Discuss
Burner cutting in and out during startup of gas heater
 in
Heating, Ventilation, and Air Conditioning (HVAC)
I have a Carrier gaspack. Carrier is not listed in the "Brand" pulldown menu for this forum for some reason
Appliance Repair Forum > Appliance Repair Help > Heating, Ventilation, and Air Conditioning (HVAC) » Burner cutting in and out during startup of gas heater
  #1 (permalink)
Old 10-31-2013, 02:52 PM
Junior Member
km4hr is on a distinguished road
Default Burner cutting in and out during startup of gas heater
Model Number: 48SX-400-074   Brand: -brand-   Age: More than 10 years
I have a Carrier gaspack. Carrier is not listed in the "Brand" pulldown menu for this forum for some reason ... wonder why?
Anyway, the burner on my furnace is cycling on an off a few times before it stays lit. Once lit, the furnace works properly.
The problem seems to occur mostly after the furnace has been down a while, such as in the morning when when my programmable thermostat turns up the heat for the day. The furnace is outside my bedroom room and I can hear what it's doing. First, I hear the sound of the burner coming on. In normal operation this sound would continue a few seconds after which the blower would come on. But instead the burner turns off (gets quiet).
After a few seconds I hear the burner start again. This time it seems to say on a little longer. But then it goes silent again. After a few cycles of the burner cutting on and off the blower also comes on, but not for long. Everything goes quiet again. Then I hear the burner start again.
After several more cycles the burner finally stays on. The blower comes on and stays on until the house is warm. For the rest of the day everything seems fine. The furnace seems to cycle on and off properly. I fear that something is waiting for the coldest day of the year to quit completely.
I'm not a technician but I've done some reading. My theory is that the flame sensor may be getting weak. This would cause the computer to shut the gas valve off if the flame sensor's signal does not appear in time. Maybe after a few tries the flame sensor finally gets hot enough to deliver a solid signal. Then everything works fine for the rest of the day. But this is just what it sounds like to my untrained ears. I could very likely be completely wrong. Do flame sensors get weak before failing completely?
Any comments are greatly appreciated.
Thanks for taking the time to consider my situation.
Related Models
Frigidaire 49-2151-00-01 Tap(v1) / 27 " Gas Dryer
Frigidaire 49-2151-00-02 Tap(v1) / 27 " Gas Dryer
Frigidaire 49-2151-23-01 Tap(v2) / 27 " Gas Dryer
Frigidaire 49-2151-23-02 Tap(v2) / 27 " Gas Dryer
Frigidaire 49-2251-00-01 Tap(v3) / 27 " Gas Dryer
Frigidaire 49-2251-00-02 Tap(v3) / 27 " Gas Dryer
Frigidaire 49-2251-00-03 Tap(v1) / 27 " Gas Dryer
Frigidaire 49-2251-00-04 Tap(v1) / 27 " Gas Dryer
