Discuss
Bad Induction motor, or jus sensor
 in
Heating, Ventilation, and Air Conditioning (HVAC)
Looking for some advise. The furnace stopped working in the following way. It got cold, so I turned the heat
Appliance Repair Forum > Appliance Repair Help > Heating, Ventilation, and Air Conditioning (HVAC) » Bad Induction motor, or jus sensor
  #1 (permalink)
Old 01-29-2008, 01:44 PM
skrobers skrobers is offline
Junior Member
skrobers is on a distinguished road
Default Bad Induction motor, or jus sensor
Model Number: GCIC070CX40   Brand: Amana   Age: 5 - 10 years
Looking for some advise. The furnace stopped working in the following way. It got cold, so I turned the heat on. In looking at the furnace, there was a delay of around 7 minutes before the induction motor kicked on and the glow plug started to glow. The furnace would then ignite, but within 5 - 20 seconds, the induction sensor relay would click and the flame would go out. It would then try to re - light with the same results until I turn the furnace off. I did find that while the furnace was trying to stay on, if I unhooked the connectors to the induction sensor relay, and shorted them out, that the furnace would run for as long as I had the connection shorted. When I hooked the sensor back up, it went back to to the same on/off/on/off symptom....
My question is, what is failing. Is it a bad induction sensor, or is it possible that the induction motor is failing causing the sensor to turn off?
Related Models
Whirlpool GCJC3655RS00 36" Electric Built - in Ceran Cooktop
Whirlpool GCJC3655RS01 36" Electric Built - in Ceran Cooktop
Whirlpool GCJC3655RS02 36" Electric Built - in Ceran Cooktop
General Electric GCK21LEMAFCC Refrigerator
General Electric GCK21LENCFCC Refrigerator
General Electric GCK23LASAFCC Refrigerator
General Electric GCK23LASBFCC Refrigerator
General Electric GCK23LCMAFCC Refrigerator
General Electric GCK23LCNCFCC Refrigerator
General Electric GCL22KGRESV Refrigerator
General Electric GCL22QGTASV Refrigerator
Maytag GCLE700 Range - Std Mwave Ele
Maytag GCLE750 Range - Std Mwave Ele
Maytag GCLG600 Range - Std Mwave Gas
Maytag GCLG601 Range - Std Mwave Gas
Maytag GCNE200 Range - F/s Std Ele
Maytag GCNG200 Range - F/s Std Gas
Maytag GCNP200 Range - F/s Std Gas
General Electric GCR23UDPCWW Refrigerator
General Electric GCR23UDPDWW Refrigerator
General Electric GCR23YLRBWW Refrigerator
General Electric GCR23YLRCWW Refrigerator
General Electric GCR23YLRDWW Refrigerator
Thermador GCR36-4GD
Thermador GCR36-4GL
Thermador GCR36-6
Thermador GCR484GD
Thermador GCR486GD
Maytag GCRE200 Range - F/s Std Ele
Maytag GCRE300 Range - F/s Std Ele
Maytag GCRE350 Range - F/s Std Ele
Maytag GCRE400 Range - F/s Std Ele
Maytag GCRE600 Range - F/s Std Ele
Maytag GCRE650 Range - F/s Std Ele
Maytag GCRE682 Range - S/c F/s Ele
Maytag GCRE700 Range - S/c F/s Ele
Maytag GCRE750 Range - S/c F/s Ele
Maytag GCRE800 Range - S/c F/s Ele
Maytag GCRG200 Range - F/s Std Gas
Maytag GCRG300 Range - F/s Std Gas
Thermador GCRG304
Maytag GCRG350 Range - F/s Std Gas
Thermador GCRG364GD
Thermador GCRG364GL
Thermador GCRG366
Maytag GCRG382 Range - F/s Std Gas
