Discuss
NuTone Range Hood Vent Fan AA2M054F#
 in
Heating, Ventilation, and Air Conditioning (HVAC)
Hello, The vent fan in my NuTone range hood runs well on high-speed but takes about 5 minutes to get
Appliance Repair Forum > Appliance Repair Help > Heating, Ventilation, and Air Conditioning (HVAC) » NuTone Range Hood Vent Fan AA2M054F#
  #1 (permalink)
Old 04-23-2013, 02:04 PM
Junior Member
Paloco is on a distinguished road
Default NuTone Range Hood Vent Fan AA2M054F#
Brand: -other-   Age: More than 10 years
Hello,
The vent fan in my NuTone range hood runs well on high-speed but takes about 5 minutes to get up to the correct rpms on low speed. Troubleshooting efforts I have tried are oiling the fan motor and letting the fan run for 5-10 minutes on low setting to ensure that it is completely lubricated. Please advise.
NuTone Range Hood ID: V19D66W (the D may be an N)
Information on Fan Casing:
Model ID: AA2M054F#
RPM 1550; #21939; LR12645; 115v; cycle 60; amps .87;
serial # 12Z52126R
  #2 (permalink)
Old 04-23-2013, 05:19 PM
Senior Member
scott5495 is on a distinguished road
Default hood
on high, the fan motor recieves 120 volts. on low the voltage drops in order to slow the fan down. make sure the grease filter is clean and the damper is opening. sounds like a bad motor otherwise.
  #3 (permalink)
Old 04-23-2013, 06:56 PM
Junior Member
Default Response 1
Scott,
Thank you for your response. Please clarify what the grease filter is. There is a stainless steel filter--what I would call an air filter--which has been cleaned. Also, the damper does work--I can hear it open and close.
Please tell me if I can still obtain the same fan motor, or let me know of another that would work with my range hood's bracket holes. In addition, any other information that I may need to have in selecting a new motor--if that is the case--will be appreciated.
Paloco
  #4 (permalink)
Old 04-23-2013, 07:08 PM
Senior Member
Default hood
the air filter and grease filter are the same part. it is a lot easier to replace the fan motor with the original. get the model no. off the hood and call cashwells appliance parts at 1-800-277-1220. they can help on the part, original or replacement.
  #5 (permalink)
Old 04-23-2013, 07:14 PM
Junior Member
Default Response 2
Scott,
Thank you for your assistance and time. I appreciate it!
Paloco
  #6 (permalink)
Old 09-30-2013, 05:19 AM
Junior Member
MarcPierre is on a distinguished road
Default
I think your issue has been solved and the vent fan is working well. Can you please share the steps that you used to troubleshoot this problem?
__________________
broan range hoods
  #7 (permalink)
Old 09-30-2013, 12:19 PM
Junior Member
Default
I solved the issue by taking the fan motor to a local repair shop. They took it apart, cleaned, and lubricated it. It works just fine now. Just
goes to show that it is sometimes worth repairing things instead of
replacing them. I saved myself a great deal of money by doing so.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thermadore range hood vent fan Dan Ping Oven Repair (including Ranges and Cooktops) 0 09-07-2011 06:25 PM
range hood vent george ray Oven Repair (including Ranges and Cooktops) 0 08-26-2011 07:25 PM
Range Vent Hood captain513 Heating, Ventilation, and Air Conditioning (HVAC) 2 11-04-2010 12:33 PM
Range Vent Hood ICBEGOVIC Oven Repair (including Ranges and Cooktops) 0 08-15-2010 06:22 PM
Converting a Vent hood to non-vent recirculating mtcycle Heating, Ventilation, and Air Conditioning (HVAC) 0 02-09-2009 01:34 PM
