Discuss
Dual Heat Pump Gas Furnace System Problem
 in
Heating, Ventilation, and Air Conditioning (HVAC)
I have a dual Lennox heat pump (14HPX), gas furnace (G40UH(X) system. Units were installed in 2010. All worked fine
Appliance Repair Forum > Appliance Repair Help > Heating, Ventilation, and Air Conditioning (HVAC) » Dual Heat Pump Gas Furnace System Problem
  #1 (permalink)
Old 11-05-2013, 09:29 PM
Junior Member
RVinBad is on a distinguished road
Question Dual Heat Pump Gas Furnace System Problem
Model Number: 14HPX and G40UH(X)   Brand: -other-   Age: 1 - 5 years
I have a dual Lennox heat pump (14HPX), gas furnace (G40UH(X) system. Units were installed in 2010. All worked fine until October 2013, then gas furnace failed to come on when outside temperature was < 40 F.
System is supposed to switch seamlessly from heat pump to gas furnace when the balance point is reached. It does not do so. In order to get the gas furnace to work, we have to change the System switch from Auto to Emergency (EM) Heat.
On warmer mornings, with the outside temperature >40 F, the heat pump (which is outside) supplies warm air. On colder mornings, the heat pump won't work and the gas furnace (in the garage) won't kick in automatically, so we wake to a COLD house.
I've checked the LEDs, and they indicate power on (simultaneous slow flash), but no heating demand initiated from the programmable thermostat. When we select EM heat, the LEDS show a simultaneous fast flash, and we're getting heat from the gas furnace (because the heat pump is by-passed).
Any ideas on what's causing this problem greatly appreciated.
Related Models
Amana 14M12TA ROOM AIR CONDITIONER
Amana 14M13TA ROOM AIR CONDITIONER
Amana 14M13TB ROOM AIR CONDITIONER
Amana 14QZ23RC ROOM AIR CONDITIONER
Amana 14QZ23RC1 ROOM AIR CONDITIONER
Amana 14QZ23TA ROOM AIR CONDITIONER
Amana 14QZ23TB ROOM AIR CONDITIONER
Amana 15 FREEZER- VERTICAL
Frigidaire 15-052A
Frigidaire 15-052C
Frigidaire 15-072A
Frigidaire 15-072B
Frigidaire 15-082A
Frigidaire 15-092B
Frigidaire 15-127A
Frigidaire 15-183A
Frigidaire 15-187A
Magic Chef 1500PAA RANGE- F/S STD ELE
Magic Chef 1500PAW RANGE- F/S STD ELE
Magic Chef 1500PRA RANGE- F/S STD ELE
Magic Chef 1500PRW RANGE- F/S STD ELE
Thermador 1501
Frigidaire 1507 SINKMASTER DISPOSAL
Amana 150A-20 ROOM AIR CONDITIONER
Amana 150A-20H ROOM AIR CONDITIONER
Amana 150A-2HN ROOM AIR CONDITIONER
Amana 150A-2N ROOM AIR CONDITIONER
Amana 150A-30 ROOM AIR CONDITIONER
Amana 150A-30H ROOM AIR CONDITIONER
Amana 150A-356 ROOM AIR CONDITIONER
Amana 150A-3HN ROOM AIR CONDITIONER
Amana 150A-3M ROOM AIR CONDITIONER
Amana 150A-3N ROOM AIR CONDITIONER
Amana 150A-3P ROOM AIR CONDITIONER
Amana 150A-3PH ROOM AIR CONDITIONER
Amana 150A-3R ROOM AIR CONDITIONER
Amana 150A-3RH ROOM AIR CONDITIONER
Amana 150A-556 ROOM AIR CONDITIONER
Amana 150A-8R ROOM AIR CONDITIONER
Amana 150A-S3N ROOM AIR CONDITIONER
Amana 150C-3P ROOM AIR CONDITIONER
Amana 150C-3PH ROOM AIR CONDITIONER
Amana 150C-3R ROOM AIR CONDITIONER
Amana 150C-3RH ROOM AIR CONDITIONER
Amana 150C-8P ROOM AIR CONDITIONER
Amana 150C-8R ROOM AIR CONDITIONER
Amana 150C-8RH ROOM AIR CONDITIONER
Amana 150D-356 ROOM AIR CONDITIONER
Amana 150D-556 ROOM AIR CONDITIONER
Amana 1510.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 1520.0 MWAVE - FAMILY SIZE (60 HZ)
Amana 1520.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 1521.000 MWAVE - FAMILY SIZE (60 HZ)
