Discuss
Blower Motor for Sears Furnace
 in
Heating, Ventilation, and Air Conditioning (HVAC)
I recently purchased a new blower motor for our home furnace and recieved the motor right on time. Hooray! The
Appliance Repair Forum > Appliance Repair Help > Heating, Ventilation, and Air Conditioning (HVAC) » Blower Motor for Sears Furnace
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 12-11-2007, 08:28 PM
dickcollentine dickcollentine is offline
Junior Member
dickcollentine is on a distinguished road
Unhappy Blower Motor for Sears Furnace
Model Number: 8677642420   Brand: Sears   Age: More than 10 years
I recently purchased a new blower motor for our home furnace and recieved the motor right on time. Hooray! The problem is the new motor has a different number and color coding on the wires coming out of it. I have been able to determine the power, neutral and several other wires but I am stymied by one thing. The new motor has two orange and two yellow leads that are looped to one another. On the motor casing it states that to reverse the direction or rotation of the motor, you should reverse these connections ( in other words, instead of connecting the yellow to the yellow and the orange to the orange, it says to connect the yellow to the orange and the orange to the yellow.
The problem is, the old motor had only 1 orange and 1 yellow lead, and these were connected to wires leading into the electrical junction box in the furnace. One of the wires then continued on to another small box which appeared to have something to do with the cycling or timing of the blower motor.
Sorry to be so obscure in my description, but maybe someone out there has had a similar problem. The motor is the same shape and size, and when I ordered it online, Sears stated that it was a substitute part but would fit and work. Too bad they didn't include a small instruction paper describing the difference between the original motor and the one they sent me. I don't want to guess on this and risk damaging some other electrical component.
Anyone out there that can make sense of this? I sure would be happy to get a response, meanwhile, we are using our gas stovetop for heat.
Thank you, Dick C. .................................
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-12-2007, 11:57 AM
kooler kooler is offline
Senior Expert
APP Volunteer
kooler is on a distinguished road
Default model or part number
I'm not seeing the number you listed in any databases, even sears... Is it a model number or part number? I would suggest not confusing or comparing wire colors of old motor with new motor.. The orange&yellow of the new motor are only for rotation and this replacement is for more than one application; the orange&yellow of the old motor may be one of the speed wires but without seeing the wire diagram your guess is better than mine... Definitely make sure it's right before applying power... You should have a common wire, at least one speed wire unless this blower utilizes more than one speed, possibly two wires to a capacitor, and the rotation wires... Take your time with this and you'll get it right...
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Replacing old dryer blower with new Aaron Felty Dryer Repair 3 12-11-2007 01:10 PM
furnace no heat amati5 Heating, Ventilation, and Air Conditioning (HVAC) 0 11-28-2007 01:46 PM
HVAC Blower is going nuts halapeno Heating, Ventilation, and Air Conditioning (HVAC) 1 11-27-2007 02:21 PM
Tips to getting blower wheel off Turbotom Dryer Repair 9 09-16-2007 02:50 AM
Sears Coldspot 17 jpridetx Refrigerator & Freezer Repair 0 08-14-2007 07:32 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
