Discuss
home hvac system wired wrong and shorted, help
 in
Heating, Ventilation, and Air Conditioning (HVAC)
My brother changed the fuse box to a circuit breaker box, and hooked up the wrong wire to its spot
Appliance Repair Forum > Appliance Repair Help > Heating, Ventilation, and Air Conditioning (HVAC) » home hvac system wired wrong and shorted, help
  #1 (permalink)
Old 07-31-2011, 02:32 PM
Junior Member
hglarry is on a distinguished road
Default home hvac system wired wrong and shorted, help
Brand: -brand-   Age: Less than 1 year
My brother changed the fuse box to a circuit breaker box, and hooked up the wrong wire to its spot (220) and it started smoking but could not tell where from.
When put together right it does not work.
Oddly no fuses were blown.
What was afected, and what should I do?
Ads By Google
  #2 (permalink)
Old 03-23-2013, 03:11 AM
Junior Member
john sitra is on a distinguished road
Smile wire tstat
What are the units heat pump gas furnace or electric heat??
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Central AC unit won't come on, needs re-wired splumer Heating, Ventilation, and Air Conditioning (HVAC) 3 08-04-2011 04:30 AM
is it a plug-in or hard-wired oven? minhnguyen Oven Repair (including Ranges and Cooktops) 0 07-01-2011 07:55 PM
new switch may be wired wrong Robert Yow Oven Repair (including Ranges and Cooktops) 10 11-08-2010 05:12 PM
Hvac joannie524 Heating, Ventilation, and Air Conditioning (HVAC) 1 07-15-2010 12:15 PM
replacement ignitor is not wired the same domanski Oven Repair (including Ranges and Cooktops) 1 09-18-2008 07:31 PM
