Discuss
Blower Motor for Sears Furnace
 in
Heating, Ventilation, and Air Conditioning (HVAC)
I recently purchased a new blower motor for our home furnace and recieved the motor right on time. Hooray! The
Appliance Repair Forum > Appliance Repair Help > Heating, Ventilation, and Air Conditioning (HVAC) » Blower Motor for Sears Furnace
  #1 (permalink)
Old 12-11-2007, 09:28 PM
dickcollentine dickcollentine is offline
Junior Member
dickcollentine is on a distinguished road
Unhappy Blower Motor for Sears Furnace
Model Number: 8677642420   Brand: Sears   Age: More than 10 years
I recently purchased a new blower motor for our home furnace and recieved the motor right on time. Hooray! The problem is the new motor has a different number and color coding on the wires coming out of it. I have been able to determine the power, neutral and several other wires but I am stymied by one thing. The new motor has two orange and two yellow leads that are looped to one another. On the motor casing it states that to reverse the direction or rotation of the motor, you should reverse these connections ( in other words, instead of connecting the yellow to the yellow and the orange to the orange, it says to connect the yellow to the orange and the orange to the yellow.
The problem is, the old motor had only 1 orange and 1 yellow lead, and these were connected to wires leading into the electrical junction box in the furnace. One of the wires then continued on to another small box which appeared to have something to do with the cycling or timing of the blower motor.
Sorry to be so obscure in my description, but maybe someone out there has had a similar problem. The motor is the same shape and size, and when I ordered it online, Sears stated that it was a substitute part but would fit and work. Too bad they didn't include a small instruction paper describing the difference between the original motor and the one they sent me. I don't want to guess on this and risk damaging some other electrical component.
Anyone out there that can make sense of this? I sure would be happy to get a response, meanwhile, we are using our gas stovetop for heat.
Thank you, Dick C. .................................
Related Models
Kenmore 867767012 FURNACE
Kenmore 867768110 FURNACES
Kenmore 867768140 FURNACES
Kenmore 867768170 FURNACES
Kenmore 867768190 FURNACES
Kenmore 867768230 FURNACES
Kenmore 867768240 FURNACES
Kenmore 867768280 FURNACES
Kenmore 86776916 SEARS FURNACE AND ELECTRONIC AIR CLEANER
Kenmore 867769161 SEARS ALL CONDITIONER FURNACE
Kenmore 867769163 COMB. FURNACE, HUMIDIFIER & ELECTRONIC AIR CLEANER
Kenmore 867769164 SEARS FURNACE, HUMIDIFIER & ELECTRONIC AIR CLEANER
Kenmore 86776917 SEARS FURNACE AND ELECTRONIC AIR CLEANER
Kenmore 867769171 SEARS ALL CONDITIONER FURNACE
Kenmore 867769173 COMB. FURNACE, HUMIDIFIER & ELECTRONIC AIR CLEANER
Kenmore 867769174 SEARS FURNACE, HUMIDIFIER & ELECTRONIC AIR CLEANER
Kenmore 86777187 SEARS GAS-FIRED SECTIONAL FURNACE
Kenmore 86777188 SEARS GAS-FIRED SECTIONAL FURNACE
Kenmore 867772590 HORIZONTAL GAS FURNACES
Kenmore 867772620 SEARS POWER MISER GAS-FIRED SPACE SAVER FURNACES
Kenmore 867772621 SEARS POWER MISER GAS-FIRED SPACE SAVER FURNACES
Kenmore 867772630 SEARS POWER MISER GAS-FIRED SPACE SAVER FURNACES