Roper 1525*1A GAS RANGE
Roper 1525*2A GAS RANGE
Roper 1525*3A GAS RANGE
Roper 1525L0A GAS RANGE
Frigidaire 1527 SINKMASTER DISPOSAL
Frigidaire 15304-0A REFRIGERATOR
Frigidaire 15304-7A REFRIGERATOR
General Electric 154510 Electric range
Frigidaire 1547 SINKMASTER DISPOSAL
Amana 1550.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 1551.000 MWAVE - FAMILY SIZE (60 HZ)
Kenmore 1552399-2 OPTIONAL ROTISSERIE KIT
Kenmore 15530810 KENMORE GAS BUILT-IN OVEN UNIT
Kenmore 15530815 KENMORE GAS OVEN UNIT
Kenmore 1553107050 OPTIONAL ROTISSERIE KIT
Kenmore 1553227290 KENMORE GAS BUILT-IN CONTINUOUS CLEANING OVEN
Kenmore 1553227291 KENMORE GAS BUILT-IN CONTINOUS CLEANING OVEN
Kenmore 1553227590 KENMORE GAS BUILT-IN CONTINUOUS CLEANING OVEN
Kenmore 1553227690 KENMORE GAS BUILT-IN CONTINUOUS CLEANING OVEN
Kenmore 15535060 BUILT-IN OVEN UNIT
Kenmore 15535170 KENMORE ELECTRIC BUILT-IN OVEN UNIT
Kenmore 15535260 BUILT-IN OVEN UNIT
Kenmore 1553546600 KENMORE GAS DROP-IN RANGE
Kenmore 1553546620 KENMORE GAS DROP-IN RANGE
Kenmore 1553546640 KENMORE GAS DROP-IN RANGE
Kenmore 1553546650 KENMORE GAS DROP-IN RANGE
Kenmore 1553546660 KENMORE GAS DROP-IN RANGE
Kenmore 1553546690 KENMORE GAS DROP-IN RANGE
Kenmore 1553546700 KENMORE GAS DROP-IN RANGE
Kenmore 1553546701 KENMORE GAS DROP-IN RANGE
Kenmore 1553546720 KENMORE GAS DROP-IN RANGE
Kenmore 1553546721 KENMORE GAS DROP-IN RANGE
Kenmore 1553546730 KENMORE GAS DROP-IN RANGE
Kenmore 1553546740 KENMORE GAS DROP-IN RANGE
Kenmore 1553546741 KENMORE GAS DROP-IN RANGE
Kenmore 1553546760 KENMORE GAS DROP-IN RANGE
Kenmore 1553546761 KENMORE GAS DROP-IN RANGE
Kenmore 1553546790 KENMORE GAS DROP-IN RANGE
Kenmore 1553547000 KENMORE GAS DROP-IN RANGE
Kenmore 1553547020 KENMORE GAS DROP-IN RANGE
Kenmore 1553547040 KENMORE GAS DROP-IN RANGE
Kenmore 1553547060 KENMORE GAS DROP-IN RANGE
Kenmore 1553547080 KENMORE GAS DROP-IN RANGE
Kenmore 1553547090 KENMORE GAS DROP-IN RANGE
Kenmore 1553567000 KENMORE RANGE
Kenmore 1553567001 KENMORE GAS DROP-IN RANGE
Kenmore 1553567020 KENMORE RANGE
Kenmore 1553567021 KENMORE GAS DROP-IN RANGE
Kenmore 1553567040 KENMORE RANGE
Kenmore 1553567041 KENMORE GAS DROP-IN RANGE
Kenmore 1553567060 KENMORE RANGE
Kenmore 1553567061 KENMORE GAS DROP-IN RANGE
Kenmore 1553567090 KENMORE RANGE
Kenmore 1553567091 KENMORE GAS DROP-IN RANGE
Kenmore 1553567200 KENMORE GAS DROP-IN RANGE
Kenmore 1553567201 KENMORE GAS DROP-IN RANGE
Kenmore 1553567290 KENMORE GAS DROP-IN RANGE
Kenmore 1553567291 KENMORE GAS DROP-IN RANGE
Kenmore 1553567292 KENMORE GAS DROP-IN RANGE
Kenmore 1553567300 KENMORE GAS DROP-IN RANGE
Kenmore 1553567301 KENMORE DROP-IN RANGE
Kenmore 1553567302 KENMORE GAS DROP-IN RANGE
Kenmore 1553567303 KENMORE GAS DROP-ON RANGE
Kenmore 1553567390 KENMORE GAS DROP-IN RANGE
Kenmore 1553567391 KENMORE DROP-IN RANGE
Kenmore 1553567392 KENMORE GAS DROP-IN RANGE
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Dual Wave Microwave System- original to house- 1986J Rochelletx65 Oven Repair (including Ranges and Cooktops) 15 01-07-2015 07:32 AM
GE Dual Wave II Microwave System amstuart1964 Oven Repair (including Ranges and Cooktops) 0 09-16-2013 03:26 PM
GE Dual Wave II Microwave System Display Off blminca Oven Repair (including Ranges and Cooktops) 0 01-24-2012 04:02 PM
GE dual wave microwave system rozman Microwave Repair 0 03-09-2009 08:04 PM
