Discuss
confused by different codes
 in
Heating, Ventilation, and Air Conditioning (HVAC)
the mfg label says inner city products out of Texas, there is no brand name that i can find. My
Appliance Repair Forum > Appliance Repair Help > Heating, Ventilation, and Air Conditioning (HVAC) » confused by different codes
  #1 (permalink)
Old 01-02-2008, 06:13 PM
psr918 psr918 is offline
Junior Member
psr918 is on a distinguished road
Default confused by different codes
Model Number: GUI100A012AIN   Brand: -other-   Age: More than 10 years
the mfg label says inner city products out of Texas, there is no brand name that i can find. My house is at about 59 in the basement, and 64 on the main floor, of couse this sort of thing happens when it is zero outside, but my furnace is not functioning the way it should. the control for the unit is a white-rodgers furnace control, model # 50A50-110 and it shows me 2 different trouble codes. first off, the small blower above, which i believe is for removing fumes, it comes on just before the burner, the igniter starts to glowand then the burner lights and the igniter goes out. about 10 seconds later the blower stars and the furnace runs for about3 minutes or so, and the burner shuts off. i get a 4 flash trouble code from the control while the blower is in the "cool down ". the code reads as "open high limit switch" . Then sometimes it changes habit and after the burner comes on it only stays on for about 10 seconds then shuts off, the code flashes 6 times now, and there is no translation for 6 flash code.
can anyone make heads or tail on this?
Paul
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-03-2008, 12:01 PM
conradmech conradmech is offline
Junior Member
conradmech is on a distinguished road
Default
sounds like you have a dirty filter. this causes the heater box to over heat. this opens the high limit and causes it to need to cool down.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven Error Codes Admin / APP Team Oven Repair (including Ranges and Cooktops) 60 11-29-2008 09:37 PM
error codes E0 F0 Catspring Oven Repair (including Ranges and Cooktops) 1 12-23-2007 07:42 AM
Error codes Al Maue Oven Repair (including Ranges and Cooktops) 1 12-18-2007 02:38 PM
Kenmore oven F codes? shano Oven Repair (including Ranges and Cooktops) 0 11-23-2007 08:58 AM
error codes f3 and f5 caraline k Oven Repair (including Ranges and Cooktops) 0 11-22-2007 02:57 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
