Discuss
Central Air Wiring Question
 in
Heating, Ventilation, and Air Conditioning (HVAC)
I need to re-wire the control wire from my thermostat to my central AC unit. Taking a look in the
Appliance Repair Forum > Appliance Repair Help > Heating, Ventilation, and Air Conditioning (HVAC) » Central Air Wiring Question
  #1 (permalink)
Old 07-27-2012, 05:29 PM
Junior Member
splumer is on a distinguished road
Default Central Air Wiring Question
Model Number: 1f80-51   Brand: -other-   Age: 5 - 10 years
I need to re-wire the control wire from my thermostat to my central AC unit. Taking a look in the manual, it shows the diagram which wire goes where, but on each of the three main wires it has a box. The boxes are labelled "Cooling system," "Fan relay" and "Heating system." Does that mean the wire should go through those systems before going to the transformer? I attached the wiring diagram for reference. Thermo is a White-Rodgers 1f80-51.
Ads By Google
Related Models
Whirlpool 1LE3000XKW0
Whirlpool 1LE4900XKW0
Whirlpool 1LE4930XKW0
Whirlpool 1LE5700XKW0
Whirlpool 1LE5800XKW0
Whirlpool 1LE5920XKW0
Whirlpool 1LE7800XKW0
Whirlpool 1LE9800XKW0
Whirlpool 1LE9800XKW1
Whirlpool 1LG5701XKW0
Whirlpool 1LG5801XKW0
Whirlpool 1LG5921XKW0
Whirlpool 1LG9801XKW0
Whirlpool 1LG9801XKW1
Whirlpool 1LHE3000W1
Whirlpool 1LHE5700W1
Whirlpool 1LHE5920W1
Whirlpool 1SF014BEN0
Whirlpool 1SF014BEN1
Whirlpool 1SF014BEN2
Whirlpool 1SF014BEW0
Whirlpool 1SF014BEW1
Whirlpool 1SF014BEW2
Whirlpool 1SF034PEN0
Whirlpool 1SF034PEN1
Whirlpool 1SF034PEN2
Whirlpool 1SF034PEW0
Whirlpool 1SF034PEW1
Whirlpool 1SF034PEW2
Whirlpool 1SMD603
Whirlpool 1VET27DKGW1
Whirlpool 1VET27DKXGW0
Amana 20 Freezer - Vertical
Amana 200.000 Mwave - Family Size (60 Hz)
Amana 200.001 Mwave - Family Size (60 Hz)
Hoover 2000 Frigidaire/electric Range
Hoover 2001 Frigidaire/walloven
Amana 2008.000 Mwave - Family Size (60 Hz)
Amana 2008.001 Mwave - Family Size (60 Hz)
Amana 2008.002 Mwave - Family Size (60 Hz)
Amana 2008.004 Mwave - Family Size (60 Hz)
Amana 2008.100 Commercial Microwaves
Amana 2008.101 Commercial Microwaves
Amana 2008.102 Commercial Microwaves
Amana 2008.112 Commercial Microwaves
Amana 2009.000 Mwave - Family Size (60 Hz)
Amana 2009.001 Mwave - Family Size (60 Hz)
Amana 2009.002 Mwave - Family Size (60 Hz)
Amana 2009.004 Mwave - Family Size (60 Hz)
Amana 200A-30 Room Air Conditioner
Amana 200A-30H Room Air Conditioner
Amana 200A-3HN Room Air Conditioner
Amana 200A-3M Room Air Conditioner
Amana 200A-3N Room Air Conditioner
Amana 200A-3P Room Air Conditioner
Amana 200A-3PH Room Air Conditioner
Amana 200A-3R Room Air Conditioner
Amana 200A-3RH Room Air Conditioner
Amana 200C-30
Amana 200C-30H
Amana 200C-3P Room Air Conditioner
Amana 200C-3PH Room Air Conditioner
Amana 200C-3R Room Air Conditioner
Amana 200C-3RH Room Air Conditioner
Amana 200C-8P Room Air Conditioner
Amana 200C-8RH Room Air Conditioner
Amana 200S
Amana 200SA
Amana 201.000 Mwave - Family Size (60 Hz)
Amana 201.001 Mwave - Family Size (60 Hz)
Amana 201.700 Mwave - Family Size (60 Hz)
Hoover 2010 Frigidaire/range
Hoover 2011
Jenn-Air 20135 Range - S/c D/i Ddraft Ele
