| » Table top Oscillating Fan, FUJI ~ SANYO |
Vic,
I think I found a suitable replacement capacitor for your fan. Just need to double check something. Could you post all the data off the motor tag here? Thanks.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Hi ~ many thanks for the quick reply. I just got home after being out of town for about 3 days so I apologize for the delay in replying.
Here are the specs as copied directly from the original "condenser": QUOTE: FUJI A.C. ELEC FAN TYPE FTC 4015 SIZE 40CM A.C. VOLT 110 CYCLE 50/60 JSC 9601 FUJI ELEC CO LTD FUJI DENKI M.P. CONDENSER W.V. 280v A.C. CAP 2.5uf ~ R SANYO UNQUOTE. I'm not sure about that last line AFTER the word "CAP 2.5 ... .." It appears to read uf followed by a space and then a captial "R". Thanks again, Regards, Vic |
Shoot, I'm sorry. I just read your answer more closely, you asked for the data off the motor tag and I re-sent you the data off the condenser instead.
I'll get the data from the motor tomorrow and send it along. Gotta excuse me, been driving all day and it's 12:30am now, guess I'm a bit tired. |
Quote:
However we would need more specifics on the dimensions to be certain. Keep in mind that you can use one with a higher voltage rating. GE (General Electric) Capacitors - 27L6093 - Allied Electronics ![]() |
Hello:
Thanks very much for your response. I've been out of town for several days and just saw the post a minute ago. Looks like I'll just have to take it to a local shop. I actually could not find one around this neck of the woods ~ everyone seems to only work on big issues. Someone told me today that Ace Hardware does work on almost any type of small appliance. Don't really have a lot of confidence in Ace HW, but who knows? I disassembled the fan completely (...I've done that several times over the past 40 odd years). Cleaned it all up, re-oiled the felts in the motor and replaced the grease (used Lithium Grease this time) in all the grease fittings. I found the armature heavily coated with a very dark film, possibly carbon but looked more like varnish or shellac. The motor field windings also had the same coating, thought that might be the cause, grease or whatever between the armature segments. Got it all back together and gave it the fire test, nothing. Someone told me to check the brushes in the motor, I couldn't find any brushes. I think this fan was built really well and looks, to me, like it was designed to run without brushes, just A.C. to the stator or something. Is that possible? Guess I just showed you how little I know about electricity and motor structures. Again thanks for the reply. I'll post again if the Ace guys/gals can fix the fan. If not I guess I'll have a static display for the old trophy case. Best Regards, Vic |
| Display Modes | |
| Sanyo microwave | hanselponte | Microwave Repair | 5 | 07-27-2009 07:33 PM |
| Sanyo Microwave wont heat but runs fine | koolboi2009 | Microwave Repair | 0 | 07-05-2009 09:01 AM |
| sanyo MICROWAVE | james2109 | Microwave Repair | 0 | 05-22-2009 09:03 AM |
| Glass Turntable needed for old Sanyo Microwave - 14" replacement or compatible | SandyW | Microwave Repair | 3 | 10-08-2008 09:11 PM |
| Swan table top. | brucieboy | Dishwasher Repair | 1 | 05-27-2008 07:27 PM |
