Discuss
orifice tube location
 in
Heating, Ventilation, and Air Conditioning (HVAC)
Hi, i own an international comfort products AC system (duct free systems) The evaporator his always freezing. I tought the
Appliance Repair Forum > Appliance Repair Help > Heating, Ventilation, and Air Conditioning (HVAC) » orifice tube location
  #1 (permalink)
Old 05-24-2009, 04:25 PM
patvac patvac is offline
Junior Member
patvac is on a distinguished road
Default orifice tube location
Model Number: DFS2A   Brand: -other-   Age: 1 - 5 years
The evaporator his always freezing. I tought the calibrated orifice might be clogg (chunk of welding). I need your help to know exactly where it should be located.
thank you
Related Models
Amana DFU17 Freezer - Vertical
Amana DFU17L Freezer - Vertical
Amana DFU18 Freezer - Vertical
Amana DFU18L Freezer - Vertical
Maytag DG100 Dryer - Gas
Maytag DG100PN1 Dryer - Gas
Maytag DG101 Dryer - Gas
Maytag DG102 Dryer - Gas
Amana DG1030 Washer - Top Loading
Amana DG1031 Washer - Top Loading
Maytag DG105 Dryer - Gas
Maytag DG106 Dryer - Gas
Maytag DG107 Dryer - Gas
Maytag DG110 Dryer - Gas
Maytag DG16CA Dryer - Gas
Maytag DG16CM Dryer - Gas
Maytag DG16CT Dryer - Gas
Maytag DG18CA Dryer - Gas
Maytag DG18CM Dryer - Gas
Maytag DG18CS Dryer - Gas
Maytag DG18CT Dryer - Gas
Admiral DG18F2AM Dryer - Gas
Admiral DG18F2HW Dryer - Gas
Admiral DG18F2WN Dryer - Gas
Admiral DG18F2WW Dryer - Gas
Maytag DG19CD Dryer - Gas
Maytag DG19CS Dryer - Gas
Maytag DG19CT Dryer - Gas
Frigidaire DG2000DL1 Frg(v1) / Gas Dryer
Frigidaire DG2000DW1 Frg(v2) / Gas Dryer
Magic Chef DG20F5AM Dryer - Gas
Magic Chef DG20F5FA Dryer - Gas
Magic Chef DG20F5HW Dryer - Gas
Magic Chef DG20F5WG Dryer - Gas
Magic Chef DG20F5WW Dryer - Gas
Admiral DG20F8AM Dryer - Gas
Admiral DG20F8HW Dryer - Gas
Admiral DG20F8WW Dryer - Gas
Maytag DG210 Dryer - Gas
Maytag DG212 Dryer - Gas
Maytag DG212D Dryer - Gas
Maytag DG21CA Dryer - Gas
Maytag DG21CM Dryer - Gas
Maytag DG21CS Dryer - Gas
Maytag DG21CT Dryer - Gas
Maytag DG22CA Dryer - Gas
Maytag DG22CS Dryer - Gas
Maytag DG22CT Dryer - Gas
Maytag DG23CD Dryer - Gas
Maytag DG24CA Dryer - Gas
Maytag DG24CM Dryer - Gas
Maytag DG24CS Dryer - Gas
Maytag DG24CT Dryer - Gas
Frigidaire DG250EXD1 Wwh(v1) / Gas Dryer
Frigidaire DG250EXD4 Wwh(v2) / Gas Dryer
Frigidaire DG250EXD5 Wwh(v3) / Gas Dryer
Frigidaire DG250EXF1 Wwh(v4) / Gas Dryer
Frigidaire DG250EXF4 Wwh(v5) / Gas Dryer
Frigidaire DG250EXF5 Wwh(v6) / Gas Dryer
Frigidaire DG250EXH1 Wwh(v7) / Gas Dryer
Frigidaire DG250EXH4 Wwh(v8) / Gas Dryer
Frigidaire DG250EXH5 Wwh(v9) / Gas Dryer
Frigidaire DG250EXV1 Wwh(v10) / Gas Dryer
Frigidaire DG250EXV4 Wwh(v11) / Gas Dryer
Frigidaire DG250EXV5 Wwh(v12) / Gas Dryer
Frigidaire DG250EXW1 Wwh(v13) / Gas Dryer
Frigidaire DG250EXW4 Wwh(v14) / Gas Dryer
Frigidaire DG250EXW5 Wwh(v15) / Gas Dryer
Frigidaire DG250JXD1 Wwh(v1) / Gas Dryer
Frigidaire DG250JXF1 Wwh(v2) / Gas Dryer
Frigidaire DG250JXH1 Wwh(v3) / Gas Dryer
Frigidaire DG250JXV1 Wwh(v4) / Gas Dryer
Frigidaire DG250JXW1 Wwh(v5) / Gas Dryer
Frigidaire DG250KXD1 Wwh(v3) / 27 " Gas Dryer
Frigidaire DG250KXD2 Wwh(v3) / 27 " Gas Dryer
Frigidaire DG250KXD3 Wwh(v3) / 27 " Gas Dryer
Frigidaire DG250KXD4 Wwh(v2) / 27 " Gas Dryer
Frigidaire DG250KXH1 Wwh(v2) / 27 " Gas Dryer
Frigidaire DG250KXH2 Wwh(v2) / 27 " Gas Dryer
Frigidaire DG250KXH3 Wwh(v2) / 27 " Gas Dryer
Frigidaire DG250KXW1 Wwh(v1) / 27 " Gas Dryer
Frigidaire DG250KXW2 Wwh(v1) / 27 " Gas Dryer
Frigidaire DG250KXW3 Wwh(v1) / 27 " Gas Dryer
Frigidaire DG250KXW4 Wwh(v1) / 27 " Gas Dryer
Maytag DG25CS Dryer - Gas
Maytag DG26CA Dryer - Gas
Maytag DG26CD Dryer - Gas
Maytag DG26CS Dryer - Gas
Maytag DG26CT Dryer - Gas
Frigidaire DG27A5WAFA Gib(v2) / 27 " Gas Dryer
Frigidaire DG27A5WAFB Gib(v2) / 27 " Gas Dryer
Frigidaire DG27A5WVFA Gib(v3) / 27 " Gas Dryer
Frigidaire DG27A5WVFX Gib(v3) / 27 " Gas Dryer
Frigidaire DG27A5WXFC Gib(v2) / 27 " Gas Dryer
