Discuss
Bad Induction motor, or jus sensor
 in
Heating, Ventilation, and Air Conditioning (HVAC)
Looking for some advise. The furnace stopped working in the following way. It got cold, so I turned the heat
Appliance Repair Forum > Appliance Repair Help > Heating, Ventilation, and Air Conditioning (HVAC) » Bad Induction motor, or jus sensor
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 01-29-2008, 12:44 PM
skrobers skrobers is offline
Junior Member
skrobers is on a distinguished road
Default Bad Induction motor, or jus sensor
Model Number: GCIC070CX40   Brand: Amana   Age: 5 - 10 years
Looking for some advise. The furnace stopped working in the following way. It got cold, so I turned the heat on. In looking at the furnace, there was a delay of around 7 minutes before the induction motor kicked on and the glow plug started to glow. The furnace would then ignite, but within 5 - 20 seconds, the induction sensor relay would click and the flame would go out. It would then try to re - light with the same results until I turn the furnace off. I did find that while the furnace was trying to stay on, if I unhooked the connectors to the induction sensor relay, and shorted them out, that the furnace would run for as long as I had the connection shorted. When I hooked the sensor back up, it went back to to the same on/off/on/off symptom....
My question is, what is failing. Is it a bad induction sensor, or is it possible that the induction motor is failing causing the sensor to turn off?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-29-2008, 06:33 PM
#1 tech #1 tech is offline
Junior Member
#1 tech is on a distinguished road
Default
It is not the motor or the pressure switch. It sounds like its in the gas valve circuit. I belive it is timeing out when it does not prove flame. Do you have a meter? Check and see if you are getting 24V across the gas valve. It will happen after the ignitor fires. If so ohm out the gas valve if it is open then it's bad. If you do not have 24V at the valve back step to the board/relay and find the open switch. Remember rollout and high limit switches are there for a reason.
Last edited by #1 tech : 01-29-2008 at 08:05 PM. Reason: outside chance i could get more info
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
heat sensor bad? karaokemom@tds.net Oven Repair (including Ranges and Cooktops) 0 01-07-2008 06:44 PM
Sensor Dry Mode drew Dryer Repair 1 12-13-2007 07:32 PM
Where is moisture sensor? brian44 Dishwasher Repair 1 12-13-2007 04:59 PM
Location of sensor? Gil Dishwasher Repair 3 11-29-2007 08:38 AM
Sensor Pad Duke Dryer Repair 0 10-06-2007 09:41 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
