMORE REFRIGERATOR
Kenmore 59657043600 KENMORE REFRIGERATOR
Kenmore 59657049600 KENMORE REFRIGERATOR
Kenmore 59657053600 KENMORE REFRIGERATOR
Kenmore 59657059600 KENMORE REFRIGERATOR
Kenmore 59657082790 20" BUILDERS SIDE BY SIDE
Kenmore 59657082791 20 SIDE-BY-SIDE REFRIGERATOR
Kenmore 59657085790 20" BUILDERS SIDE BY SIDE
Kenmore 59657085791 20 SIDE-BY-SIDE REFRIGERATOR
Kenmore 59657087790 20 BUILDERS SIDE BY SIDE
Kenmore 59657087791 20 SIDE-BY-SIDE REFRIGERATOR
Kenmore 59657089790 20" BUILDERS SIDE BY SIDE
Kenmore 59657089791 20 SIDE-BY-SIDE REFRIGERATOR
Kenmore 59657542790 25 SIDE BY SIDE REFRIGERATOR
Kenmore 59657542791 25 SIDE-BY-SIDE REFRIGERATOR
Kenmore 59657547790 25 SIDE BY SIDE REFRIGERATOR
Kenmore 59657547791 25 SIDE-BY-SIDE REFRIGERATOR
Kenmore 59657582790 25 SIDE BY SIDE REFRIGERATOR
Kenmore 59657582791 25 SIDE-BY-SIDE REFRIGERATOR
Kenmore 59657585790 25 SIDE BY SIDE REFRIGERATOR
Kenmore 59657585791 25 SIDE-BY-SIDE REFRIGERATOR
Kenmore 59657587790 SIDE BY SIDE REFRIGERATOR
Kenmore 59657587791 25 SIDE-BY-SIDE REFRIGERATOR
Kenmore 59658392890 Side-by-Side
Kenmore 59658395890 Side-by-Side
Kenmore 59658397890 Side-by-Side
Kenmore 59658622990 SIDE-BY-SIDE REFRIGERATOR
Kenmore 59658627990 SIDE-BY-SIDE REFRIGERATOR
Kenmore 59658632890 Side-by-Side
Kenmore 59658632891 SIDE-BY-SIDE REFRIGERATOR
Kenmore 59658634000 SIDE-BY-SIDE REFRIGERATOR
Kenmore 59658635890 Side-by-Side
Kenmore 59658635891 SIDE-BY-SIDE REFRIGERATOR
Kenmore 59658637890 Side-by-Side
Kenmore 59658642890 Side-by-Side
Kenmore 59658642891 REFRIGERATOR
Kenmore 59658644000 REFRIGERATOR
Kenmore 59658647890 Side-by-Side
Kenmore 59658692890 Side-by-Side
Kenmore 59658695890 Side-by-Side
Kenmore 59658697890 Side-by-Side
Kenmore 59661102100 REFRIGERATOR
Kenmore 59661102101 REFRIGERATOR
Kenmore 59661103100 REFRIGERATOR
Kenmore 59661103101 REFRIGERATOR
Kenmore 59661104100 REFRIGERATOR
Kenmore 59661104101 REFRIGERATOR
Kenmore 59661109100 REFRIGERATOR
Kenmore 59661109101 REFRIGERATOR
Kenmore 59661142100 REFRIGERATOR
Kenmore 59661142101 REFRIGERATOR
Kenmore 59661144100 REFRIGERATOR
  #2 (permalink)
Old 12-04-2013, 08:38 PM
Junior Member
Gasguy3713 is on a distinguished road
Default
Sounds like you got it figured out....bad circuit board. You have to purchase the whole board.
  #3 (permalink)
Junior Member
Default
  #4 (permalink)
Old 12-05-2013, 12:22 AM
Junior Member
Default
Thank you for the reply.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Janitrol a/c Heater Element and blower fan won't turn off RVAN Heating, Ventilation, and Air Conditioning (HVAC) 0 02-15-2012 08:58 PM
Dryer heater turn on and off lyon62 Dryer Repair 1 11-15-2011 01:00 PM
Looking to see defrost heater turn on man1repair Refrigerator & Freezer Repair 0 12-11-2010 08:50 PM
Driier will not turn but heater is on gumpps Dryer Repair 8 01-07-2010 04:05 AM
Need Some Advise ftw-con Dishwasher Repair 0 04-05-2009 05:52 AM
