Discuss
I need help to figure out what's wrong with my thermostat/heating system
 in
Heating, Ventilation, and Air Conditioning (HVAC)
I have a White-Rodgers thermostat, Model 1F82-162, that was installed in 2003 or 2004. It runs my outdoor heat pump
Appliance Repair Forum > Appliance Repair Help > Heating, Ventilation, and Air Conditioning (HVAC) » I need help to figure out what's wrong with my thermostat/heating system
  #1 (permalink)
Old 03-01-2012, 09:15 AM
Junior Member
Newbie2 is on a distinguished road
Default I need help to figure out what's wrong with my thermostat/heating system
Model Number: 1F82-162   Brand: -other-   Age: 5 - 10 years
I have a White-Rodgers thermostat, Model 1F82-162, that was installed in 2003 or 2004. It runs my outdoor heat pump and is also attached to an indoor blower (furnace?) unit in a closet. The heat pump is the same age as the thermostat, the indoor unit dates to 1984 when the house was built. Until last night, everything seemed to be working fine with the system.
Last night I noticed the backlight on the thermostat was not on. That was my first clue that something is wrong. Next thing I noticed is that the heat did not come on when programmed to. Neither the heat pump nor the blower was going. So I started checking and testing:
Flame icon was flashing on the screen, indicating it was trying to heat.
Day and time were wrong (said 12 on Mon when it should have been 9 pm on Wed). I reset the day and time. It stayed in memory for some time, but eventually it reverted to 12 on Mon.
I set the switch to Emergency heat and the display responded, but nothing turned on.
I replaced the 2 AA batteries inside the cover. Reset the day and time again, checked that the programming had stayed (it did) and turned it to heat, but nothing turned on.
I went outside and flipped the circuits for the heat pump and furnace off and back on again.
I looked at the outdoor fuse for the heat pump, but don't know enough about it to tell if anything is wrong. It's all behind a plastic cover which I did not remove.
I pressed the Reset button on the inside of the thermostat and waited for any change, but heat never came on, although the thermostat itself seemed to reset (the current temperature showed up as 71 and gradually went down to the actual temp of 57, the day and time had to be reset again).
I checked all the configuration items on the thermostat and they were set at factory defaults.
I set the desired temperature above the current temperature, and waited to hear a click like it says in the manual, but I never heard it click, although the flame icon would display and eventually start to flash.
What part of my heating system might be faulty? I'm thinking I need to replace the thermostat, but don't want to take a stab in the dark. I'm good at following instructions and thinking logically, but am not an electical or HVAC expert.
Thanks for any input!
Ads By Google
Related Models
Whirlpool 1LE3000XKW0
Whirlpool 1LE4900XKW0
Whirlpool 1LE4930XKW0
Whirlpool 1LE5700XKW0
Whirlpool 1LE5800XKW0
Whirlpool 1LE5920XKW0
Whirlpool 1LE7800XKW0
Whirlpool 1LE9800XKW0
Whirlpool 1LE9800XKW1
Whirlpool 1LG5701XKW0
Whirlpool 1LG5801XKW0
Whirlpool 1LG5921XKW0
Whirlpool 1LG9801XKW0
Whirlpool 1LG9801XKW1
Whirlpool 1LHE3000W1
Whirlpool 1LHE5700W1
Whirlpool 1LHE5920W1
Whirlpool 1SF014BEN0
Whirlpool 1SF014BEN1
Whirlpool 1SF014BEN2
Whirlpool 1SF014BEW0
Whirlpool 1SF014BEW1
Whirlpool 1SF014BEW2
Whirlpool 1SF034PEN0
Whirlpool 1SF034PEN1
Whirlpool 1SF034PEN2
