Discuss
HVAC Blower is going nuts
 in
Heating, Ventilation, and Air Conditioning (HVAC)
Even with the system turned off at the thermostat, the blower turns on about once an hour for about 5
Appliance Repair Forum > Appliance Repair Help > Heating, Ventilation, and Air Conditioning (HVAC) » HVAC Blower is going nuts
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 11-25-2007, 10:47 AM
halapeno halapeno is offline
Junior Member
halapeno is on a distinguished road
Default HVAC Blower is going nuts
Brand: -brand-   Age: Less than 1 year
Even with the system turned off at the thermostat, the blower turns on about once an hour for about 5 minutes. I replaced the thermostat, but still have the same symptoms. Otherwise, both the heat and AC work well. Anyone have a clue why the blower wants to cycle without heat or AC?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 11-27-2007, 02:21 PM
kooler kooler is offline
Senior Expert
APP Volunteer
kooler is on a distinguished road
Default what's the model
You didn't list a brand or model number for your system so one can only guess what you're dealing with... There is a control that will cycle the blower that measures the temp inside the heating chamber called a fan limit switch... Generally it's designed to only turn the blower on when the chamber is hot/warm (during the heating mode) so it's possible this control is malfunctioning and cycling the blower when the chamber is cool... Suggest locating and inspecting/replacing this fan limit switch...
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Tips to getting blower wheel off Turbotom Dryer Repair 9 09-16-2007 02:50 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
