Appliance Repair Forum
-   Heating, Ventilation, and Air Conditioning (HVAC) (http://forum.appliancepartspros.com/heating-ventilation-air-conditioning-hvac/)
-   -   Heating Parts (http://forum.appliancepartspros.com/heating-ventilation-air-conditioning-hvac/5151-heating-parts.html)
Admin / APP Team 02-03-2008 04:31 PM
Heating Parts
Heating parts such as replacement gas valves, ignitors, and ignition modules can be found here - heating parts.
byarst 10-31-2013 09:08 PM
Quote:
need replacement or mng. part for mod.#fav18ej2a1 unit it has bad sel. switch the mng.# is 5308017262 switch is rated 6amp 1/4hp 120/240 and 21amp 120/240 with total rating of 25fla 90lra 240 volt
donaldharris 03-05-2017 10:00 PM
Need replacement for gas valve. Please help!
RickyTerzis 08-17-2017 10:17 AM
Hi..in my case e clock started blinking and I noticed none of the burners were getting hot and the display stopped working unless I had one of the burner switches on. So now none of the burners heat at all, the oven doesn't heat at all and the display only displays if I have a burner switch turned on??
