Will the AC Gurus please confirm!
Brand: -other- Age: More than 10 years
Hi there, could use some good ac advice from some of you ac pros. I have a Trane that is about 11 years old. It is currently very very hot here in San Antonio and everyones units are being put to the test. Long story short, when my thermostat kicks in and tells the unit to turn on everything seems to function except that the fan will not turn. After trying a multitude of solutions, I simply gave the fan a little push and it started spinning normally. When I shut it down and turned it back on, same problem.
I guess I could have simply said "AC fan will not engage without a spin of assistance."
Am I correct in thinking that this issue is being caused by a weak fan motor? Money is an issue for me at this time and I would love to be able to do this repair myself. Seeing as how the fan will start to spin when assisted, I'm hoping that I am on the right track.
All help is certainly appreciated....Thank You, Chuck P
Ads By Google
