Discuss
Thermostat Installation Help
 in
Heating, Ventilation, and Air Conditioning (HVAC)
Greetings, We currently had a Honeywell Digital TH5220D1003 (non programmable) thermostat (link here: Product) on our downstairs Westinghouse (Nordyne) FT5BD-030K
Appliance Repair Forum > Appliance Repair Help > Heating, Ventilation, and Air Conditioning (HVAC) » Thermostat Installation Help
  #1 (permalink)
Old 10-04-2011, 06:53 PM
Junior Member
dubosegriffin is on a distinguished road
Default Thermostat Installation Help
Model Number: FT5BD-030K   Brand: White-Westinghouse   Age: 1 - 5 years
Greetings,
We currently had a Honeywell Digital TH5220D1003 (non programmable) thermostat (link here: Product) on our downstairs Westinghouse (Nordyne) FT5BD-030K HVAC (link here: WESTINGHOUSE FT5BD-030K Heat Pumps). There is a separate unit for the upstairs. It was working fine. Then we wanted to install a new honeywell digital thermostat (model RTHL2310) that was programmable (link to product here: RTHL2310B | 5-2-Day Programmable Thermostat).
I removed the wires and labeled them. They are either:
Conventional (which I assumed to the correct one)
R (red wire), Y (yellow wire), C (blue wire), W (red wire), G (green wire), W2 (white wire)
OR
Heat Pump
R (red wire), Y (yellow wire), C (blue wire), O/B (red wire), G (green wire), Aux (white wire)
Next I connected the new thermostat as follows matching the conventional labels above:
R (red wire), W (red wire), Y (yellow wire), G (green wire). I did nothing with C (blue wire) or W2 (white wire).
The result was that the unit just blew warm air. I then hooked the old thermostat back up and still no cooling.
So I believe the Westinghouse is not working period and I do not have the wiring correct.
Any direction would be greatly appreciated!
Thank you,
DuBose Griffin
Ads By Google
Related Models
Frigidaire FTF1040AS0 Frtld Washer - Frigidaire
Frigidaire FTF2140ES0 Frigidaire/washer
Frigidaire FTF2140ES1 Frigidaire/washer
Frigidaire FTF2140ES2 Frigidaire/washer
Frigidaire FTF2140ES3 Frigidaire/washer
Frigidaire FTF2140FS0 Frigidaire/washer
Frigidaire FTF530ES0 Frigidaire/washer
Frigidaire FTF530ES1 Frigidaire/washer
Frigidaire FTF530FS0 Frigidaire/washer
Frigidaire FTF630AS0 Frtld Washer - Frigidaire
Frigidaire FTFB2940FE0 Frigidaire/washer
Frigidaire FTFB4000FS0 Frigidaire/washer
Frigidaire FTFB4000FS1 Frigidaire/washer
Frigidaire FTFB4000GS0 Frigidaire/washer
Frigidaire FTR630AS0 Frtld Washer - Frigidaire
Frigidaire FU017RRW1 Wwh(v2) / Upright Freezer
Frigidaire FU018TRW1 Wwh(v3) / Upright Freezer
Frigidaire FU019ARW5 Wwh(v3) / Upright Freezer
