| » Wall Heater Keeps Turning Off |
Quote:
The pilot stays lit. I rent thee house from y mom and everything was put in new about two years ago. It has done it from the very start, so we are thinking it is just something is not adjusted quite right. Once the thermostat is on, it just goes on and off at will sometimes. Then, like I said at night, sometimes it just won't fire back up at all. I think when we open and close the door on the bottom if just jiggles something that makes it start again, because sometimes you can just make like Fonzie and just bang on the bottom and it will fire up.
From what I read, you had a warranty issue awhile back.
thermo couple because your pilot stay`s lit, you could have a loose connection on a component, it may be inside covering you could not see. electric testing meter is what you need to test with and sequence of operation to know what happens to find problem. |
| Display Modes | |
| wall/floor heater | johnny wen | Heating, Ventilation, and Air Conditioning (HVAC) | 1 | 12-17-2011 12:24 AM |
| therador wall heater | theard | Heating, Ventilation, and Air Conditioning (HVAC) | 0 | 07-17-2011 06:46 PM |
| Wall Heater | wardic2 | Heating, Ventilation, and Air Conditioning (HVAC) | 0 | 11-23-2010 10:31 AM |
| Heater element supposed to be on when drum not turning? | feeney | Dryer Repair | 0 | 07-15-2010 06:14 PM |
| GE Wall Oven Turning Off after High Temp | laurenquinn | Oven Repair (including Ranges and Cooktops) | 0 | 10-25-2009 07:19 AM |