Frigidaire 49-2251-23-01 Tap(v4) / 27 " Gas Dryer
Frigidaire 49-2251-23-02 Tap(v4) / 27 " Gas Dryer
Frigidaire 49-2251-23-03 Tap(v2) / 27 " Gas Dryer
Frigidaire 49-2251-23-04 Tap(v2) / 27 " Gas Dryer
Frigidaire 49-2351-00-01 Tap(v1) / 27 " Gas Dryer
Frigidaire 49-2351-23-01 Tap(v2) / 27 " Gas Dryer
Frigidaire 49-2451-00-01 Tap(v5) / 27 " Gas Dryer
Frigidaire 49-2451-00-03 Tap(v1) / 27 " Gas Dryer
Frigidaire 49-2451-23-01 Tap(v6) / 27 " Gas Dryer
Frigidaire 49-2451-23-03 Tap(v2) / 27 " Gas Dryer
Frigidaire 49-2551-00-01 Tap(v3) / 27 " Gas Dryer
Frigidaire 49-2551-00-03 Tap(v1) / 27 " Gas Dryer
Frigidaire 49-2551-23-01 Tap(v4) / 27 " Gas Dryer
Frigidaire 49-2551-23-03 Tap(v2) / 27 " Gas Dryer
Frigidaire 49-2707-00-01 Tap(v2)
Frigidaire 49-2707-23-01 Tap(v1)
Frigidaire 49-2751-00-01 Tap(v1) / 27 " Gas Dryer
Frigidaire 49-2751-00-02 Tap(v1) / 27 " Gas Dryer
Frigidaire 49-2751-23-01 Tap(v2) / 27 " Gas Dryer
Frigidaire 49-2827-00-01 Tap(v1) / Gas Dryer
Frigidaire 49-2827-23-01 Tap(v2) / Gas Dryer
Frigidaire 49-2828-00-01 Tap(v3) / Gas Dryer
Frigidaire 49-2828-00-03 Tap(v3) / Gas Dryer
Frigidaire 49-2828-00-04 Tap(v3) / 27 " Gas Dryer
Frigidaire 49-2828-23-01 Tap(v4) / Gas Dryer
Frigidaire 49-2828-23-02 Tap(v2) / Gas Dryer
Frigidaire 49-2828-23-03 Tap(v4) / Gas Dryer
Frigidaire 49-2828-23-04 Tap(v4) / 27 " Gas Dryer
Frigidaire 49-2847-00-01 Tap(v3) / Gas Dryer
Frigidaire 49-2847-23-01 Tap(v4) / Gas Dryer
Frigidaire 49-2848-00-01 Tap(v1) / Gas Dryer
Frigidaire 49-2848-00-02 Tap(v1) / Gas Dryer
Frigidaire 49-2848-00-03 Tap(v1) / Gas Dryer
Frigidaire 49-2848-00-04 Tap(v1) / 27 " Gas Dryer
Frigidaire 49-2848-23-01 Tap(v2) / Gas Dryer
Frigidaire 49-2848-23-03 Tap(v2) / Gas Dryer
Frigidaire 49-2848-23-04 Tap(v2) / 27 " Gas Dryer
Jenn-Air 4900 RANGE- F/S STD DDRAFT ELE
Frigidaire 49152-0A UPRIGHT FREEZER
Frigidaire 49152-0B CHEST FREEZER
Frigidaire 49161-0A FREEZER
Frigidaire 49161-0B FREEZER
Frigidaire 49257-7A FREEZER
Frigidaire 49257A FREEZER
Frigidaire 49258-7A FREEZER
Frigidaire 49258A FREEZER
Frigidaire 49259A UPRIGHT FREEZER
Frigidaire 49259B UPRIGHT FREEZER
Frigidaire 49269A UPRIGHT FREEZER
Frigidaire 49269B UPRIGHT FREEZER
Frigidaire 49647-7C FREEZER
Frigidaire 49647C FREEZER
Frigidaire 49648-7A FREEZER
Frigidaire 49651-0A FREEZER
Frigidaire 49651-0B FREEZER
Frigidaire 49651-0C UPRIGHT FREEZER
Frigidaire 49668-7A FREEZER
Frigidaire 49669 UPRIGHT FREEZER
Frigidaire 49669B UPRIGHT FREEZER
Hoover 49811001
Frigidaire 49847-7A FREEZER
Frigidaire 49847A FREEZER
Frigidaire 49947-7A FREEZER
Frigidaire 49947A FREEZER
Whirlpool 4ACE07LD0 AIR CONDITIONER
Whirlpool 4ACE23LD0 AIR CONDITONER
Whirlpool 4AD50DSL1 DEHUMIDIFIER
Whirlpool 4AD50J0 DEHUMIDIFIER
Whirlpool 4CA2762XWW0 Commercial Washers
Whirlpool 4CA2782XYW0 Commercial Washers
Whirlpool 4CACM07DD0 THROUGH-THE-WALL AIR CONDITIONER
Whirlpool 4CACM10DD0 THROUGH-THE-WALL AIR CONDITIONER
Whirlpool 4CACM12DD0 THROUGH-THE-WALL AIR CONDITIONER