Frigidaire FU054ERD1 Wwh(v1) / Upright Freezer
Frigidaire FU054ERD2 Wwh(v2) / Upright Freezer
Frigidaire FU054ERD3 Wwh(v3) / Upright Freezer
Frigidaire FU054ERW1 Wwh(v4) / Upright Freezer
Frigidaire FU054ERW2 Wwh(v5) / Upright Freezer
Frigidaire FU100JRW1 Wwh(v1) / Upright Freezer
Frigidaire FU100JRW2 Wwh(v2) / Upright Freezer
Frigidaire FU100JRW3 Wwh(v3) / Upright Freezer
Frigidaire FU100JRW4 Wwh(v1) / Upright Freezer
Frigidaire FU100JRW5 Wwh(v1) / Upright Freezer
Frigidaire FU100LRW1 Wwh(v1) / Upright Freezer
Frigidaire FU100LRW2 Wwh(v2) / Upright Freezer
Frigidaire FU100LRW3 Wwh(v3) / Upright Freezer
Frigidaire FU100LRW4 Wwh(v1) / Upright Freezer
Frigidaire FU100LRW5 Wwh(v2) / Upright Freezer
Frigidaire FU134ERW1 Wwh(v1) / Upright Freezer
Frigidaire FU134ERW2 Wwh(v2) / Upright Freezer
Frigidaire FU134ERW3 Wwh(v3) / Upright Freezer
Frigidaire FU134ERW4 Wwh(v4) / Upright Freezer
Frigidaire FU134JRW1 Wwh(v1) / Upright Freezer
Frigidaire FU134JRW2 Wwh(v2) / Upright Freezer
Frigidaire FU134JRW3 Wwh(v3) / Upright Freezer
Frigidaire FU134JRW4 Wwh(v2) / Upright Freezer
Frigidaire FU134JRW5 Wwh(v1) / Upright Freezer
Frigidaire FU134LRW1 Wwh(v1) / Upright Freezer
Frigidaire FU134LRW2 Wwh(v2) / Upright Freezer
Frigidaire FU134LRW3 Wwh(v3) / Upright Freezer
Frigidaire FU134LRW4 Wwh(v1) / Upright Freezer
Frigidaire FU134LRW5 Wwh(v1) / Upright Freezer
Frigidaire FU161ERW1 Wwh(v1) / Upright Freezer
Frigidaire FU161ERW2 Wwh(v2) / Upright Freezer
Frigidaire FU161ERW3 Wwh(v3) / Upright Freezer
Frigidaire FU161ERW4 Wwh(v4) / Upright Freezer
Frigidaire FU161ERW5 Wwh(v5) / Upright Freezer
Frigidaire FU161ERW6 Wwh(v6) / Upright Freezer
Frigidaire FU161JRW1 Wwh(v0) / Upright Freezer
Frigidaire FU161JRW2 Wwh(v0) / Upright Freezer
Frigidaire FU161JRW3 Wwh(v3) / Upright Freezer
Frigidaire FU161LRW1 Wwh(v1) / Upright Freezer
Frigidaire FU161LRW2 Wwh(v2) / Upright Freezer
Frigidaire FU161LRW3 Wwh(v1) / Upright Freezer
Frigidaire FU161LRW4 Wwh(v1) / Upright Freezer
Frigidaire FU161LRW5 Wwh(v1) / Upright Freezer
Frigidaire FU161LRW6 Wwh(v1) / Upright Freezer
Frigidaire FU166ERW1 Wwh(v7) / Upright Freezer
Frigidaire FU166ERW2 Wwh(v8) / Upright Freezer
Frigidaire FU166ERW3 Wwh(v9) / Upright Freezer
Frigidaire FU166ERW4 Wwh(v10) / Upright Freezer
Frigidaire FU166HRD1 Wwh(v1) / Upright Freezer
Frigidaire FU166HRD2 Wwh(v2) / Upright Freezer
Frigidaire FU166HRW1 Wwh(v3) / Upright Freezer
Frigidaire FU166HRW2 Wwh(v4) / Upright Freezer
Frigidaire FU166HRW3 Wwh(v5) / Upright Freezer
Frigidaire FU168JRD1 Wwh(v1) / Upright Freezer
Frigidaire FU168JRD2 Wwh(v2) / Upright Freezer
Frigidaire FU168JRD3 Wwh(v1) / Upright Freezer
