Discuss
Ventless gas logs will not stay lit
 in
Heating, Ventilation, and Air Conditioning (HVAC)
My gas logs have decided to quit working after only 13 years of service. Pilot is lit and easily relit
Appliance Repair Forum > Appliance Repair Help > Heating, Ventilation, and Air Conditioning (HVAC) » Ventless gas logs will not stay lit
  #1 (permalink)
Old 10-29-2011, 11:52 AM
Junior Member
TestPoint is on a distinguished road
Default Ventless gas logs will not stay lit
Brand: -brand-   Age: More than 10 years
My gas logs have decided to quit working after only 13 years of service. Pilot is lit and easily relit if necessary. MilliVolt contact closure will result in quick and correct ignition of burners. After about 20 seconds burners go out and will not restart until some time has passed, more than a few minutes, less than overnight. Contact closure from standard thermostat but results the same with jumper clips.
Suggestions appreciated.
Ads By Google
  #2 (permalink)
Old 10-29-2011, 03:11 PM
Junior Member
Default
Testing results update:
Flipping the on/off millivolt switch will cause the gas to flow again for a few seconds to a couple minutes and then it turns off again. I do not have a schematic for the millivolt operations but assume (ass u me) that the 'on' position provides a short to the regulator while the 'off' connects the regulator to remote wiring to provide the short.
Is the millivolt control internal to the regulator?
  #3 (permalink)
Old 10-29-2011, 06:03 PM
Junior Member
Default
OK, been doing the research. Both the pilot light gas supply and the gas burner supply appear to be controlled by the thermopile generator. That is the thermocouple being heated in the pilot flame which generates about 0.75v (750 millivolts). Apparently my 13 year old unit is able to operate the pilot control with little voltage left to operate the burner supply valve. Of course, the problem could be the regulator valve. At least that gives me something to replace tomorrow.
Still looking for comments.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Fireplace with gas logs mimiw2 Heating, Ventilation, and Air Conditioning (HVAC) 0 12-19-2010 10:08 AM
Bosch Axxis Ventless dryer cyberone Dryer Repair 0 07-25-2009 10:09 AM
Ventless Electric Dryers TripleJ Dryer Repair 3 05-09-2009 03:42 AM
vented to ventless cbivins Microwave Repair 3 04-16-2009 07:57 PM
vent free gas logs tshoemaker74401 Heating, Ventilation, and Air Conditioning (HVAC) 1 01-24-2009 06:23 AM
