Discuss
Gas Furnace Stopped working
 in
Heating, Ventilation, and Air Conditioning (HVAC)
My Magic Chef gas furnace (model number unknown at this time) stopped working this morning. I tried to turn the
Appliance Repair Forum > Appliance Repair Help > Heating, Ventilation, and Air Conditioning (HVAC) » Gas Furnace Stopped working
  #1 (permalink)
Old 01-31-2012, 01:34 PM
Junior Member
mitch8 is on a distinguished road
Default Gas Furnace Stopped working
Model Number: ?   Brand: Magic Chef   Age: More than 10 years
My Magic Chef gas furnace (model number unknown at this time) stopped working this morning. I tried to turn the thermostat off and on; raised the temperature setting beyond 80 (it was 61 in the house); replaced the batteries in the thermostat; but to no avail. When I went in the basement to have a look, nothing was apparent, so I turned the circuit breaker feeding the furnace off and on. No change. There is a electrical box mounted on the side of the furnace with a switch - when I turned it off and on, the pilot ignited and when it was hot enough, the fan turned on. Success, or so I thought, but 10 minutes later the temp only got to 63 and the furnace wasn't on. I thought I'd look inside the metal box that had the switch to see if there was a loose wire. As soon as the screwdriver touched one of the two mounting screws the furnace kicked on - but a few minutes later stopped working. I removed the plate and found nothing amiss, no loose or frayed wires, no loose connections or parts, but noticed that if the plate was put in a particular alignment the furnace shut off.
There is a small metal box/can on the switch plate and a wire extends from the switch to the can on the inside side of the switch plate - does anyone know what this part is (relay maybe)? Is it repairable? If the model number is important I can provide it when I get home...not too prepared (my bad)
tia,
Mitch
Ads By Google
Related Models
General Electric A*B588D Room air conditioner
General Electric A*B588E Room air conditioner
General Electric A*B688D Room air conditioner
General Electric A*B688E Room air conditioner
Jenn-Air A0310 Misc / Accessory
Frigidaire A04LE2E1 Frg(v1) / Room Air Conditioner
Frigidaire A04LE2F1 Frg(v1) / Room Air Conditioner
Frigidaire A05LE2E1 Frg(v2) / Room Air Conditioner
Frigidaire A05LE2E2 Frg(v4) / Room Air Conditioner
Frigidaire A05LE2E3 Frg(v1) / Room Air Conditioner
Frigidaire A05LE2E7 Frg(v1) / Room Air Conditioner
Frigidaire A05LE2N1 Frg(v1) / Room Air Conditioner
Frigidaire A05LH5E1 Frg(v1) / Room Air Conditioner
Frigidaire A05LH5F1 Frg(v1) / Room Air Conditioner
Frigidaire A05LH5F2 Frg(v1) / Room Air Conditioner
Frigidaire A05LH5K1 Frg(v1) / Room Air Conditioner
Frigidaire A05LH5L1 Frg(v1) / Room Air Conditioner
Frigidaire A05LH5N1 Frg(v0) / Room Air Conditioner
Frigidaire A05LH8F1 Frg(v1) / Room Air Conditioner
Frigidaire A05LH8L1 Frg(v1) / Room Air Conditioner
Frigidaire A05LH8N1 Frg(v1) / Room Air Conditioner
Frigidaire A05LS1F1 Frg(v1) / Air Conditioner
Frigidaire A05LS1N1 Frg(v1) / Room Air Conditioner
Frigidaire A06LE2E1 Frg(v3) / Room Air Conditioner
Frigidaire A06LE2E2 Frg(v1) / Room Air Conditioner
Frigidaire A06LE2E3 Frg(v2) / Room Air Conditioner
Frigidaire A06LE2K1 Frg(v1) / Room Air Conditioner
Frigidaire A06LE2L1 Frg(v1) / Room Air Conditioner
Frigidaire A06LE2N1 Frg(v1) / Room Air Conditioner
Frigidaire A06LE3E1 Frg(v1) / Room Air Conditioner
Frigidaire A06LH5E1 Frg(v1) / Room Air Conditioner
Frigidaire A06LH5E2 Frg(v1) / Room Air Conditioner
Frigidaire A06LH5F1 Frg(v1) / Room Air Conditioner
Frigidaire A06LH5L1 Frg(v1) / Room Air Conditioner
Frigidaire A06LH5N1 Frg(v1) / Room Air Conditioner
Frigidaire A06LH6F1 Frg(v1) / Room Air Conditioner
Frigidaire A06LH6L1 Frg(v1) / Room Air Conditioner
Frigidaire A06LH8E1 Frg(v1) / Room Air Conditioner
Frigidaire A07LH8E1 Frg(v1) / Room Air Conditioner
Frigidaire A07LH8E2 Frg(v1) / Room Air Conditioner
Frigidaire A07LH8E3 Frg(v1) / Room Air Conditioner
