Discuss
A.O. Smith Water Heater Pilot Light
 in
Heating, Ventilation, and Air Conditioning (HVAC)
I have a 9-1/2 year old A.O. Smith 50 gallon natural gas water heater, Model FDV 50 216, S/N MK02-2006490-216.
Appliance Repair Forum > Appliance Repair Help > Heating, Ventilation, and Air Conditioning (HVAC) » A.O. Smith Water Heater Pilot Light
  #1 (permalink)
Old 03-11-2012, 03:27 PM
Junior Member
iwanttofixit is on a distinguished road
Default A.O. Smith Water Heater Pilot Light
Model Number: FDV 50 216   Brand: -other-   Age: 5 - 10 years
I have a 9-1/2 year old A.O. Smith 50 gallon natural gas water heater, Model FDV 50 216, S/N MK02-2006490-216. A couple of years ago a plumber was doing some other work, and when he re-lit the water heater pilot light, something changed. Ever since then, on windy days the pilot light blows out--it didn't used to do that. I think he may have bent the pilot light shroud or damaged the thermocouple, but it's pretty hard to lay on the floor and see how things are lining up in there. During windy periods, like now, I end up lighting the pilot light about once a day. When it's not windy, it can stay lit for 4 months. This heater is in the basement and vents out the upper wall through a double pipe--exhaust out the middle and intake air in the outer ring. The metal shroud outside looks to be in good shape (not rusted out), and I tried propping a wind block, but it hasn't helped. Today, for the first time, the main burner didn't want to light after I lit the pilot, waited 90 seconds, and turned on the burner. The burner would try to light and go out, putting the pilot out, too. This happened twice. What causes this? I'm thinking about buying a new pilot/thermocouple assembly and trying to install it, but now I'm wondering if the heater is going out when the burner tries to relight, and that could be the gas control on the outside of the heater? Your thoughts would be greatly appreciated. Thank you.
Ads By Google
Related Models
Whirlpool FGP335EQ0
Whirlpool FGP335EW0
Whirlpool FGP335GN0
Whirlpool FGP335GN1
Whirlpool FGP335GQ0
Whirlpool FGP335GQ1
Whirlpool FGP335GW0
Whirlpool FGP335GW1
Whirlpool FGP335HN0
Whirlpool FGP335HQ0
Whirlpool FGP335HW0
Whirlpool FGP335VL0
Whirlpool FGP335VL1
Whirlpool FGP335VL2
Whirlpool FGP335VL3
Whirlpool FGP335VW0
Whirlpool FGP335VW1
Whirlpool FGP335VW2
Whirlpool FGP335VW3
Whirlpool FGP335YL0
Whirlpool FGP335YL1
Whirlpool FGP335YL2
Whirlpool FGP335YW0
Whirlpool FGP335YW1
Whirlpool FGP335YW2
Whirlpool FGP337GN0
Whirlpool FGP337GN1
Whirlpool FGP337GN5
Whirlpool FGP337GQ0
Whirlpool FGP337GQ1
Whirlpool FGP337GQ5
Whirlpool FGP337GW0
Whirlpool FGP337GW1
Whirlpool FGP337GW5
Whirlpool FGP337HN0
Whirlpool FGP337HQ0
Whirlpool FGP337HW0
Whirlpool FGP337KN0
Whirlpool FGP337KQ0
Whirlpool FGP337KW0
Whirlpool FGP337KW1 30" Gas Freestanding Standard Clean Range Electro
Whirlpool FGP345VL0
Whirlpool FGP345VL1
Whirlpool FGP345VL2
Whirlpool FGP345VW0
Whirlpool FGP345VW1
Whirlpool FGP345VW2
Whirlpool FGP345YL0
Whirlpool FGP345YW0
Whirlpool FGP355VL0
Whirlpool FGP355VL1
Whirlpool FGP355VL2
Whirlpool FGP355VL3
Whirlpool FGP355VW0
Whirlpool FGP355VW1
Whirlpool FGP355VW2
Whirlpool FGP355VW3
Whirlpool FGP355YL0
Whirlpool FGP355YW0
Whirlpool FGP357XL0
Whirlpool FGP357XW0
Whirlpool FGP357YL0
Whirlpool FGP357YL1
Whirlpool FGP357YL3
Whirlpool FGP357YW0
