Discuss
Central A/C not cooling
 in
Heating, Ventilation, and Air Conditioning (HVAC)
Its problem can be solved by full tuning of this machine, one or more times blower service can b also
Appliance Repair Forum > Appliance Repair Help > Heating, Ventilation, and Air Conditioning (HVAC) » Central A/C not cooling
  #11 (permalink)
Old 11-21-2015, 10:09 AM
Junior Member
HVACrepair is on a distinguished road
Default
Its problem can be solved by full tuning of this machine, one or more times blower service can b also give some more satisfaction. Its air pipes are also may be in odd state, those pipes would also be repairable.
  #12 (permalink)
Old 11-24-2015, 10:15 AM
Junior Member
Default
heating furnace repair
  #13 (permalink)
Old 11-24-2015, 11:14 AM
Junior Member
balperi is on a distinguished road
Default
interesting thread, I too was having the same problem
  #14 (permalink)
Old 01-05-2016, 02:33 AM
Junior Member
Patrick_Stevenson is on a distinguished road
Default
I strongly advise you not to DIY as if you do something that should not be done will cause more trouble than what you are already trying to fix. I suggest contacting any repair company such as Domestic Services and ask them to come have a look. Good luck with your AC repair.
  #15 (permalink)
Old 03-15-2018, 03:14 AM
Junior Member
tinasingh is on a distinguished road
Default
You have to try setting the thermostat fan switch to the "on" position. Feel for air coming out of the vents. If it is in the air conditioning mode, check for ice around the evaporator coil and on the refrigerant lines at the indoor unit. ... If the fan isn't working, that can cause the coil to freeze. I did same thing when i face same problem and take a help from air conditioner dealers.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Central Air isn't cooling Janielyn80 Heating, Ventilation, and Air Conditioning (HVAC) 6 05-23-2014 04:29 AM
Central AC Fan Speed stringed Heating, Ventilation, and Air Conditioning (HVAC) 0 06-12-2012 02:30 PM
help with a/c central system ronald871 Heating, Ventilation, and Air Conditioning (HVAC) 0 07-07-2010 10:24 PM
Central Heat won't come on candy2785 Heating, Ventilation, and Air Conditioning (HVAC) 2 01-08-2010 07:32 AM
