Discuss
Frost on A/C pipes
 in
Heating, Ventilation, and Air Conditioning (HVAC)
I noticed last night that the temperature coming out of our vents was colder than normal. I checked the A/C
Appliance Repair Forum > Appliance Repair Help > Heating, Ventilation, and Air Conditioning (HVAC) » Frost on A/C pipes
  #1 (permalink)
Old 08-19-2011, 07:42 AM
Junior Member
ccrosbie is on a distinguished road
Default Frost on A/C pipes
Model Number: Trane Weathertron 1000   Brand: -brand-   Age: More than 10 years
I noticed last night that the temperature coming out of our vents was colder than normal. I checked the A/C unit and upon inspecting it noted about 1/16-1/32 inch of ice covering the pipe going from the compressor into the evaporator coils.
The ice defrosted in about 30 seconds after having shut off the unit (it had been on about 30 minutes prior).
This morning I started unit and it formed frost in about 3 minutes. I checked the airflow, removed the filter and it still formed. The evaporator coils underside is pretty dirty, but I noticed that when I shut off the A/C this morning the last place the frost melted was the large hex nut that attaches the pipe to the compressor. I have someone coming out to inspect the unit in a few days, but I was hoping you all could shed light on either how to clean the evaporator coils if that indeed could be the problem or how long I can run the system at a time and not freeze it up given temperatures in the mid 80s during the day and 60s at night before someone comes and inspects the system for a leak/low freon.
Also if thee is indeed a leak that is the problem, the unit was made in 1999. Was R-22 used in units then, or was it another type of refridgerant?
Thanks for your help
Related Models
Amana TRG16J REF - TOP MOUNT
Amana TRG18J REF - TOP MOUNT
Amana TRG18K REF - TOP MOUNT
Amana TRG18M REF - TOP MOUNT
Amana TRG18N REF - TOP MOUNT
Amana TRG18QB2L REF - TOP MOUNT
Amana TRG18QB2W REF - TOP MOUNT
Amana TRG18QB3G REF - TOP MOUNT
Amana TRG18QB3L REF - TOP MOUNT
Amana TRG18QB3W REF - TOP MOUNT
Amana TRG18QBG REF - TOP MOUNT
Amana TRG18QBL REF - TOP MOUNT
Amana TRG18QBW REF - TOP MOUNT
Amana TRG18SPH REF - TOP MOUNT
Amana TRG20J REF - TOP MOUNT
Amana TRG20M REF - TOP MOUNT
Amana TRG20SPH REF - TOP MOUNT
Amana TRG22J REF - TOP MOUNT
Amana TRGI18J REF - TOP MOUNT
Amana TRGI18QBL REF - TOP MOUNT
Amana TRGI18QBW REF - TOP MOUNT
Amana TRGI20J REF - TOP MOUNT
Amana TRGI22J REF - TOP MOUNT
Amana TRI-17D MISC / ACCESSORY
Amana TRI-17D-1 MISC / ACCESSORY
Amana TRI-17E MISC / ACCESSORY
Amana TRI-17LD MISC / ACCESSORY
Amana TRI-17LD-1 MISC / ACCESSORY
Amana TRI-17LE MISC / ACCESSORY
Amana TRI16K REF - TOP MOUNT
Amana TRI17E MISC / ACCESSORY
Amana TRI17LE MISC / ACCESSORY
Amana TRI18D REF - TOP MOUNT
Amana TRI18D MISC / ACCESSORY
Amana TRI18D-A REF - TOP MOUNT
Amana TRI18D-C REF - TOP MOUNT
Amana TRI18D-G REF - TOP MOUNT
Amana TRI18D-L REF - TOP MOUNT
Amana TRI18E MISC / ACCESSORY
Amana TRI18E-A MISC / ACCESSORY
Amana TRI18E-C MISC / ACCESSORY
Amana TRI18E-G MISC / ACCESSORY
Amana TRI18E-L MISC / ACCESSORY
Amana TRI18J REF - TOP MOUNT
Amana TRI18K REF - TOP MOUNT
Amana TRI18TE REF - TOP MOUNT
Amana TRI18TL REF - TOP MOUNT
Amana TRI18TW REF - TOP MOUNT
Amana TRI18V1E REF - TOP MOUNT
Amana TRI18V1L REF - TOP MOUNT
Amana TRI18V1W REF - TOP MOUNT
Amana TRI20K REF - TOP MOUNT
Amana TRI21S4E REF - TOP MOUNT
Amana TRI21S4L REF - TOP MOUNT
Amana TRI21S4W REF - TOP MOUNT
Amana TRI21VE REF - TOP MOUNT
Amana TRI21VL REF - TOP MOUNT
Amana TRI21VW REF - TOP MOUNT
Amana TRI22S4 REF - TOP MOUNT
Amana TRI22S4E REF - TOP MOUNT
Amana TRI22S4L REF - TOP MOUNT
Amana TRI22S4W REF - TOP MOUNT
Amana TRI22SRL REF - TOP MOUNT
Amana TRI25S5E REF - TOP MOUNT
Amana TRI25S5L REF - TOP MOUNT
Amana TRI25S5W REF - TOP MOUNT
Amana TRI25VE REF - TOP MOUNT
Amana TRI25VL REF - TOP MOUNT
Amana TRI25VW REF - TOP MOUNT
Admiral TRIS225BAW REF - SXS/I&W
Admiral TRIS225FAW REF - SXS/I&W
Admiral TRIS245BBW REF - SXS/I&W
Admiral TRIS245FBW REF - SXS/I&W
Frigidaire TRS20WRHD0 Tap(v1) / Refrigerator
Frigidaire TRS20WRHD1 Tap(v1) / Side By Side Refrigerator
Frigidaire TRS20WRHD2 Tap(v1) / Side By Side Refrigerator
Frigidaire TRS20WRHD3 Tap(v2) / Side By Side Refrigerator
Frigidaire TRS20WRHD4 Tap(v1) / Refrigerator
Frigidaire TRS20WRHD5 Tap(v1) / Refrigerator
Frigidaire TRS20WRHW0 Tap(v2) / Refrigerator
Frigidaire TRS20WRHW1 Tap(v2) / Side By Side Refrigerator
Frigidaire TRS20WRHW2 Tap(v3) / Side By Side Refrigerator
  #2 (permalink)
Old 08-23-2011, 05:21 PM
Senior Expert
APP Volunteer
icehouse is on a distinguished road
Default
Yes it is an R-22 unit. You should the evaporator coil with a good foaming cleaner like Ka Boom which will get the dirt out. The blower motor should be checked for proper RPM's. Then and only then should the refrigerant charge be checked.
__________________
NATE, HVAC Ecellence, NCCER, PHCC Certified Instructor.
a tragedy has happen to me : http://web.me.com/zenzoidman/Bobice/
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
banging pipes nathan d. Washer Repair 1 02-22-2011 01:58 AM
Water pipes nothappy Heating, Ventilation, and Air Conditioning (HVAC) 1 01-11-2009 08:07 PM
frost free refrigerator making frost proenzap Refrigerator & Freezer Repair 0 06-18-2008 12:23 PM