Frigidaire DG27A5WXFD Gib(v2) / 27 " Gas Dryer
Frigidaire DG27A5WXFE Gib(v2) / 27 " Gas Dryer
Frigidaire DG27A5WXFF Gib(v2) / 27 " Gas Dryer
Frigidaire DG27A7WVFA Gib(v1) / 27 " Gas Dryer
Frigidaire DG27A7WVFX Gib(v1) / 27 " Gas Dryer
Frigidaire DG27A7WXFB Gib(v1) / 27 " Gas Dryer
Frigidaire DG27A7WXFC Gib(v1) / 27 " Gas Dryer
Frigidaire DG27A7WXFD Gib(v1) / 27 " Gas Dryer
Frigidaire DG27A7WXFE Gib(v1) / 27 " Gas Dryer
Frigidaire DG27A8WAFA Gib(v1) / 27 " Gas Dryer
Frigidaire DG27A8WAFB Gib(v1) / 27 " Gas Dryer
Maytag DG27CA Dryer - Gas
Maytag DG27CD Dryer - Gas
Maytag DG27CS Dryer - Gas
Maytag DG27CT Dryer - Gas
Frigidaire DG27S6DTMA Gib(v1) / Gas Dryer
Frigidaire DG27S6DVFA Gib(v2) / 27 " Gas Dryer
Frigidaire DG27S6FTMA Gib(v3) / Gas Dryer
Frigidaire DG27S6WPMA Gib(v1) / Stackable Gas Dryers
Frigidaire DG27S6WPMB Gib(v2) / Stackable Gas Dryers
Frigidaire DG27S6WPMC Gib(v3) / Stackable Gas Dryers
Frigidaire DG27S6WTMA Gib(v4) / Gas Dryer
Frigidaire DG27S6WVFA Gib(v1) / 27 " Gas Dryer
Frigidaire DG27S6WVFB Gib(v1) / 27 " Gas Dryer
Frigidaire DG27S6WVFC Gib(v1) / 27 " Gas Dryer
Frigidaire DG27S6YTMA Gib(v2) / Gas Dryer
  #2 (permalink)
Old 05-31-2009, 07:49 PM
icehouse icehouse is offline
Senior Expert
APP Volunteer
icehouse is on a distinguished road
Default
You are probably running the unit at a low outdoor temperature. This will prevent the condenser from condensing properly. As a result the refrigerant is pooling up in the condenser and starving the evaporator which results in lower pressure. Lower pressure results in lower temperature hence the coil freeze up.
__________________
NATE, HVAC Ecellence, NCCER, PHCC Certified Instructor. Vist www.hvacbob.com
  #3 (permalink)
Old 05-31-2009, 08:58 PM
Junior Member
Default
We have discuss togetter already, but it's also freezing when it's really hot outside
  #4 (permalink)
Old 06-01-2009, 09:44 AM
Senior Expert
APP Volunteer
Default
That was on another forum. Please list all conditions such as evaporator coil (clean thoroughly), condenser coil (clean thoroughly) filters changed, supply air temperature, return air temperature, dry bulb temperature, wet bulb temperature. Since this is a fixed orifice the charge is verified by super-heat, so post that reading as well.
__________________
  #5 (permalink)
Old 06-01-2009, 10:25 AM
Senior Expert
APP Volunteer
Default
Use the following:
File Type: doc Superheat charging curves for technicians.doc (92.5 KB, 5 views)
__________________
  #6 (permalink)
Old 06-05-2009, 02:21 PM
Junior Member
Default New measurements
outside temperature 90 F with 20 % humidity
high Low
165 40
150 25
150 23 (psi)
Temperature external of evaporator 49.5F at 23 psi (shoud be -2F)
Temperature external of condenser 97 F at the fan at 150 psi (shoud be -82.5F)
Fitting at the condenser are full of ice and evaporator his starting to fill up too.
Thank you
  #7 (permalink)
Old 06-05-2009, 02:33 PM
Senior Expert
APP Volunteer
Default
Pressures are way off for R22. Head Pressure should be around 275# (110*F condensing temperature).
Suction 68# (40*F evaporator temperature)
__________________
  #8 (permalink)
Old 06-05-2009, 02:36 PM
Senior Expert
APP Volunteer
Default
Also read:
File Type: doc Diagnosing Air Conditioning System Problems.doc (23.0 KB, 3 views)
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
what is diffrent between LP gs orifice and Netural gas orifice mani Oven Repair (including Ranges and Cooktops) 0 04-30-2009 06:31 AM
whirlpool orifice for LP sprasad Dryer Repair 2 04-05-2009 09:12 AM
Natural Gas Orifice jeff glanzer Oven Repair (including Ranges and Cooktops) 1 12-27-2008 09:13 PM
Orifice Tube Assembly REYNA_CERRATRO123@MSN.COM Oven Repair (including Ranges and Cooktops) 0 10-16-2008 10:49 AM
changed out both orifice tube assemblies, burning tall and yellow now gene1340 Oven Repair (including Ranges and Cooktops) 0 07-02-2008 09:12 AM
