Discuss
Pilot
 in
Heating, Ventilation, and Air Conditioning (HVAC)
Magic Chef Furnace - probably 1983 model in attic. When heat shut down, will not restart because pilot has gone
Appliance Repair Forum > Appliance Repair Help > Heating, Ventilation, and Air Conditioning (HVAC) » Pilot
  #1 (permalink)
Old 10-30-2012, 03:37 PM
Junior Member
ferris75 is on a distinguished road
Smile Pilot
Brand: Magic Chef   Age: More than 10 years
Magic Chef Furnace - probably 1983 model in attic. When heat shut down, will not restart because pilot has gone out. Reset Pilot and works fine until heat shut down. Tired of lighting pilot. What is it?
  #2 (permalink)
Old 11-01-2012, 03:55 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
I have no tech info on this unit and probably will not be able to find any even with a model number.
At the top of my list would be the thermocouple.
Remove it at the gas valve and check/clean that end.
Also look inside the valve where it connects to be sure that the connection in the valve is clean, sometimes they get a light brown or grey coating. If dirty clean it with a small piece of sandpaper or emery cloth. Be gentle.
If it looks clean, I would replace it
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
gas FP pilot terrence l. thomas Heating, Ventilation, and Air Conditioning (HVAC) 1 01-22-2011 09:29 AM
pilot OK but no gas JoannOmar Dryer Repair 1 10-18-2010 05:14 PM
pilot light keeps going out lillithree Heating, Ventilation, and Air Conditioning (HVAC) 1 03-23-2009 06:03 PM
pilot light? kari Oven Repair (including Ranges and Cooktops) 1 12-15-2008 06:28 PM
pilot out toddcarter19 Oven Repair (including Ranges and Cooktops) 1 02-14-2008 03:43 PM