Whirlpool 4CACM12ND0 THROUGH-THE-WALL AIR CONDITIONER
Whirlpool 4CACM14DD0 THROUGH-THE-WALL AIR CONDITIONER
Whirlpool 4CACM14ND0 THROUGH-THE-WALL AIR CONDITIONER
Whirlpool 4CACM18DD0 THROUGH-THE-WALL AIR CONDITIONER
Whirlpool 4CACM18ND0 THROUGH-THE-WALL AIR CONDITIONER
Whirlpool 4CACM23DD1 THROUGH-THE-WALL AIR CONDITIONER
Whirlpool 4CACM23ND1 THROUGH-THE-WALL AIR CONDITIONER
Whirlpool 4ECKMF87 ICEMAKER KIT
Whirlpool 4ED20ZKIFN00 REFRIGERATOR
Whirlpool 4ED20ZKIFN01 REFRIGERATOR
Whirlpool 4ED20ZKIFW00 REFRIGERATOR
Whirlpool 4ED20ZKIFW01 REFRIGERATOR
Whirlpool 4ED20ZKXBN00 REFRIGERATOR
Whirlpool 4ED20ZKXBW00 REFRIGERATOR
Whirlpool 4ED20ZKXDN00 SIDE-BY-SIDE REFRIGERATOR
Whirlpool 4ED20ZKXDN01 KITCHEN REFRIGERATORS
Whirlpool 4ED20ZKXDN02 REFRIGERATORS
Whirlpool 4ED20ZKXDW00 SIDE-BY-SIDE REFRIGERATOR
Whirlpool 4ED20ZKXDW01 KITCHEN REFRIGERATORS
Whirlpool 4ED20ZKXDW02 REFRIGERATORS
Whirlpool 4ED20ZKXFN00 REFRIGERATOR
Whirlpool 4ED20ZKXFW00 REFRIGERATOR
Whirlpool 4ED22DWXTN01 Refrigerators*
Whirlpool 4ED22DWXTW00 Refrigerators*
Whirlpool 4ED25DQXAW00 Refrigerators*
Whirlpool 4ED25DQXBN00 REFRIGERATOR
Whirlpool 4ED25DQXBW00 REFRIGERATOR
Whirlpool 4ED25DQXDN00 REFRIGERATOR
Whirlpool 4ED25DQXDN01 REFRIGERATORS
Whirlpool 4ED25DQXDN02 REFRIGERATORS
Whirlpool 4ED25DQXDW00 REFRIGERATOR
Whirlpool 4ED25DQXDW01 REFRIGERATORS
Whirlpool 4ED25DQXDW02 REFRIGERATORS
Whirlpool 4ED25DQXFN00 REFRIGERATOR
Whirlpool 4ED25DQXFN01 REFRIGERATOR
Whirlpool 4ED25DQXFW00 REFRIGERATOR
Whirlpool 4ED25DQXFW01 REFRIGERATOR
Whirlpool 4ED25DQXVW00 Refrigerators*
Whirlpool 4ED25DQXVW01 Refrigerators*
  #2 (permalink)
Old 11-04-2013, 09:38 PM
Junior Member
Default Problem Solved!
So I've managed to stump the "Pro's" with a fairly routine problem, at least 79 of you at last count. Not even one "Pro" had any idea. So I'll tell you the solution. I repositioned the flame sensor and now the problem is gone. There you have it! That wasn't so hard was it? Even and amateur like me was able to figure this one out.
  #3 (permalink)
Old 12-04-2013, 08:51 PM
Junior Member
Gasguy3713 is on a distinguished road
Default
Try cleaning it as well. It is very simple. Just pull it out and rub it with some steel wool. These sensors produce micro amps and have very tight tolerances and while repositioning it may have worked for now in reality you probably only knocked some of the junk off. Cleaning this annually will ensure that it doesn't happen anymore
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
XLO Gas Burner Cutting Off After 5-7 Minutes jimwheel Oven Repair (including Ranges and Cooktops) 4 11-20-2012 04:44 AM
Startup issue llorton@gmail.com Microwave Repair 0 06-22-2011 12:07 PM
Startup sequence AJaco Dryer Repair 0 12-12-2010 02:54 PM
Kenmore Oven burner cutting out! Ripper Oven Repair (including Ranges and Cooktops) 2 08-20-2008 10:53 AM
Rattle on startup tillamook Dryer Repair 4 09-23-2007 06:01 PM
