Discuss
can a 30 yr old heater be fixed?
 in
Heating, Ventilation, and Air Conditioning (HVAC)
i have a trane forced hot air system. not sure of the model number tbh. but a specialist just came
Appliance Repair Forum > Appliance Repair Help > Heating, Ventilation, and Air Conditioning (HVAC) » can a 30 yr old heater be fixed?
  #1 (permalink)
Old 11-01-2012, 04:59 PM
Junior Member
ghostdragon is on a distinguished road
Default can a 30 yr old heater be fixed?
Brand: -other-   Age: More than 10 years
i have a trane forced hot air system. not sure of the model number tbh. but a specialist just came by... couldnt help me.. he found there to be an electrical fault.. that the output was too low. it was relaying 1/2 the output it should be. the fan works fine.. i never have any issues with it cooling in the summer. but no heat. i dont want to have to pay $5800 for a new furnace at the moment. do you think an electrician can fix this?
Ads By Google
  #2 (permalink)
Old 11-02-2012, 03:31 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
A model number may be helpful especially if you need parts so try to find the plate.
You said "specialist" but I do not know what you mean by that.
" he found there to be an electrical fault.. that the output was too low. it was relaying 1/2 the output it should be. the fan works fine."
I am assuming that this is an electric furnace.
Also that the unit is only getting 120 volts instead of the required 240 volts.
In other words you are missing half the line.
I do not know what this specialist did.
Did they use a meter to check the voltage?
Did they flip the breaker for the unit off/on slowly a couple times. This should be a double breaker.
If your house panel uses fuses did they check the fuses.
Did they disconnect the furnace and check that the line was still no good.
If the unit is only getting 120 volts to it then an electrician should be able to fix it.
Note: There may be something in the furnace that is blowing half the line and I do not know if your specialist checked for this.
__________________
Reply
« Pilot | PTAC Issue »
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Problem fixed. Laura Taylor Refrigerator & Freezer Repair 0 03-11-2012 10:39 AM
n/m fixed skeeter Refrigerator & Freezer Repair 0 03-04-2011 03:24 AM
Should it be fixed? scotty tagfixer Refrigerator & Freezer Repair 15 11-24-2010 04:19 PM
Almost Fixed ! Jack-99 Washer Repair 1 10-25-2009 11:55 AM
I think I fixed it? Dremert Refrigerator & Freezer Repair 4 05-30-2009 12:14 PM
