Discuss
furnace
 in
Heating, Ventilation, and Air Conditioning (HVAC)
The blower motor will start even if I have the thermostat turned off. I have even disconnected the thermostat at
Appliance Repair Forum > Appliance Repair Help > Heating, Ventilation, and Air Conditioning (HVAC) » furnace
  #1 (permalink)
Old 10-03-2009, 11:06 AM
Junior Member
roel is on a distinguished road
Default furnace
Model Number: cmpn100-4   Brand: Jenn-Air   Age: More than 10 years
The blower motor will start even if I have the thermostat turned off. I have even disconnected the thermostat at the furnace and the blower motor still will start. Sometimes it will run for a few minutes and sometimes it runs for less than one minute. It will sometimes start up every 30 seconds and run for a short time. I have heard that this model furnace has had trouble with the early circuit boards and this could be the problem. Does anyone have any information on this problem? Thank you
Ads By Google
Related Models
Maytag CMS130BCLWH  Freezer - Vertical
Maytag CMS180BCLWH  Freezer - Vertical
Maytag CMS210ACLWH Freezer - Vertical
Maytag CMS210ADLWH Freezer - Vertical
Maytag CMS210BCLWH Freezer - Vertical
Thermador CMT-127
Thermador CMT-131
Thermador CMT-18
Thermador CMT-19
Thermador CMT-19 SERVICE CODE H & UP
Thermador CMT-20
Thermador CMT-21
Thermador CMT-21 SERVICE CODE J & UP
Thermador CMT-227
Thermador CMT-231
Whirlpool CMT061SGW0
Whirlpool CMT101SGW0
Whirlpool CMT102SGW0
Thermador CMT127N-01
Whirlpool CMT135SGW0
Thermador CMT227N-01
Thermador CMT227W
Thermador CMT231-01 S/N 89110145 & UP
Maytag CMV1000ADA Mwave - Mounted Under Cabinet
Maytag CMV1000ADB Mwave - Mounted Under Cabinet
Maytag CMV1000ADW Mwave - Mounted Under Cabinet
Maytag CMV1000BAB Mwave - Mounted Under Cabinet
Maytag CMV1000BAQ Mwave - Mounted Under Cabinet
Maytag CMV1000BAW Mwave - Mounted Under Cabinet
Maytag CMV1000BDB Mwave - Mounted Under Cabinet
Maytag CMV1000BDQ Mwave - Mounted Under Cabinet
Maytag CMV1000BDW Mwave - Mounted Under Cabinet
Maytag CMV1100AAB Mwave - Mounted Under Cabinet
Maytag CMV1100AAQ Mwave - Mounted Under Cabinet
Maytag CMV1100AAW Mwave - Mounted Under Cabinet
Crosley CMW159PC Mwave - Cntrtp / Stand Alone
Crosley CMW22A2 Mwave - Cntrtp / Stand Alone
Crosley CMW22A6 Mwave - Cntrtp / Stand Alone
Crosley CMW419PD Mwave - Cntrtp / Stand Alone
Crosley CMW464G Mwave - Cntrtp / Stand Alone
Maytag CNDNS229J  Ref - SXS/I&W
Maytag CNDNS229JA  Ref - SXS/I&W
Maytag CNDNS229JH  Ref - SXS/I&W
Maytag CNDNS229K  Ref - SXS/I&W
Maytag CNDNS229KA  Ref - SXS/I&W
Maytag CNE200 Range - F/s Std Ele
Maytag CNE2000ACL Range - F/s Std Ele
Maytag CNE2000ACW Range - F/s Std Ele
Admiral CNEA100ACL Range - F/s Std Ele
Admiral CNEA100ACW Range - F/s Std Ele
Maytag CNG200 Range - F/s Std Gas
Maytag CNG201 Range - F/s Std Gas
Maytag CNG2010AAL Range - F/s Std Gas
Maytag CNG2010AAW Range - F/s Std Gas
Maytag CNG2010BAL Range - F/s Std Gas
Maytag CNG2010BAW Range - F/s Std Gas
Maytag CNNS208  Ref - Sxs
Maytag CNNS208H  Ref - Sxs
Norge CNNS208K Ref - Sxs
Norge CNNS208KA Ref - Sxs
Norge CNNS208KW Ref - Sxs
Maytag CNNT153L  Ref - Top Mount
Maytag CNNT153LA  Ref - Top Mount
Maytag CNNT156K  Ref - Top Mount
Maytag CNNT156KA  Ref - Top Mount
Maytag CNNT156KH  Ref - Top Mount
Maytag CNNT156KL  Ref - Top Mount
Norge CNNT174HL Ref - Top Mount
Norge CNNT174HLA Ref - Top Mount
Norge CNNT174HLH Ref - Top Mount
Maytag CNNT174K  Ref - Top Mount
Maytag CNNT174KA  Ref - Top Mount
Maytag CNNT174KL  Ref - Top Mount
Maytag CNNT174KLA  Ref - Top Mount
Norge CNNT178BV Ref - Top Mount
Norge CNNT178BVA Ref - Top Mount
Norge CNNT178BVH Ref - Top Mount
Maytag CNNT198GA  Ref - Top Mount
Maytag CNNT198GH  Ref - Top Mount
Maytag CNNT198GL Ref - Top Mount
Maytag CNNT198GLA  Ref - Top Mount
Maytag CNNT198GLH  Ref - Top Mount
Maytag CNNT198GLN Ref - Top Mount
Maytag CNNT198GN  Ref - Top Mount
Maytag CNNT198K  Ref - Top Mount
Maytag CNNT198KA  Ref - Top Mount
Maytag CNNT198KL  Ref - Top Mount
Maytag CNNT198KLA  Ref - Top Mount
Crosley CNNT218BV Ref - Top Mount
Crosley CNNT218BVA Ref - Top Mount
Crosley CNNT218BVH Ref - Top Mount
Maytag CNP200 Range - F/s Std Gas
Maytag CNP201 Range - F/s Std Gas
Maytag CNP2010AXL Range - F/s Std Gas
Maytag CNP2010AXW Range - F/s Std Gas
Maytag CNP2010BXL Range - F/s Std Gas
Maytag CNP2010BXW Range - F/s Std Gas
Admiral CNPA100AXL Range - F/s Std Gas
Admiral CNPA100AXW Range - F/s Std Gas
Crosley CNS20M4 Ref - Sxs
Crosley CNS20M4A Ref - Sxs
Crosley CNS20M4H Ref - Sxs
Crosley CNS20M6 Ref - Sxs
Crosley CNS20M6A Ref - Sxs
Crosley CNS20M6H Ref - Sxs
  #2 (permalink)
Old 10-05-2009, 08:28 PM
Senior Expert
APP Volunteer
SublimeMasterJW is on a distinguished road
Default
Wow a furnace with a mind of it's own. LOL You never hear much about Jenn Air central unit I don't think it is a wide spread problem. You need to check for a stack pipe rain leak dripping on or near that board.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Furnace Issues ssyba Heating, Ventilation, and Air Conditioning (HVAC) 7 05-14-2010 11:27 AM
furnace no heat rleescott Heating, Ventilation, and Air Conditioning (HVAC) 5 01-24-2010 10:10 AM
Amana Gas Furnace Ouiserm Heating, Ventilation, and Air Conditioning (HVAC) 2 11-29-2009 09:51 AM
Furnace won't turn on mgoblue Heating, Ventilation, and Air Conditioning (HVAC) 1 02-15-2009 04:13 PM
furnace no heat amati5 Heating, Ventilation, and Air Conditioning (HVAC) 0 11-28-2007 01:46 PM
