| » kenmore ac/heater won't heat |
Model Number: 58072187300 Brand: Kenmore Age: 1 - 5 years
I turned on my heater for the 1st time and it only blows cold air on the heat setting.Could it be the electric heater assembly?
Is your heater brand new or has been stocked for long time or haven't been used for long? The problems can be defective heater valve, defective blower motor, weaker water pump and an open thermostat. Furnaces that are electronic based like from Air cond. Bell canyon have heating coils that can be clooged or defective blower motor.
Quote:
Parts for Kenmore Air Conditioner 58072187300 - AppliancePartsPros.com If you go to the Sears parts site they have actual part breakdown diagram. Unfortunately AppliancePartsPros does not have access to these. Yes it could be the heater assembly. Below is the heater. You will notice a thermostat mounted at the bottom. This should be 0 ohms at room temperature. I could not find any tech specs on the unit so cannot say for sure what the heater resistance should be. I think it will be around 20 to 30 ohms. Part number: AP4439760 The unit is made by LG ans I cannot get a wiring diagram so have to do some guessing. I am guessing that the air conditioner rune off of 120 volts while the heater runs off of the full 240 volts so I would check the power to the unit first. Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker. Check the voltage at the plug L1 to L2 should be 240 volts L1 to Neutral and L2 to Neutral, both should be 120 volts. If OK Unplug the unit and check the wires at the terminal strip in the machine to make sure none are loose or burned out If OK Check the power at the terminal strip if it has one. Do this with the heater off and on. Be careful as 240 volts is lethal !!!
__________________
| Display Modes | |
| Replaced defrost heater--no heat | curtis lowe | Refrigerator & Freezer Repair | 2 | 01-18-2011 04:02 PM |
| heater coil won't heat | slope12 | Dryer Repair | 1 | 12-16-2010 03:17 AM |
| no heat and all thermastats and heater are good | sloefoot25 | Dryer Repair | 1 | 03-25-2010 02:03 PM |
| new heater but wont heat up | bri_w_4 | Dryer Repair | 0 | 01-14-2008 03:19 PM |
| Gas TANKLESS WATER HEATER no heat | Eddy | General Talk | 2 | 08-04-2007 05:54 PM |