Kenmore 867772631 SEARS POWER MISER GAS-FIRED SPACE SAVER FURNACES
Kenmore 867772640 SEARS POWER MISER GAS-FIRED SPACE SAVER FURNACES
Kenmore 867772641 SEARS POWER MISER GAS-FIRED SPACE SAVER FURNACES
Kenmore 867772660 GAS-FIRED FURNACE
Kenmore 867772830 SEARS GAS-FIRED COUNTERFLOW FURNACE
Kenmore 867772850 SEARS GAS-FIRED COUNTERFLOW FURNACE
Kenmore 86777287 SEARS GAS-FIRED SECTIONAL FURNACE
Kenmore 867772930 SEARS GAS-FIRED HORIZONTAL FURNACE
Kenmore 867772931 GAS-FIRED HORIZONTAL FURNACE
Kenmore 867773220 SEARS GAS-FIRED SPACE SAVER FURNACE
Kenmore 867773221 SEARS GAS-FIRED SPACE SAVER FURNACES
Kenmore 867773230 SEARS GAS-FIRED SPACE SAVER FURNACE
Kenmore 867773240 SEARS GAS-FIRED SPACE SAVER FURNACE
Kenmore 867773260 SEARS GAS-FIRED SPACE SAVER FURNACES
Kenmore 867773261 SEARS GAS-FIRED SPACE SAVER FURNACE
Kenmore 867773270 SEARS GAS-FIRED SPACE SAVER FURNACE
Kenmore 867773271 SEARS GAS-FIRED SPACE SAVER FURNACES
Kenmore 867773280 SEARS GAS-FIRED SPACE SAVER FURNACE
Kenmore 867773281 SEARS GAS-FIRED SPACE SAVER FURNACES
Kenmore 867773730 GAS-FIRED SPACE SAVER FURNACE
Kenmore 867773750 GAS-FIRED COUNTERFLOW FURNACE
Kenmore 867773860 SEARS GAS-FIRED SECTIONAL FURNACE
Kenmore 86777387 GAS-FIRED SECTIONAL FURNACE
Kenmore 86777388 GAS-FIRED SECTIONAL FURNACE
Kenmore 86777389 GAS-FIRED SECTIONAL FURNACE
Kenmore 867774220 POWER MISER GAS-FIRED SPACE SAVER FURNACES
Kenmore 867774221 SEARS GAS-FIRED UPFLOW FURNACE
Kenmore 867774230 POWER MISER GAS-FIRED SPACE SAVER FURNACES
Kenmore 867774231 SEARS GAS-FIRED UPFLOW FURNACE
Kenmore 867774232 SEARS GAS-FIRED UPFLOW FURNACE
Kenmore 867778010 SEARS DIRECT VENT WALL FURNACE
Kenmore 867778040 SEARS WALL FURNACE
Kenmore 867778050 SEARS WALL FURNACE
Kenmore 867778060 SEARS WALL FURNACE
Kenmore 867778260 WALL FURNACE
Kenmore 867778270 FURNACES
Kenmore 867778320 FURNACES
Kenmore 867778370 FURNACES
Kenmore 867778380 FURNACES
Kenmore 867783250 SEARS GAS FIRED CONVERSION BURNER
Kenmore 867800161 AIR CONDITIONER
Kenmore 867800261 AIR CONDITIONER
Kenmore 867815000 COMBINATION UNITS ELECTRIC COOL & GAS HEAT
Kenmore 867815001 COMBINATION UNITS ELECTRIC COOL & GAS HEAT
Kenmore 867815010 COMBINATION HEATING AND COOLING UNIT
Kenmore 867815011 SEARS ELECTRIC COOL/GAS HEAT COMBINATION
Kenmore 867815012 COMBINATION UNITS ELECTRIC COOL & GAS HEAT
Kenmore 867815013 COMBINATION UNITS ELECTRIC COOL & GAS HEAT
Kenmore 867815014 COMBINATION UNITS ELECTRIC COOL & GAS HEAT
Kenmore 867815020 COMBINATION HEATING AND COOLING UNIT
Kenmore 867815021 SEARS ELECTRIC COOL/GAS HEAT COMBINATION
Kenmore 867815022 COMBINATION UNITS ELECTRIC COOL & GAS HEAT
Kenmore 867815023 COMBINATION UNITS ELECTRIC COOL & GAS HEAT
Kenmore 867815024 COMBINATION UNITS ELECTRIC COOL & GAS HEAT
Kenmore 867815030 COMBINATION HEATING AND COOLING UNIT
Kenmore 867815031 SEARS ELECTRIC COOL/GAS HEAT COMBINATION
Kenmore 867815032 COMBINATION UNITS ELECTRIC COOL & GAS HEAT
Kenmore 867815033 COMBINATION UNITS ELECTRIC COOL & GAS HEAT
Kenmore 867815034 COMBINATION UNITS ELECTRIC COOL & GAS HEAT
Kenmore 867815040 COMBINATION HEATING AND COOLING UNIT
Kenmore 867815041 SEARS ELECTRIC COOL/GAS HEAT COMBINATION
Kenmore 867815042 COMBINATION UNITS ELECTRIC COOL & GAS HEAT
Kenmore 867815043 COMBINATION UNITS ELECTRIC COOL & GAS HEAT
Kenmore 867815044 COMBINATION UNITS ELECTRIC COOL & GAS HEAT
