Discuss
Help with Amana Air Command 90
 in
Heating, Ventilation, and Air Conditioning (HVAC)
Good afternoon. I have an Amana Air Command 90, model GUC090X35A, P1173604F. The current symptom is the system will run
Appliance Repair Forum > Appliance Repair Help > Heating, Ventilation, and Air Conditioning (HVAC) » Help with Amana Air Command 90
  #1 (permalink)
Old 03-31-2012, 01:24 PM
Junior Member
casperitus493 is on a distinguished road
Default Help with Amana Air Command 90
Model Number: GUC090X35A   Brand: Amana   Age: More than 10 years
Good afternoon. I have an Amana Air Command 90, model GUC090X35A, P1173604F. The current symptom is the system will run on Heat constantly, but the burner won't ignite. We had this issue last winter and had a technician out to fix it - there was actually a blinking light then - and he sucked on a tube off of the pressure switch and it was fixed. We didn't seem to have the issue again until this past week, when I had to flip over from AC back to the Heat.
I have tried to follow the guidance of some of the forums that I found (e.g., suck gently on the tube, crank the heat way up), with no luck.
I was looking for a replacement pressure switch, thinking that I could just replace it and correct the issue, but, after talking to a parts specialist online here, found that the part is discontinued.
I just put new batteries in the thermostat, reset and reprogrammed it, and it still doesn't fix the issue.
Before I call a technician back out, does anyone have advice as to how to self diagnose the issue?
Ads By Google
Related Models
Maytag GV1110PRW Range - F/s Std Gas
International GV1226NXEW Freezer - Vertical
International GV1726NXEW Freezer - Vertical
Hoover GV3177WUA Range - F/s Std Gas
Hoover GV3177WUA5 Range - F/s Std Gas
Hoover GV3177WUW Range - F/s Std Gas
Hoover GV3177WUW5 Range - F/s Std Gas
Maytag GV3277XUA Range - F/s Std Gas
Maytag GV3277XUW Range - F/s Std Gas
Hoover GV3531WUA Range - F/s Std Ele
Hoover GV3531WUW Range - F/s Std Ele
Whirlpool GVW9959KL0
Whirlpool GVW9959KL1
Whirlpool GVW9959KL2
Whirlpool GVW9959KL3 Automatic Washer
Whirlpool GVW9959KQ0
Whirlpool GVW9959KQ1
Whirlpool GVW9959KQ2
Whirlpool GVW9959KQ3 Automatic Washer
Whirlpool GVW9959KT0
Whirlpool GVW9959KT1
Whirlpool GVW9959KT2
Whirlpool GVW9959KT3 Automatic Washer
Maytag GW18F1 Washer - Top Loading
Maytag GW18F1A Washer - Top Loading
Maytag GW18F1H Washer - Top Loading
Maytag GW18F1W Washer - Top Loading
Maytag GW18F2 Washer - Top Loading
Maytag GW18F2A Washer - Top Loading
Maytag GW18F2H Washer - Top Loading
Maytag GW18F2W Washer - Top Loading
Maytag GW18G1 Washer - Top Loading
Maytag GW18G100 Washer - Top Loading
Maytag GW18G124 Washer - Top Loading
Maytag GW18G125 Washer - Top Loading
Maytag GW18G1A Washer - Top Loading
Maytag GW18G1HW Washer - Top Loading
Maytag GW18G1WW Washer - Top Loading
Maytag GW20F6 Washer - Top Loading
Maytag GW20F600 Washer - Top Loading
Maytag GW20F624 Washer - Top Loading
Maytag GW20F625 Washer - Top Loading
Maytag GW20F6A Washer - Top Loading
Maytag GW20F6H Washer - Top Loading
Maytag GW20F6W Washer - Top Loading
Frigidaire GW30SPEA2 Wwh(v1) / Electric Range
Frigidaire GW30SPED1 Wwh(v2) / Electric Range
Frigidaire GW30SPEW1 Wwh(v1) / Electric Range
Frigidaire GW30SPEW2 Wwh(v2) / Electric Range
Whirlpool GW395LEGB0
Whirlpool GW395LEGB1
Whirlpool GW395LEGB3
Whirlpool GW395LEGB4
Whirlpool GW395LEGB5
Whirlpool GW395LEGB6
Whirlpool GW395LEGQ0
Whirlpool GW395LEGQ1
Whirlpool GW395LEGQ3
Whirlpool GW395LEGQ4
Whirlpool GW395LEGQ5
Whirlpool GW395LEGQ6
Whirlpool GW395LEGT3
Whirlpool GW395LEGT4
Whirlpool GW395LEGT5
Whirlpool GW395LEGT6
Whirlpool GW395LEGZ0
Whirlpool GW395LEGZ1
Whirlpool GW395LEGZ3
Whirlpool GW395LEPB00 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPB01 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPB02 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPB03 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPB04 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPB05 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPQ00 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPQ01 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPQ02 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPQ03 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPQ04 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPQ05 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPS00 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPS01 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPS02 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPS03 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPS04 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPS05 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPT00 30" Slide - in Gas Oven Non - Convect
Whirlpool GW395LEPT01 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPT02 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPT03 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPT04 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPT05 30" Slide - in Gas Oven Non - Conv
Maytag GWC202 Dishwasher - Convertible
Maytag GWC204 Dishwasher - Convertible
General Electric GWR03AAMABB Refrigerator
Gibson GWS1149AS0 Washer - Gibson
Gibson GWS1149AS1 Washer - Gibson
Gibson GWS1339CS0 Gibson/washer
Gibson GWS1339CS1 Gibson/washer
Gibson GWS1749AS0 Washer - Gibson
Gibson GWS1749AS1 Washer - Gibson
Gibson GWS1749CS0 Gibson/washer
Frigidaire GWS223RFS0 Gib(v0) / Washer
Frigidaire GWS223RFS1 Gib(v0) / Washer
Frigidaire GWS223RHS0 Gib(v0) / Washer
Frigidaire GWS223RHS1
Frigidaire GWS445RFS0 Gib(v0) / Washer
Frigidaire GWS445RFS1 Gib(v1)
Frigidaire GWS445RFS2 Gib(v0) / Washer
Frigidaire GWS445RHS0 Gib(v0) / Washer
Gibson GWS445RHS1 Washer - Gibson
Frigidaire GWS645RBS0 Gib(v0) / 27 " Washer
Frigidaire GWS645RBS1 Gib(v0) / Washer
Frigidaire GWS645RBS2 Gib(v0) / Washer
Frigidaire GWS645RBS3 Gib(v0) / Washer
Frigidaire GWS645RBS4 Gib(v0) / Washer
Frigidaire GWS645RFS0 Gib(v0) / Washer
Frigidaire GWS645RFS1 Gib(v0) / Washer
Frigidaire GWS645RFS2 Gib(v0) / Washer
Frigidaire GWS645RHS0 Gib(v0) / Washer
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
amana ref conbelch Refrigerator & Freezer Repair 1 01-21-2012 01:31 PM
Amana Fan won't run robefinger Refrigerator & Freezer Repair 3 01-12-2012 06:07 PM
Amana sbs oneyoungmunson Refrigerator & Freezer Repair 2 01-11-2012 02:57 AM
Amana fillthebarman Dryer Repair 0 08-18-2010 09:27 AM
Amana BOBSTOUFUS Refrigerator & Freezer Repair 3 01-20-2010 03:07 PM