Whirlpool 1SF034PEW0
Whirlpool 1SF034PEW1
Whirlpool 1SF034PEW2
Whirlpool 1SMD603
Whirlpool 1VET27DKGW1
Whirlpool 1VET27DKXGW0
Amana 20 Freezer - Vertical
Amana 200.000 Mwave - Family Size (60 Hz)
Amana 200.001 Mwave - Family Size (60 Hz)
Hoover 2000 Frigidaire/electric Range
Hoover 2001 Frigidaire/walloven
Amana 2008.000 Mwave - Family Size (60 Hz)
Amana 2008.001 Mwave - Family Size (60 Hz)
Amana 2008.002 Mwave - Family Size (60 Hz)
Amana 2008.004 Mwave - Family Size (60 Hz)
Amana 2008.100 Commercial Microwaves
Amana 2008.101 Commercial Microwaves
Amana 2008.102 Commercial Microwaves
Amana 2008.112 Commercial Microwaves
Amana 2009.000 Mwave - Family Size (60 Hz)
Amana 2009.001 Mwave - Family Size (60 Hz)
Amana 2009.002 Mwave - Family Size (60 Hz)
Amana 2009.004 Mwave - Family Size (60 Hz)
Amana 200A-30 Room Air Conditioner
Amana 200A-30H Room Air Conditioner
Amana 200A-3HN Room Air Conditioner
Amana 200A-3M Room Air Conditioner
Amana 200A-3N Room Air Conditioner
Amana 200A-3P Room Air Conditioner
Amana 200A-3PH Room Air Conditioner
Amana 200A-3R Room Air Conditioner
Amana 200A-3RH Room Air Conditioner
Amana 200C-30
Amana 200C-30H
Amana 200C-3P Room Air Conditioner
Amana 200C-3PH Room Air Conditioner
Amana 200C-3R Room Air Conditioner
Amana 200C-3RH Room Air Conditioner
Amana 200C-8P Room Air Conditioner
Amana 200C-8RH Room Air Conditioner
Amana 200S
Amana 200SA
Amana 201.000 Mwave - Family Size (60 Hz)
Amana 201.001 Mwave - Family Size (60 Hz)
Amana 201.700 Mwave - Family Size (60 Hz)
Hoover 2010 Frigidaire/range
Hoover 2011
Jenn-Air 20135 Range - S/c D/i Ddraft Ele
Hoover 2017 Tappan/range
Amana 2018.000 Mwave - Family Size (60 Hz)
Amana 2018.001 Mwave - Family Size (60 Hz)
Amana 2018.002 Mwave - Family Size (60 Hz)
Amana 2018.004 Mwave - Family Size (60 Hz)
Amana 2022.000 Mwave - Family Size (60 Hz)
Amana 2022.001 Mwave - Family Size (60 Hz)
Amana 2022.002 Mwave - Family Size (60 Hz)
Amana 2022.004 Mwave - Family Size (60 Hz)
Jenn-Air 20236 Range - S/c S/i Ddraft Ele
Jenn-Air 20237 Range - S/c S/i Ddraft Ele
Jenn-Air 20239 Range - S/c S/i Ddraft Ele
Whirlpool 2025B0A
Whirlpool 2035B0A
Amana 2036.001 Mwave - Family Size (60 Hz)
Amana 2036.005 Mwave - Family Size (60 Hz)
Amana 2036.104 Commercial Microwaves
Amana 2036.105 Commercial Microwaves
Amana 2039.000 Mwave - Family Size (60 Hz)
Amana 2039.001 Mwave - Family Size (60 Hz)
Amana 2039.002 Mwave - Family Size (60 Hz)
Amana 2039.004 Mwave - Family Size (60 Hz)
Hoover 2040
Whirlpool 2041B10
Whirlpool 2041B20
Whirlpool 2041B30
Whirlpool 2041B40
Whirlpool 2045B0A
Whirlpool 2045B1A
Hoover 2048 Frigidaire/warmer Drawer
Amana 2052.000 Mwave - Family Size (60 Hz)
Amana 2052.001 Mwave - Family Size (60 Hz)
Amana 2052.002 Mwave - Family Size (60 Hz)
Amana 2052.004 Mwave - Family Size (60 Hz)
Amana 2054.000 Mwave - Family Size (60 Hz)
Amana 2054.001 Mwave - Family Size (60 Hz)
Amana 2054.002 Mwave - Family Size (60 Hz)
Amana 2054.004 Mwave - Family Size (60 Hz)
Whirlpool 2055B0A
Whirlpool 2055B1A
Whirlpool 2055B2A
Whirlpool 2065B0A
Whirlpool 2065B1A
Whirlpool 2065B2A
Whirlpool 2068120
Whirlpool 2068130
  #2 (permalink)
Old 03-03-2012, 06:06 PM
Junior Member
Default Update--problem resolved with service pros
So I continued to troubleshoot, checking the outdoor and indoor fuse boxes, and trying to test the wires to the thermostat to see if there was power. Eventually I took out those 2 AA batteries, which the user's manual said were optional, and there was no power to the thermostat at all.
