Discuss
LG Window AC, compressor runs non-stop
 in
Heating, Ventilation, and Air Conditioning (HVAC)
Window AC unit, if plugged in and the display NOT powered on, the compressor runs. Turn the display on and
Appliance Repair Forum > Appliance Repair Help > Heating, Ventilation, and Air Conditioning (HVAC) » LG Window AC, compressor runs non-stop
  #1 (permalink)
Old 08-14-2012, 11:58 AM
Junior Member
Brian Mc is on a distinguished road
Default LG Window AC, compressor runs non-stop
Model Number: LW1211ER   Brand: -other-   Age: 1 - 5 years
Window AC unit, if plugged in and the display NOT powered on, the compressor runs. Turn the display on and the compressor runs all the time in "cool" with the fan running the whole time. Fan turns on and off, but the compressor runs continuous if in "energy saver", and the compressor runs (and thus cools) if put into Fan mode. It was intermittent, only occurring in "cool" setting at first and if we unplugged the unit for 10+ hours it would then work correctly for a couple of days before failing again. Then we switched from leaving it on "cool" at night (for the noise of the fan to help sleep) to "energy saver" and it worked like that for a couple weeks until the compressor would stay on all the time.
Unit was 1 year, 2 weeks old when this started (and we woke up to a 60* room inside while it was in the 80's outside.. brrrrr ). Since the unit was/is under warranty, I called to have it fixed.
It's now 7 weeks later after waiting on Multiple companies to inspect, then return and fix (no one would ever return, not even a phone call follow-up), we finally had a tech take some pity on us and provide some real info. Parts are covered by warranty, but not labor ~ which is estimated over the cost of a new unit. This tech felt it was the 2 main control boards in the unit:
LG 6871A20418A Pwb(pcb) Assm., Disp., AP4440990 | AppliancePartsPros.com
LG EBR39283902 Pcb Assembly,main, AP4446870 | AppliancePartsPros.com
A previous tech mentioned in a round-about way that it might be on the 2nd of those 2. The display works just fine, though I have no clue what's controlled by which board. While we WILL replace both if needed (or this isn't answered definitively), being in a family with only one part time job supporting us, less money spent means less belt-tightening this month.
Also, does anyone have a link to how this unit comes apart? I'm fairly handy and will figure it out on my own, but it might mean the difference between me learning on the fly and taking 4~5 hours, or getting it completely swapped in 1 hour.
Thank you in advance for reading and/or helping.
Brian
Ads By Google
Related Models
Amana LW1501 Washer - Top Loading
Amana LW1502 Washer - Top Loading
Amana LW1503 Washer - Top Loading
Amana LW2001W Washer - Top Loading
Amana LW2001W2 Washer - Top Loading
Amana LW2201G Washer - Top Loading
Amana LW2201L Washer - Top Loading
Amana LW2201W Washer - Top Loading
Amana LW2300 Washer - Top Loading
Amana LW2302 Washer - Top Loading
Amana LW2303 Washer - Top Loading
Amana LW2400 Washer - Top Loading
Amana LW2402 Washer - Top Loading
Amana LW2403 Washer - Top Loading
Amana LW2500 Washer - Top Loading
Amana LW2501G Washer - Top Loading
Amana LW2501L Washer - Top Loading
Amana LW2501L2 Washer - Top Loading
Amana LW2501W Washer - Top Loading
Amana LW2501W2 Washer - Top Loading
Amana LW2502G Washer - Top Loading
Amana LW2502L Washer - Top Loading
Amana LW2502W Washer - Top Loading
Amana LW2503G Washer - Top Loading
Amana LW2503L Washer - Top Loading
Amana LW2503W Washer - Top Loading
Amana LW2600 Washer - Top Loading
Amana LW2602 Washer - Top Loading
Amana LW2603 Washer - Top Loading
Amana LW2800 Washer - Top Loading
Amana LW2802 Washer - Top Loading
Amana LW2900 Washer - Top Loading
Amana LW2902 Washer - Top Loading
Amana LW2903 Washer - Top Loading
Amana LW3302G Washer - Top Loading
Amana LW3302L Washer - Top Loading
Amana LW3302W Washer - Top Loading
Amana LW3303G Washer - Top Loading
Amana LW3303L Washer - Top Loading
Amana LW3303W Washer - Top Loading
Amana LW3403G Washer - Top Loading
Amana LW3403L Washer - Top Loading
Amana LW3403W Washer - Top Loading
Amana LW3502L Washer - Top Loading
Amana LW3502L2 Washer - Top Loading
Amana LW3502W Washer - Top Loading
Amana LW3502W2 Washer - Top Loading
Amana LW3503L Washer - Top Loading
Amana LW3503L2 Washer - Top Loading
Amana LW3503W Washer - Top Loading
Amana LW3503W2 Washer - Top Loading
Amana LW3603 Washer - Top Loading
Amana LW3603L Washer - Top Loading
Amana LW3603W Washer - Top Loading
Amana LW3903 Washer - Top Loading
Amana LW3903L Washer - Top Loading
Amana LW3903W Washer - Top Loading
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Haier Window A/C compressor not working like it should kansas_dude Heating, Ventilation, and Air Conditioning (HVAC) 0 07-10-2011 02:04 PM
Window Air Conditioner compressor help??? SevillianSTS Heating, Ventilation, and Air Conditioning (HVAC) 2 12-14-2009 10:35 PM
A/C window unit compressor always on zygote7 Heating, Ventilation, and Air Conditioning (HVAC) 1 04-26-2009 05:12 PM
window A/C Compressor won't engage all the time. aqpmedic Heating, Ventilation, and Air Conditioning (HVAC) 4 07-30-2008 08:24 PM
Window a/c compressor noise Justinjt Heating, Ventilation, and Air Conditioning (HVAC) 0 07-29-2008 11:05 PM
