Discuss
Amcor A/C Window Unit- dripping a lot
 in
Heating, Ventilation, and Air Conditioning (HVAC)
I have an older Amcor Window A/C unit and it is dripping a ton of water out the back. These
Appliance Repair Forum > Appliance Repair Help > Heating, Ventilation, and Air Conditioning (HVAC) » Amcor A/C Window Unit- dripping a lot
  #1 (permalink)
Old 09-11-2012, 05:03 PM
Junior Member
Larbo is on a distinguished road
Default Amcor A/C Window Unit- dripping a lot
Brand: -brand-   Age: More than 10 years
I have an older Amcor Window A/C unit and it is dripping a ton of water out the back. These window units have "slingers" that are supposed to collect the condensate and evaporate it by "slinging it" into the condenser hot coils. However, the slinger system (which is the actual condenser fan blade), is not working right. The little pan under the blade has no water in it and all the water seems to be collecting instead on the bottom of the unit and dripping out the back. The evaporator section has a 4" clear tube that empties the condensate onto the bottom of the unit and not into the condensor area.
Otherwide, it cools like a Nor-Easter!
This used to work. I am sure that every unit is different and I am hoping the someone knows Amcors sees this and understands what on earth I am talking about.
Thanks, Lar
Ads By Google
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
ac window unit rsriedman Heating, Ventilation, and Air Conditioning (HVAC) 2 08-08-2010 08:46 PM
AC-window unit makatamiba Heating, Ventilation, and Air Conditioning (HVAC) 0 06-17-2009 01:30 PM
Ge Window A/c Unit MOELLER4@CTC.NET Heating, Ventilation, and Air Conditioning (HVAC) 0 09-19-2008 08:16 AM
28,000 btu window a/c unit David Hendley Heating, Ventilation, and Air Conditioning (HVAC) 0 07-21-2008 10:40 AM
ac window unit trae southard Heating, Ventilation, and Air Conditioning (HVAC) 0 08-10-2007 01:33 PM