I was out of ideas for what I could do myself, so I called in an electrician. He checked the indoor fuse box to determine that there was definitely power going to the air handler (the blower/furnace that I mentioned in my original post). And there was definitely no power to the thermostat. So I needed an HVAC pro.
I called one in, and he found that a fuse had blown in the air handler. Replaced that, turned on the thermostat, and the fuse immediately blew again. With inspection of the heat pump electrical stuff and some more troubleshooting inside (to bypass the fuse, I think), he diagnosed that the contact unit on the heat pump had failed. He replaced that and the thermostat then started the air handler, and after a 5 minute or so time delay the heat pump kicked in. The heat pump also kicked off and went through some kind of cycle, and within 15 minutes or so was back on, fan spinning, house heating.
Just a note, for anyone who might be looking for service people, or for service pros who want more ways to get customers, I found both the electrician and HVAC service person through ServiceMagic.com. It wasn't even 1 minute after I submitted a request for assistance that I got a phone call each time. Both pros were very quick, friendly, professional, competent and reasonable. I highly recommend that website if you are hesitating about calling someone for help.
  #3 (permalink)
Old 03-23-2013, 02:59 AM
Junior Member
john sitra is on a distinguished road
Default
1st if it uses batteries change the ,next dose the fan on turn the blower on
  #4 (permalink)
Old 03-23-2013, 03:03 AM
Junior Member
Smile thermostat help
check the batteries if applicable next dose the fan on switch activate the fan
  #5 (permalink)
Old 03-23-2013, 07:08 AM
Junior Member
Default You're a little late
Uh, John, thanks for the idea about changing the batteries, but if you read the entire thread, you would have been aware that I did that early on in my diagnosis. Besides which, the entire problem has been figured out and fixed 2 years ago when I posted the original problem. All of that info is posted here already, so don't waste your time offering advice for issues that no longer exist. Thanks anyway, and good luck.
  #6 (permalink)
Old 05-10-2013, 07:34 PM
Junior Member
Adeline Dalia is on a distinguished road
Default
It was better that a serviceman was called because without having the proper knowledge and experience, experimenting your ways on the appliance can sometimes damage some most important components for its functioning costing much more than what can be settled by simple servicing.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
home hvac system wired wrong and shorted, help hglarry Heating, Ventilation, and Air Conditioning (HVAC) 1 03-23-2013 03:11 AM
Replaced 3 parts.. Still can't figure out what's wrong! Neozen Dryer Repair 0 01-12-2011 09:32 PM
trying to figure out what's wrong with my washer arthurlw_2000@yahoo.com Washer Repair 1 11-16-2010 11:19 AM
How do I check the defrost timer, heater, and thermostat and repair whats wrong elgem3 Refrigerator & Freezer Repair 1 10-26-2008 04:36 PM
wrong part for thermostat? jcsmaestra Oven Repair (including Ranges and Cooktops) 0 04-04-2008 11:20 AM
