| » Central Air isn't cooling |
We had the freon check and it is at a good level and no leaks. My husband went out and did the manual start on the fan it made a weird noise and then it worked like it was suppose to. Can stuff get caught in the fan and make it not work properly?
Two simple factors you might try is to substitute the narrow and fresh the outside and inside rings. I've seen this improve the performance of techniques by 50%.
To discover out if your main air device is functional, convert the program on and take a good temperature gauge (I use a food preparation thermometer) and position it in the come back release (the release going to your furnace). |
| Display Modes | |
| Central A/c Problem | lisjeg | Heating, Ventilation, and Air Conditioning (HVAC) | 0 | 07-25-2010 08:04 AM |
| Central A/C not blowing cold enough | qwe32 | Heating, Ventilation, and Air Conditioning (HVAC) | 2 | 07-19-2010 02:24 AM |
| help with a/c central system | ronald871 | Heating, Ventilation, and Air Conditioning (HVAC) | 0 | 07-07-2010 10:24 PM |
| Central Heat won't come on | candy2785 | Heating, Ventilation, and Air Conditioning (HVAC) | 2 | 01-08-2010 07:32 AM |
| central control unit | topwrench | Washer Repair | 1 | 04-27-2009 12:05 PM |
