Discuss
Need some answers or just some opinions thanks
 in
Heating, Ventilation, and Air Conditioning (HVAC)
Lets talk dehumidifiers. 2 dehumidifiers and both the fans and compressors work however they both will not produce any water
Appliance Repair Forum > Appliance Repair Help > Heating, Ventilation, and Air Conditioning (HVAC) » Need some answers or just some opinions thanks
  #1 (permalink)
Old 07-10-2012, 04:26 PM
Junior Member
richappy2 is on a distinguished road
Default Need some answers or just some opinions thanks
Brand: Amana   Age: Less than 1 year
Lets talk dehumidifiers. 2 dehumidifiers and both the fans and compressors work however they both will not produce any water Help me please with my guess that the sealed system is the issue. Either a possible leak or a recharging needs to happen? No frost pattern around the evap at all when running
Ads By Google
  #2 (permalink)
Old 07-10-2012, 04:29 PM
Junior Member
Default
Thank you for your answers appreciate it
  #3 (permalink)
Old 07-15-2012, 12:47 AM
Junior Member
RonPMatc is on a distinguished road
Default
Yes this sounds like a sealed system issue, you need to check for leaks around any solder joints or get a leak meter and check and get your self a compound gauge and add some freon and look for the frost pattern if it stays your good if not attempt to evacuate than and recharge.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Opinions please. Timer or thermal cycling? adale714 Dryer Repair 1 05-29-2012 05:09 PM
Can't really find answers JVW Dryer Repair 9 05-15-2012 03:14 PM
3rd post still no answers???????? tabark Oven Repair (including Ranges and Cooktops) 1 12-20-2010 05:01 AM
No Answers !!! wvanosten Oven Repair (including Ranges and Cooktops) 0 09-25-2009 11:02 AM