Maytag GCRG400 Range - F/s Std Gas
Maytag GCRG500 Range - F/s Std Gas
Maytag GCRG501 Range - F/s Std Gas
Maytag GCRG501B Range - F/s Std Gas
Maytag GCRG502 Range - F/s Std Gas
Maytag GCRG600 Range - F/s Std Gas
Maytag GCRG601 Range - F/s Std Gas
Maytag GCRG602 Range - F/s Cont Clean Gas
Maytag GCRG700 Range - S/c F/s Gas
Maytag GCRG750 Range - S/c F/s Gas
Maytag GCRG800 Range - S/c F/s Gas
Maytag GCRP200 Range - F/s Std Gas
Maytag GCRP300 Range - F/s Std Gas
Maytag GCRP382 Range - F/s Std Gas
Amana GCS120 Misc / Accessory
Amana GCSAND-7D.A Commercial Microwaves
Amana GCSAND7D Commercial Microwaves
Amana GCSAND7DRR Commercial Microwaves
Menu Master GCSAND7DRR  Commercial Microwaves
Amana GCSAND8LW Commercial Microwaves
Menu Master GCSAND8LW  Commercial Microwaves
Maytag GCSE600 Surface Unit - Ele
Maytag GCSG500 Surface Unit - Gas
General Electric GCSR2090H0WW Washer
General Electric GCSR2090H2WW Washer
Thermador GCT24GD
Thermador GCT24GL
Thermador GCT24W
Thermador GCT364G
Thermador GCT484GG
Thermador GCT486G
General Electric GCU21LGTAFBB Refrigerator
General Electric GCU21LGTAFSS Refrigerator
General Electric GCU21YESAFBB Refrigerator
General Electric GCU21YESAFSS Refrigerator
General Electric GCU21YETBFSS Refrigerator
General Electric GCU23MITAFBB Refrigerator
Thermador GCV36
Thermador GCV36G
Whirlpool GD22DCXHB00
Whirlpool GD22DCXHB01
Whirlpool GD22DCXHB02
Whirlpool GD22DCXHS00
Whirlpool GD22DCXHS01
Whirlpool GD22DCXHS02
Whirlpool GD22DCXHT00
Whirlpool GD22DCXHT01
Whirlpool GD22DCXHT02
Whirlpool GD22DCXHW00
Whirlpool GD22DCXHW01
Whirlpool GD22DCXHW02
Whirlpool GD22DFXFB00
Whirlpool GD22DFXFB01
Whirlpool GD22DFXFB02
Whirlpool GD22DFXFB03
Whirlpool GD22DFXFB04
Whirlpool GD22DFXFN00
Whirlpool GD22DFXFN01
Whirlpool GD22DFXFN02
Whirlpool GD22DFXFN03
Whirlpool GD22DFXFN04
Whirlpool GD22DFXFT02
Whirlpool GD22DFXFT03
Whirlpool GD22DFXFT04
Whirlpool GD22DFXFW00
Whirlpool GD22DFXFW01
Whirlpool GD22DFXFW02
Whirlpool GD22DFXFW03
Whirlpool GD22DFXFW04
Whirlpool GD22DKXFW00
Whirlpool GD22DKXFW01
Whirlpool GD22DKXHW00
  #2 (permalink)
Old 01-29-2008, 07:33 PM
#1 tech #1 tech is offline
Junior Member
#1 tech is on a distinguished road
Default
It is not the motor or the pressure switch. It sounds like its in the gas valve circuit. I belive it is timeing out when it does not prove flame. Do you have a meter? Check and see if you are getting 24V across the gas valve. It will happen after the ignitor fires. If so ohm out the gas valve if it is open then it's bad. If you do not have 24V at the valve back step to the board/relay and find the open switch. Remember rollout and high limit switches are there for a reason.
Last edited by #1 tech : 01-29-2008 at 09:05 PM. Reason: outside chance i could get more info
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
heat sensor bad? karaokemom@tds.net Oven Repair (including Ranges and Cooktops) 0 01-07-2008 07:44 PM
Sensor Dry Mode drew Dryer Repair 1 12-13-2007 08:32 PM
Where is moisture sensor? brian44 Dishwasher Repair 1 12-13-2007 05:59 PM
Location of sensor? Gil Dishwasher Repair 3 11-29-2007 09:38 AM
Sensor Pad Duke Dryer Repair 0 10-06-2007 10:41 AM
