Discuss
Thermostat or...
 in
Heating, Ventilation, and Air Conditioning (HVAC)
In the Summer the AC compressor wouldn't shut off and it iced up, would do fine if you switched
Appliance Repair Forum > Appliance Repair Help > Heating, Ventilation, and Air Conditioning (HVAC) » Thermostat or...
  #1 (permalink)
Old 11-29-2007, 10:31 PM
PeggySue PeggySue is offline
Junior Member
PeggySue is on a distinguished road
Default Thermostat or...
Model Number: ACE184XD1   Brand: Whirlpool   Age: 5 - 10 years
In the Summer the AC compressor wouldn't shut off and it iced up, would do fine if you switched it to fan and only let the AC compressor run for 10 or 15 minutes, then turn it to fan only...now when I want heat from it the heater will not come on, fan blows...just no heat. Is this the thermostat or something else tricky?
Thanks a bunch!!
PeggySue
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 11-30-2007, 02:31 PM
kooler kooler is offline
Senior Expert
APP Volunteer
kooler is on a distinguished road
Default could be the stat
It could be the thermostat (AP2944735) causing your problems but it could also be something 'tricky'... I would inspect the wiring connections, thermostat and heating element to determine why there's no heat... You would have to know how to use a volt/ohm meter to troubleshoot this yourself... I would definitely blame the thermostat if the compressor runs when the stat is adjusted to a warm setting in the cooling mode...
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thermostat or... PeggySue Heating, Ventilation, and Air Conditioning (HVAC) 0 11-29-2007 10:26 PM
Need new thermostat nyan42 Oven Repair (including Ranges and Cooktops) 3 11-21-2007 02:51 PM
new thermostat replacement deronsherry Oven Repair (including Ranges and Cooktops) 0 10-05-2007 07:41 AM
problem with thermostat dav5 Oven Repair (including Ranges and Cooktops) 1 09-30-2007 01:55 AM
Thermostat or Fan problem equon, equon00@yahoo.com Refrigerator & Freezer Repair 0 07-25-2007 01:33 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
