Discuss
Floor model gas furnace
 in
Heating, Ventilation, and Air Conditioning (HVAC)
My sister has a floor model gas furnace with a grate. Sporadically the furnace will not come on. Sometimes if
Appliance Repair Forum > Appliance Repair Help > Heating, Ventilation, and Air Conditioning (HVAC) » Floor model gas furnace
  #1 (permalink)
Old 03-22-2013, 10:38 AM
Member
pdl2 is on a distinguished road
Default Floor model gas furnace
Brand: -brand-   Age: 5 - 10 years
My sister has a floor model gas furnace with a grate. Sporadically the furnace will not come on. Sometimes if you mess around with the thermostat ( raise/lower setting ) it will come on. Works most of the time. Had the same problem around this time of the year last year. Then started working again. Worked all winter, until this past monday. However, it did start working again. Is it just as simple as the thermostat? Does power need to be off to the thermostat before it is change? I can get the make/model # later if need be. Where is the best place to look for the model #?
pdl2
  #2 (permalink)
Old 03-22-2013, 11:21 AM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
You can test the thermostat by jumping the two wires inside it.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 03-22-2013, 11:57 AM
Member
Default
Simon,
How do you do that ? How will I know if the test is good or not?
your probably tired of talking to me by now. Quick question on my refrigerator that was froze up and is now working: I unplugged the ice maker that we werent using to give us more space in the freezer. Just wanted to make sure there was not a problem with the open plug that the ice maker plugged into still being in the freezer.
thanks
pdl2
  #4 (permalink)
Old 03-22-2013, 05:54 PM
Expert
Default
Hi.
Open the thermostat, locate two wires and connect them together. If the furnace kicks on - the thermostat should be replaced.
If you mean the electrical plug for the icemaker being exposed I don't see any problem unless some one decide to plug themselves into it.
Simon.
__________________
  #5 (permalink)
Old 04-06-2013, 06:42 AM
Member
Default
Simon,
I had not bothered it since it was working. It went out again last night so i jumped the wires and it kicked on. On a two wire system, does it matter which wire goes where? they are both white and as far as i can tell they are not marked and neither is the old thermostat. Do I need to turn off the power? will it short out the new thermostat or furnace? I disconnected and reconnected the old one without turning off the power
  #6 (permalink)
Old 04-08-2013, 09:21 AM
Expert
Default
HI.
You can ether turn the power off or put some electrical tape on the wires.
Simon.
__________________
  #7 (permalink)
Old 04-08-2013, 11:47 AM
Member
Default
On the 2 wire system, does it matter which wire goes to thr "R" & "W" ?
Not sure the old thermostat is labled.
Thanks,
pdl2
  #8 (permalink)
Old 04-08-2013, 11:57 AM
Expert
Default
On the two wire system it doesn't matter.
Simon.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Ice collecting on freezer floor and water on floor under door hinge paddison51 Refrigerator & Freezer Repair 4 08-24-2013 03:05 PM
KitchenAid Model model# KSCS25FKSS01 icemaker problem jwagd07 Refrigerator & Freezer Repair 3 03-20-2013 01:00 PM
CARRIER Model 58SS furnace problems whsydddy9 Heating, Ventilation, and Air Conditioning (HVAC) 2 12-31-2010 09:45 AM
freezer leaks water on floor and freezes in floor bcarolan Refrigerator & Freezer Repair 10 04-04-2009 10:52 AM
LP converstion kit for open-box floor model marcse_ms Oven Repair (including Ranges and Cooktops) 3 10-22-2008 08:47 PM
