| » A/C Issue - Lennox furnace |
Model Number: G20Q3/4E-100-3 Brand: -other- Age: 5 - 10 years
No ground at Compressor ground terminal on PC board inside furnace.
24V found at Y wire / positive to compressor terminal with meter grounded to chassis when T-Stat in in "cool" mode. Jumper from Chassis (internal transformer) ground to compressor ground wire makes compressor function normally. No issue with heat side. All wires from T-Stat test as normal. Can I assume that the PC board in the furnace needs to be replaced? Ads By Google Related Models |
Quote:
I was reminded that I should have said "I had to jump the COMMON compressor wire to the chassis to bypass the "C" terminal." I was thinking in terms of DC wiring rather than low voltage AC when I used the term "ground" Anyone out ther have a schematic for this board? Lennox 48K98 . This is a friend's furnace. I'm just helping someone who's down on their luck. All other BCC board related functions seem normal. If this contact is the only one made by this terminal, can I simply make this temporary contact more permanent and save her some money? Last edited by fixerguy123 : 07-10-2012 at 07:44 AM. |
| Display Modes | |
| Lennox heater fan not starting | hermie66 | Heating, Ventilation, and Air Conditioning (HVAC) | 0 | 03-26-2011 11:02 PM |
| lennox heater shuts off | giantsfan | Heating, Ventilation, and Air Conditioning (HVAC) | 4 | 01-27-2011 01:51 PM |
| Gas Valve On Lennox Hvac...bad??? | F1RUETER | Heating, Ventilation, and Air Conditioning (HVAC) | 1 | 11-15-2009 10:07 AM |
| Lennox A/C starts and immediately cuts off | Cooked out | Heating, Ventilation, and Air Conditioning (HVAC) | 1 | 07-20-2009 01:57 PM |
| lennox | cttina | Heating, Ventilation, and Air Conditioning (HVAC) | 0 | 06-27-2009 11:06 AM |