Frigidaire FU168JRW1 Wwh(v3) / Upright Freezer
Frigidaire FU168JRW2 Wwh(v4) / Upright Freezer
Frigidaire FU168JRW3 Wwh(v2) / Upright Freezer
Frigidaire FU168LRW1 Wwh(v2) / Upright Freezer
Frigidaire FU168LRW2 Wwh(v4) / Upright Freezer
Frigidaire FU169ERD1 Wwh(v1) / Upright Freezer
Frigidaire FU169ERD2 Wwh(v2) / Upright Freezer
Frigidaire FU169ERW1 Wwh(v3) / Upright Freezer
Frigidaire FU169ERW2 Wwh(v4) / Upright Freezer
Frigidaire FU169JRD1 Wwh(v1) / Upright Freezer
Frigidaire FU169JRD2 Wwh(v2) / Upright Freezer
Frigidaire FU169JRD3 Wwh(v4) / Upright Freezer
Frigidaire FU169JRW1 Wwh(v2) / Upright Freezer
Frigidaire FU169JRW2 Wwh(v1) / Upright Freezer
Frigidaire FU169JRW3 Wwh(v3) / Upright Freezer
Frigidaire FU169LRW1 Wwh(v1) / Upright Freezer
Frigidaire FU169LRW2 Wwh(v1) / Upright Freezer
Frigidaire FU169LRW3 Wwh(v2) / Upright Freezer
Frigidaire FU169LRW4 Wwh(v3) / Upright Freezer
Frigidaire FU169LRW5 Wwh(v1) / Upright Freezer
Frigidaire FU169LRW6 Wwh(v1) / Upright Freezer
Frigidaire FU196ERW1 Wwh(v1) / Upright Freezer
Frigidaire FU196ERW2 Wwh(v2) / Upright Freezer
Frigidaire FU196ERW3 Wwh(v3) / Upright Freezer
Frigidaire FU196JRW1 Wwh(v0) / Upright Freezer
Frigidaire FU196JRW2 Wwh(v4) / Upright Freezer
Frigidaire FU196JRW3 Wwh(v1) / Upright Freezer
Frigidaire FU196LRW1 Wwh(v1) / Upright Freezer
Frigidaire FU196LRW2 Wwh(v2) / Upright Freezer
Frigidaire FU196LRW3 Wwh(v3) / Upright Freezer
Frigidaire FU196LRW4 Wwh(v1) / Upright Freezer
Frigidaire FU196LRW5 Wwh(v1) / Upright Freezer
Frigidaire FU196LRW6 Wwh(v1) / Upright Freezer
Frigidaire FU199ERD1 Wwh(v5) / Upright Freezer
Frigidaire FU199ERD2 Wwh(v6) / Upright Freezer
Frigidaire FU199ERW1 Wwh(v7) / Upright Freezer
Frigidaire FU199ERW2 Wwh(v8) / Upright Freezer
Frigidaire FU199JRD1 Wwh(v0) / Upright Freezer
Frigidaire FU199JRD2 Wwh(v1) / Upright Freezer
Frigidaire FU199JRW1 Wwh(v0) / Upright Freezer
Frigidaire FU199JRW2 Wwh(v2) / Upright Freezer
Frigidaire FU199JRW4 Wwh(v1) / Upright Freezer
Frigidaire FU199LRW1 Wwh(v2) / Upright Freezer
Frigidaire FU199LRW2 Wwh(v3) / Upright Freezer
Frigidaire FU199LRW3 Wwh(v1) / Upright Freezer
Frigidaire FU199LRW4 Wwh(v1) / Upright Freezer
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
thermostat installation glass2011 Refrigerator & Freezer Repair 0 02-22-2011 03:17 PM
thermostat installation markfoster Oven Repair (including Ranges and Cooktops) 1 05-25-2010 02:57 PM
Thermostat installation skushman Dryer Repair 2 05-09-2010 06:28 PM
Thermostat Installation Paul B. Refrigerator & Freezer Repair 0 12-12-2008 04:19 PM
Thermostat installation edioni Refrigerator & Freezer Repair 2 11-11-2008 11:45 AM