Frigidaire A07LH8L1 Frg(v1) / Room Air Conditioner
Frigidaire A08LE2E1 Frg(v1) / Room Air Conditioner
Frigidaire A08LE2E2 Frg(v2) / Room Air Conditioner
Frigidaire A08LE2N1 Frg(v1) / Room Air Conditioner
Frigidaire A08LE2N2 Frg(v1) / Room Air Conditioner
Frigidaire A08LH5E1 Frg(v1) / Room Air Conditioner
Frigidaire A08LH5E2 Frg(v2) / Room Air Conditioner
Frigidaire A08LH5F1 Frg(v1) / Room Air Conditioner
Frigidaire A08LH5L1 Frg(v1) / Room Air Conditioner
Frigidaire A08LH5L2 Frg(v1) / Room Air Conditioner
Frigidaire A08LH5L3 Frg(v1) / Room Air Conditioner
Frigidaire A08LH8N1 Frg(v1) / Room Air Conditioner
Frigidaire A08ME2E1 Frg(v1) / Room Air Conditioner
Frigidaire A08ME2E2 Frg(v2) / Room Air Conditioner
Frigidaire A08ME2E3 Frg(v1) / Room Air Conditioner
Frigidaire A08ME2E4 Frg(v1) / Room Air Conditioner
Whirlpool A0W17W12
Whirlpool A0W22W12
Whirlpool A0W23L10
Whirlpool A0W23W10
Jenn-Air A100 Ele Cartridge
Jenn-Air A100-8 Ele Cartridge
Jenn-Air A100-C Ele Cartridge
Jenn-Air A100-J Ele Cartridge
Jenn-Air A100B Ele Cartridge
Jenn-Air A100B-8 Ele Cartridge
Jenn-Air A100B-C Ele Cartridge
Jenn-Air A100L Ele Cartridge
Jenn-Air A100L-C Ele Cartridge
Jenn-Air A100L-J Ele Cartridge
Maytag A100S Washer - Top Loading
Jenn-Air A100S-8 Ele Cartridge
Jenn-Air A100S-C Ele Cartridge
Jenn-Air A100W Ele Cartridge
Jenn-Air A100W-8 Ele Cartridge
Jenn-Air A100W-C Ele Cartridge
Jenn-Air A100W-J Ele Cartridge
Maytag A101 Washer - Top Loading
Maytag A102 Washer - Top Loading
Maytag A102S Washer - Top Loading
Maytag A103 Washer - Top Loading
Maytag A103S Washer - Top Loading
Maytag A104 Washer - Top Loading
Maytag A105 Washer - Top Loading
Jenn-Air A105-8 Misc / Accessory
Maytag A105T Washer - Top Loading
Jenn-Air A105W-8 Misc / Accessory
Maytag A106 Washer - Top Loading
Jenn-Air A106B Ele Cartridge
Maytag A106S Washer - Top Loading
Jenn-Air A106W Ele Cartridge
Maytag A107 Washer - Top Loading
Maytag A107S Washer - Top Loading
Maytag A108 Washer - Top Loading
Hoover A1089
Maytag A108S Washer - Top Loading
Maytag A110 Washer - Top Loading
Jenn-Air A110-8 Misc / Accessory
Admiral A1100PRA Range - F/s Std Gas
Admiral A1100PRA-K Range - F/s Std Gas
Admiral A1100PRW Range - F/s Std Gas
Admiral A1100PRW-K Range - F/s Std Gas
Admiral A110PRA Range - F/s Std Gas
Admiral A110PRW Range - F/s Std Gas
Jenn-Air A111 Misc / Accessory
Jenn-Air A111-8 Misc / Accessory
Jenn-Air A111B Misc / Accessory
Jenn-Air A111W Misc / Accessory
Maytag A112 Washer - Top Loading
Maytag A112T Washer - Top Loading
Frigidaire A11ME5E1 Frg(v1) / Room Air Conditioner
Frigidaire A11ME5F1 Frg(v1) / Room Air Conditioner
Frigidaire A11ME5L2 Frg(v1) / Room Air Conditioner
Frigidaire A11ME8E1 Frg(v1) / Room Air Conditioner
Frigidaire A11ME8E2 Frg(v2) / Room Air Conditioner
Frigidaire A11ME8E3 Frg(v1) / Room Air Conditioner
Frigidaire A11MEDC2 Frg(v1) / Room Air Conditioner
Frigidaire A11MEDSD3 Frg(v1) / Room Air Conditioner
Frigidaire A11MEDTC2 Frg(v2) / Room Air Conditioner
  #2 (permalink)
Old 03-15-2012, 02:21 AM
Junior Member
salmanblc is on a distinguished road
Unhappy Check Switch and Gas PipeLine
May be Gas Switch is not working or Problem in Gas PipeLine..Check it otherwise Better Re-install it to be 100% sure..
__________________
Backlinks-Cafe.com Affordable SEO Services.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Furnace keeps powering off preventing air conditioning from working eldon_brasche Heating, Ventilation, and Air Conditioning (HVAC) 1 08-23-2011 05:25 PM
refrigerator stopped working cleaned it and started working then stopped working agai ravaginggoatman Refrigerator & Freezer Repair 5 12-18-2010 01:13 AM
Trane furnace has no heat, fan still working slycer2002 Heating, Ventilation, and Air Conditioning (HVAC) 5 03-16-2010 07:12 AM
Amana Furnace Stops working produces oil/electic smell hamsi067 Heating, Ventilation, and Air Conditioning (HVAC) 1 11-17-2009 03:55 PM
Refrig and freezer stopped working, then started...then stopped again Auvan0876 Refrigerator & Freezer Repair 2 08-28-2009 07:29 PM