Whirlpool FGP357YW1
Whirlpool FGP357YW2
Whirlpool FGP357YW3
Frigidaire FGQ1442ES0 Frigidaire/dryer
Frigidaire FGQ332ES0 Frigidaire/gas Dryer
Frigidaire FGQB2152FE0 Frigidaire/dryer
Frigidaire FGQB4000FS0 Frigidaire/dryer
Frigidaire FGQBB30DS0 Frigidaire/dryer
Frigidaire FGR211AS0 Dryer - Frigidaire
Frigidaire FGR211AS1 Dryer - Frigidaire
Frigidaire FGR211AS2 Frigidaire/gas Dryer
Frigidaire FGR211AS3 Frigidaire/gas Dryer
Frigidaire FGR211AS4 Frigidaire/dryer
Frigidaire FGR211MAS0 Frigidaire/dryer
Frigidaire FGR221AS0 Dryer - Frigidaire
Frigidaire FGR231AS0 Dryer - Frigidaire
Frigidaire FGR231AS1 Dryer - Frigidaire
Frigidaire FGR231AS2 Frigidaire/dryer
Frigidaire FGR231AS3 Frigidaire/gas Dryer
Frigidaire FGR231AS4 Frigidaire/dryer
Frigidaire FGR231CAS4 Frigidaire/dryer
Frigidaire FGR311FS0 Frigidaire/dryer
Frigidaire FGR331AS0 Dryer - Frigidaire
Frigidaire FGR331AS1 Dryer - Frigidaire
Frigidaire FGR331KAS1 Frigidaire/gas Dryer
Frigidaire FGR341AC0 Frigidaire/dryer
Frigidaire FGR341AC1 Frigidaire/dryer
Frigidaire FGR341AS0 Dryer - Frigidaire
Frigidaire FGR341AS1 Dryer - Frigidaire
Frigidaire FGR641FS0 Frigidaire/dryer
Frigidaire FGR6600ES0 Frigidaire/dryer
Frigidaire FGR6600FS0 Frigidaire/dryer
Frigidaire FGRB5700DS0 Frigidaire/dryer
Frigidaire FGRB6600ES0 Frigidaire/dryer
Frigidaire FGRB6600FS0 Frigidaire/dryer
Frigidaire FGRB7800DS0 Frigidaire/dryer
Whirlpool FGS325RQ0 30" Gas Freestanding Self Clean Range
Whirlpool FGS325RQ1 30" Gas Freestanding Self Clean Range
Whirlpool FGS325RQ2 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD0 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD1 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD2 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD3 30" Gas Freestanding Self Clean Range
Whirlpool FGS335EN0
Whirlpool FGS335EQ0
Whirlpool FGS335EW0
Whirlpool FGS337GN0
Whirlpool FGS337GN1
Whirlpool FGS337GN5
Whirlpool FGS337GQ0
Whirlpool FGS337GQ1
Whirlpool FGS337GQ5
Whirlpool FGS337GQ6
Whirlpool FGS337GQ7
Whirlpool FGS337GW0
  #2 (permalink)
Old 03-12-2012, 08:15 PM
Junior Member
Default
I think I may have found the problem. Talked to a friend about how to go about it. Pulled it all apart, took out the burner/pilot/thermocouple assembly. The thermocouple was pulled down about 3/8" in the bracket, so it wasn't in the pilot flame like it should've been, I guess. Also found that the thermocouple line was less than hand tight in the gas valve! Cleaned it all up really good, cleaned the fitting holes in the gas valve, put it all back together, and the pilot light burned strong after only holding the valve button 30 seconds. Previously was holding it 90 to 150 seconds and the pilot would still not stay lit very well. We'll see over the next few days. Thanks.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
A O Smith Water Heater mdfixer Heating, Ventilation, and Air Conditioning (HVAC) 4 01-17-2012 02:44 AM
Heater Pilot Not Lighting tonyg Oven Repair (including Ranges and Cooktops) 5 03-26-2011 05:50 PM
Light Pilot on Kitchen Heater Gas Range markn984 Oven Repair (including Ranges and Cooktops) 1 01-13-2010 10:33 PM
Space heater pilot light won' stay lit Cochise Heating, Ventilation, and Air Conditioning (HVAC) 0 10-11-2009 06:09 PM
Pool Heater Pilot Light dbdubb Heating, Ventilation, and Air Conditioning (HVAC) 0 05-11-2009 09:27 AM