Hoover 2017 Tappan/range
Amana 2018.000 Mwave - Family Size (60 Hz)
Amana 2018.001 Mwave - Family Size (60 Hz)
Amana 2018.002 Mwave - Family Size (60 Hz)
Amana 2018.004 Mwave - Family Size (60 Hz)
Amana 2022.000 Mwave - Family Size (60 Hz)
Amana 2022.001 Mwave - Family Size (60 Hz)
Amana 2022.002 Mwave - Family Size (60 Hz)
Amana 2022.004 Mwave - Family Size (60 Hz)
Jenn-Air 20236 Range - S/c S/i Ddraft Ele
Jenn-Air 20237 Range - S/c S/i Ddraft Ele
Jenn-Air 20239 Range - S/c S/i Ddraft Ele
Whirlpool 2025B0A
Whirlpool 2035B0A
Amana 2036.001 Mwave - Family Size (60 Hz)
Amana 2036.005 Mwave - Family Size (60 Hz)
Amana 2036.104 Commercial Microwaves
Amana 2036.105 Commercial Microwaves
Amana 2039.000 Mwave - Family Size (60 Hz)
Amana 2039.001 Mwave - Family Size (60 Hz)
Amana 2039.002 Mwave - Family Size (60 Hz)
Amana 2039.004 Mwave - Family Size (60 Hz)
Hoover 2040
Whirlpool 2041B10
Whirlpool 2041B20
Whirlpool 2041B30
Whirlpool 2041B40
Whirlpool 2045B0A
Whirlpool 2045B1A
Hoover 2048 Frigidaire/warmer Drawer
Amana 2052.000 Mwave - Family Size (60 Hz)
Amana 2052.001 Mwave - Family Size (60 Hz)
Amana 2052.002 Mwave - Family Size (60 Hz)
Amana 2052.004 Mwave - Family Size (60 Hz)
Amana 2054.000 Mwave - Family Size (60 Hz)
Amana 2054.001 Mwave - Family Size (60 Hz)
Amana 2054.002 Mwave - Family Size (60 Hz)
Amana 2054.004 Mwave - Family Size (60 Hz)
Whirlpool 2055B0A
Whirlpool 2055B1A
Whirlpool 2055B2A
Whirlpool 2065B0A
Whirlpool 2065B1A
Whirlpool 2065B2A
Whirlpool 2068120
Whirlpool 2068130
  #2 (permalink)
Old 07-27-2012, 09:01 PM
Junior Member
kurt h is on a distinguished road
Default
does your thermostat have a (c) terminal? If so hook one wire going out to your condensing unit to (c) terminal and the other to the (y) terminal. You should only have 2 wires going outside. Your t stat contacts close r to y in cooling
  #3 (permalink)
Old 07-29-2012, 03:53 PM
Junior Member
Default
Quote:
The terminals you see in the diagram are the only ones it has. Are you saying a two-lead wire should go from the C & Y terminals on the thermo to the outside unit? (Don't have a C terminal, but whatever)
  #4 (permalink)
Old 08-04-2012, 07:04 AM
Member
whsydddy9 is on a distinguished road
Default THERMOSTAT wiring (typically)
Yellow wire should go to - Y
Green wire should go to - G
Red wire should go to - R
White wire should go to - W
Then there should be a jumper wire between RC (cool) & RH (heat)
  #5 (permalink)
Old 08-04-2012, 07:06 AM
Member
Default
the 2 wire from the Ac to the Furnace should be wired on the Y & C terminals - and PLEASE DISCONNECT THE POWER B4 WORKING!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Switch wiring question rustypryor Oven Repair (including Ranges and Cooktops) 1 01-26-2012 01:16 PM
tappan wiring question cutler Oven Repair (including Ranges and Cooktops) 0 12-16-2011 10:40 PM
tappan wiring question cutler Oven Repair (including Ranges and Cooktops) 0 12-16-2011 10:38 PM
thermostat wiring question rickatthelake Refrigerator & Freezer Repair 2 05-06-2009 02:16 PM
Oven wiring question tommyboy84 Oven Repair (including Ranges and Cooktops) 3 09-15-2008 03:29 PM
