| » Compressor, breaker blown |
Model Number: York Brand: -other- Age: Less than 1 year
My compressor stopped kicking on over the weekend. I noticed that the breaker in the garage is in the 'blown' position, but when I turn it off and back on again it stays in the 'blown' position. By 'blown' I mean, not tightly in "On" and it has play in the switch. It's a 30amp 2-pole breaker. No other power in my house appears to be affected.
1. Would my compressor be on it's own circuit? (30 amp 2-pole) 2. If so, is it a problem with the breaker or with the compressor? I tend to think it's the breaker because I can't turn it back on at all, even when nothing is pulling from it. btw, I checked the fan in the compressor and it spins easily. What else should I check in the compressor? Ads By Google Related Models |
Update: I replaced the 30 amp 2-pole breaker just to be sure. And now I know, as soon as the compressor kicks on and the fan starts to run, it throws the breaker. So something electrical is failing. But I know the fan/motor are working. What else could it be? Thanks!
It could be a couple of things. First, keep the breaker off. Next, go outside to the condenser and pull off the cover on the control panel. Inspect the dual run capacitor for any bulging. Next, follow the wires from the contactor to the compressor. This will mean that you'll have to remove the top cover of this condenser. Remove the plastic cover off of the compressor, and inspect the wire terminals. Sometimes I see a failed wire connector, which will cause a wire to fall off and short across another wire. If these wires look good inside the compressor cover, then remove the 3 wires, and ohm from the copper pipe to any of the 3 terminals on the compressor. If you read any resistance, then you have a failed compressor.
Good luck |
| Display Modes | |
| Oven Cleaning Mishap... May have blown a breaker?? Please HELP! | Wasps70 | Oven Repair (including Ranges and Cooktops) | 1 | 03-11-2011 03:47 AM |
| thermal cut off blown again | timm6528 | Dryer Repair | 16 | 12-19-2010 05:19 PM |
| TCO Blown | mjgreen63 | Dishwasher Repair | 0 | 09-23-2010 07:31 AM |
| freezer warm, clicking noise from compressor, compressor very hot | sgtmajor58 | Refrigerator & Freezer Repair | 1 | 08-08-2009 06:57 PM |
| frig and freezer warm,clicking noisefrom compressor,compressor very hot | tdot | Refrigerator & Freezer Repair | 4 | 04-02-2008 08:35 AM |
