Discuss
Williams wall heater problems
 in
Heating, Ventilation, and Air Conditioning (HVAC)
I recently purchased a cabin that has a Wiliams wall heater as a heat source. When I leave the cabin
Appliance Repair Forum > Appliance Repair Help > Heating, Ventilation, and Air Conditioning (HVAC) » Williams wall heater problems
  #1 (permalink)
Old 03-05-2013, 11:39 AM
Junior Member
reynja is on a distinguished road
Default Williams wall heater problems
Model Number: 2509621   Brand: -other-   Age: 1 - 5 years
I recently purchased a cabin that has a Wiliams wall heater as a heat source. When I leave the cabin after a weekend, I set the thermostat at 50 degrees. The last two times I have returned to the cabin, the temperature has been near 30 degrees, and the heater is not running. When I turn up the thermostat, the heater fires up and works fine all weekend, but I do notice that the blower fan takes about 10 minutes to start after the heater has started. I would think that the blower fan should start within 1-2 minutes after the heater starts. There is a reset button located on the upper left side of the heater, near the fan, and I am wondering if this is a high temperature switch that is tripping the heater offline because the fan is slow to start and the heater gets too hot.
Can someone offer suggestions on how to diagnose this problem, and explain the function of the reset button?
Thanks!
Ads By Google
Related Models
Frigidaire 2509A GAS RANGE
Jenn-Air 2513 SURFACE UNIT- ELE
Jenn-Air 2514 SURFACE UNIT- ELE
Jenn-Air 2514A SURFACE UNIT- ELE
Jenn-Air 2514B SURFACE UNIT- ELE
Jenn-Air 2515 SURFACE UNIT- ELE
Hardwick 2519 GAS RANGE
Roper 2521B00 Ranges, Electric*
Roper 2521B10 Ranges, Electric*
Roper 2521W00 Ranges, Electric*
Hardwick 2522A GAS RANGE
Frigidaire 2530A GAS RANGE
Frigidaire 2530B GAS RANGE
Frigidaire 2530C GAS RANGE
Frigidaire 2530D GAS RANGE
Frigidaire 2530E GAS RANGE
Kenmore 25310301000 CHEST FREEZER
Kenmore 25310301001 CHEST FREEZER
Kenmore 25310311000 CHEST FREEZER
Kenmore 25310311001 CHEST FREEZER
Kenmore 25310311002 FREEZER
Kenmore 25310911990 FREEZER
Kenmore 25310911991 CHEST FREEZER
Kenmore 25310911992 CHEST FREEZER
Kenmore 25311301100 FREEZER
Kenmore 25311301101 FREEZER
Kenmore 25311311100 CHEST FREEZER
Kenmore 25311312100 FREEZER
Kenmore 25311312101 FREEZER
Kenmore 25311312102 SEARS/FREEZER
Kenmore 25311321100 CHEST FREEZER
Kenmore 25311321101 FREEZER
Kenmore 25311351100 FREEZER
Kenmore 25311351101 CHEST FREEZER
Kenmore 25311351102 FREEZER
Kenmore 25311511100 CHEST FREEZER
Kenmore 25311511101 FREEZER
Kenmore 25311521100 FREEZER
Kenmore 25311521102 CHEST FREEZER
Kenmore 25311521103 FREEZER
Kenmore 25311531100 FREEZER
Kenmore 25311531101 FREEZER
Kenmore 25311531102 FREEZER
Kenmore 25311531103 FREEZER
Kenmore 25311541100 CHEST FREEZER
Kenmore 25311541102 FREEZER
Kenmore 25311711100 FREEZER
Kenmore 25311711101 CHEST FREEZER
Kenmore 25311711102 FREEZER
Kenmore 25311821100 FREEZER
Kenmore 25311821101 FREEZER
Kenmore 25311911100 FREEZER
Kenmore 25311911101 FREEZER
Kenmore 25312021100 FREEZER
Kenmore 25312021101 FREEZER
Kenmore 25312021102 FREEZER
Kenmore 25312541100 FREEZER
Kenmore 25312541102 SEARS/FREEZER
Kenmore 25312551100 FREEZER
Kenmore 25313009100 FREEZER
Kenmore 25313051100 FREEZER
Kenmore 25313051101 FREEZER
Kenmore 25313051102 FREEZER
Kenmore 25313051103 FREEZER
Kenmore 25313312101 FREEZER
Kenmore 25313351100 FREEZER
Kenmore 25313500100 FREEZER
Kenmore 25313500101 FREEZER
Kenmore 25313500102 FREEZER
Kenmore 25313500103 FREEZER
Kenmore 25313511100 CHEST FREEZER
Kenmore 25313511101 FREEZER
Kenmore 25313511102 FREEZER
Kenmore 25313541101 FREEZER
Kenmore 25313541102 FREEZER
Kenmore 25313551100 FREEZER
Kenmore 25313551101 FREEZER
Kenmore 25313711100 FREEZER
Kenmore 25313711101 FREEZER
Kenmore 25313711102 FREEZER
Kenmore 25313712100 FREEZER
Kenmore 25313712101 FREEZER
Kenmore 25313911100 FREEZER
Kenmore 25313911101 FREEZER
Kenmore 25313911102 FREEZER
Kenmore 25314092101 FREEZER
Kenmore 25314092102 FREEZER
Kenmore 25314092103 FREEZER
Kenmore 25314342100 FREEZER
Kenmore 25314342101 FREEZER
Kenmore 25314342102 FREEZER
Kenmore 25314352100 FREEZER
Kenmore 25314352101 FREEZER
Kenmore 25314352102 FREEZER
Kenmore 25314502100 FREEZER
Kenmore 25314502101 FREEZER
Kenmore 25314502102 FREEZER
Kenmore 25314502103 FREEZER
Kenmore 25314502104 FREEZER
Kenmore 25314502105 FREEZER
Kenmore 25314512100 FREEZER
Kenmore 25314512101 FREEZER
Kenmore 25314512102 FREEZER
Kenmore 25314512103 FREEZER
Kenmore 25314512104 FREEZER
Kenmore 25314542100 FREEZER
Kenmore 25314542101 FREEZER
Kenmore 25314542102 FREEZER
Kenmore 25314542103 FREEZER
Kenmore 25314542104 FREEZER
Kenmore 25314542105 FREEZER
Kenmore 25314552100 FREEZER
Kenmore 25314552101 FREEZER
Kenmore 25314552102 FREEZER
Kenmore 25314582100 FREEZER
Kenmore 25314592100 FREEZER
Kenmore 25314592101 FREEZER
Kenmore 25314592102 FREEZER
Kenmore 25314702100 FREEZER
Kenmore 25314702101 FREEZER
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Wall Heater Keeps Turning Off runesgirl Heating, Ventilation, and Air Conditioning (HVAC) 4 03-10-2012 10:30 AM
wall/floor heater johnny wen Heating, Ventilation, and Air Conditioning (HVAC) 1 12-17-2011 12:24 AM
Thermador Wall heater WTF Heating, Ventilation, and Air Conditioning (HVAC) 0 12-04-2010 11:13 AM
Wall Heater wardic2 Heating, Ventilation, and Air Conditioning (HVAC) 0 11-23-2010 10:31 AM
Electric Wall Heater jtesta6015 Heating, Ventilation, and Air Conditioning (HVAC) 1 02-06-2010 06:16 PM