Kenmore 867815050 COMBINATION HEATING AND COOLING UNIT
Kenmore 867815051 SEARS ELECTRIC COOL/GAS HEAT COMBINATION
Kenmore 867815052 COMBINATION UNITS ELECTRIC COOL & GAS HEAT
Kenmore 867815053 COMBINATION UNITS ELECTRIC COOL & GAS HEAT
Kenmore 867815060 COMBINATION UNITS ELECTRIC COOL & GAS HEAT
Kenmore 867815061 COMBINATION UNITS ELECTRIC COOL & GAS HEAT
Kenmore 867815080 COMBINATION UNITS ELECTRIC COOL & GAS HEAT
Kenmore 867815081 COMBINATION UNITS ELECTRIC COOL & GAS HEAT
Kenmore 867815082 COMBINATION UNITS ELECTRIC COOL & GAS HEAT
Kenmore 867815100 COMBINATION UNITS ELECTRIC COOL & GAS HEAT
Kenmore 867815101 COMBINATION UNITS ELECTRIC COOL & GAS HEAT
Kenmore 867815111 COMBINATION HEATING AND COOLING UNIT
Kenmore 867815112 SEARS ELECTRIC COOL/GAS HEAT COMBINATION
Kenmore 867815113 COMBINATION UNITS ELECTRIC COOL & GAS HEAT
Kenmore 867815114 COMBINATION UNITS ELECTRIC COOL & GAS HEAT
Kenmore 867815115 COMBINATION UNITS ELECTRIC COOL & GAS HEAT
Kenmore 867815121 COMBINATION HEATING AND COOLING UNIT
Kenmore 867815122 SEARS ELECTRIC COOL/GAS HEAT COMBINATION
Kenmore 867815123 COMBINATION UNITS ELECTRIC COOL & GAS HEAT
Kenmore 867815124 COMBINATION UNITS ELECTRIC COOL & GAS HEAT
Kenmore 867815125 COMBINATION UNITS ELECTRIC COOL & GAS HEAT
Kenmore 867815131 COMBINATION HEATING AND COOLING UNIT
Kenmore 867815132 SEARS ELECTRIC COOL/GAS HEAT COMBINATION
Kenmore 867820910 SEARS PACKAGE AIR CONDITIONING UNIT
Kenmore 867820920 SEARS PACKAGE AIR CONDITIONING UNIT
Kenmore 867820930 SEARS PACKAGE AIR CONDITIONING UNIT
Kenmore 867820940 SEARS PACKAGE AIR CONDITIONING UNIT
Kenmore 867820950 SEARS PACKAGE AIR CONDITIONING UNIT
Kenmore 867820960 SEARS PACKAGE AIR CONDITIONING UNIT
Kenmore 867820961 AIR CONDITIONER
Kenmore 867820962 PACKAGE AIR CONDITIONER
Kenmore 867820963 PACKAGE AIR CONDITIONER
Kenmore 867822430 SEARS HIGH EFFICIENCY PACKAGE AIR CONDITIONER
Kenmore 867822432 SEARS HIGH EFFICIENCY PACKAGE AIR CONDITIONER
  #2 (permalink)
Old 12-12-2007, 12:57 PM
kooler kooler is offline
Senior Expert
APP Volunteer
kooler is on a distinguished road
Default model or part number
I'm not seeing the number you listed in any databases, even sears... Is it a model number or part number? I would suggest not confusing or comparing wire colors of old motor with new motor.. The orange&yellow of the new motor are only for rotation and this replacement is for more than one application; the orange&yellow of the old motor may be one of the speed wires but without seeing the wire diagram your guess is better than mine... Definitely make sure it's right before applying power... You should have a common wire, at least one speed wire unless this blower utilizes more than one speed, possibly two wires to a capacitor, and the rotation wires... Take your time with this and you'll get it right...
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Replacing old dryer blower with new Aaron Felty Dryer Repair 3 12-11-2007 02:10 PM
furnace no heat amati5 Heating, Ventilation, and Air Conditioning (HVAC) 0 11-28-2007 02:46 PM
HVAC Blower is going nuts halapeno Heating, Ventilation, and Air Conditioning (HVAC) 1 11-27-2007 03:21 PM
Tips to getting blower wheel off Turbotom Dryer Repair 9 09-16-2007 03:50 AM
Sears Coldspot 17 jpridetx Refrigerator & Freezer Repair 0 08-14-2007 08:32 AM
