Discuss
ge profile room air
 in
Heating, Ventilation, and Air Conditioning (HVAC)
I cannot be much help here as I cannot find any tech info on this unit. I am assuming that
Appliance Repair Forum > Appliance Repair Help > Heating, Ventilation, and Air Conditioning (HVAC) » ge profile room air
  #1 (permalink)
Old 07-30-2011, 05:41 AM
Senior Expert
APP Volunteer
denman is a glorious beacon of light
Default
Model Number: aed18kl   Brand: GE   Age: Less than 1 year
I am assuming that the actual part you want to control is the compressor.
Try to get a wiring diagram of the unit.
You need to know what device measures the temperature (thermistor) and whether is is a positive of negative coefficient device.
For instance a negative device gives a lower resistance as the temperature rises. So a high resistance means that the temperature is low and the compressor does not start.
Once you know this you could use your timer to run a 120 volt relay.
The relay contacts are then wired into the thermistor circuit.
For instance if the thermistor is negative coefficient the contacts are wired in one of the wires going to the thermistor (wired in series). With the relay off the unit sees an open (infinite ohms) as the temperature so it thinks that the room is cold so does not turn on the compressor. When they close for the 20 minutes it sees the actual temperature/thermistor and will start the compressor if the measured temperature is higher than the set point.
The above will not work if the unit has a self diagnostic which senses an open thermistor. In this case a you would need a relay with normally open (NO) and normally closed (NC) contacts. A resistor is then wired across (parallel) the normally open contacts so the unit sees this as the thermistor resistance and will not start but also will not cause an error.
The resistor of course has to be of the correct value.
If it is positive coefficient then you need a relay with NO and NC contacts and when you want the unit to stay off a resistor of the correct resistance is wired in so the control thinks the ambient temperature is below set point.
I hope the above makes sense and is useful to you.
P.S.: GE likes to keep everything a secret so getting the required info may be a pain.
Ads By Google
Related Models
General Electric AED22DAR1 Room air conditioner
General Electric AED22DAR2 Room air conditioner
General Electric AED22DBR1 Room air conditioner
General Electric AED25DNL1 ROOM AIR CONDITIONER
Maytag AED4370TQ0 29" ELECTRIC DRYER
Maytag AED4470TQ0 29" ELECTRIC DRYER
Maytag AED4475TQ0 29" ELECTRIC DRYER
Maytag AED4475TQ1 29" ELECTRIC DRYER
General Electric AEE08AKM1 ROOM AIR CONDITIONER
General Electric AEE08AMM1 ROOM AIR CONDITIONER
General Electric AEE08ANL1 ROOM AIR CONDITIONER
General Electric AEE08APL1 ROOM AIR CONDITIONER
General Electric AEE12DKG1 ROOM AIR CONDITIONER
General Electric AEE12DMG1 ROOM AIR CONDITIONER
General Electric AEE12DNL1 ROOM AIR CONDITIONER
General Electric AEE12DPL1 ROOM AIR CONDITIONER
General Electric AEE18DKM1 ROOM AIR CONDITIONER
General Electric AEE18DMM1 ROOM AIR CONDITIONER
General Electric AEE18DNM1 ROOM AIR CONDITIONER
General Electric AEE18DPM1 ROOM AIR CONDITIONER
General Electric AEE23DMH1 ROOM AIR CONDITIONER
General Electric AEE23DNL1 ROOM AIR CONDITIONER
General Electric AEE23DPL1 ROOM AIR CONDITIONER
General Electric AEE24DNL1 ROOM AIR CONDITIONER
Amana AEE933 DRYER- ELE
Amana AEE953 DRYER- ELE
General Electric AEG12AMG1 ROOM AIR CONDITIONER
General Electric AEH05LMG1 ROOM AIR CONDITIONER
General Electric AEH05LMS1 ROOM AIR CONDITIONER
General Electric AEH06LLG1 ROOM AIR CONDITIONER
General Electric AEH06LMG1 ROOM AIR CONDITIONER
General Electric AEH06LML1 ROOM AIR CONDITIONER
General Electric AEH06LNH1 ROOM AIR CONDITIONER
General Electric AEH06LNL1 ROOM AIR CONDITIONER
General Electric AEH06LPL1 ROOM AIR CONDITIONER
General Electric AEH06LPQ1 ROOM AIR CONDITIONER
General Electric AEH08ALG1 ROOM AIR CONDITIONER
General Electric AEH08ALM1 ROOM AIR CONDITIONER
General Electric AEH08FMG1 ROOM AIR CONDITIONER
General Electric AEH08LNH1 ROOM AIR CONDITIONER
General Electric AEH08LNQ1 ROOM AIR CONDITIONER
General Electric AEH08LPH1 ROOM AIR CONDITIONER
General Electric AEH08LPQ1 ROOM AIR CONDITIONER
General Electric AEH10ALG1 ROOM AIR CONDITIONER
General Electric AEH10AMG1 ROOM AIR CONDITIONER
General Electric AEH10AMS1 ROOM AIR CONDITIONER
General Electric AEH10ANH1 ROOM AIR CONDITIONER
General Electric AEH10ANW1 ROOM AIR CONDITIONER
General Electric AEH10APH1 ROOM AIR CONDITIONER
General Electric AEH12ALG1 ROOM AIR CONDITIONER
General Electric AEH12AMG1 ROOM AIR CONDITIONER
General Electric AEH12ANL1 ROOM AIR CONDITIONER
General Electric AEH12ANW1 ROOM AIR CONDITIONER
General Electric AEH12APL1 ROOM AIR CONDITIONER
General Electric AEH12APW1 ROOM AIR CONDITIONER
General Electric AEH18DLG1 ROOM AIR CONDITIONER
General Electric AEH18DMG1 ROOM AIR CONDITIONER
General Electric AEH18DNH1 ROOM AIR CONDITIONER
General Electric AEH18DPH1 ROOM AIR CONDITIONER
General Electric AEH18DPQ1 ROOM AIR CONDITIONER
General Electric AEH24DJH1 Room air conditioner
General Electric AEH24DKH1 Room air conditioner
General Electric AEH25DLH1 ROOM AIR CONDITIONER
General Electric AEH25DMH1 ROOM AIR CONDITIONER
General Electric AEH25DNL1 ROOM AIR CONDITIONER
General Electric AEH25DPL1 ROOM AIR CONDITIONER
General Electric AEL05LJS1 Room air conditioner
General Electric AEL05LPL1 ROOM AIR CONDITIONER
General Electric AEL05LPQ1 ROOM AIR CONDITIONER
General Electric AEL05LPW1 ROOM AIR CONDITIONER
General Electric AEL06LPL1 ROOM AIR CONDITIONER
General Electric AEL06LPQ1 ROOM AIR CONDITIONER
General Electric AEL08LPH1 ROOM AIR CONDITIONER
General Electric AEL08LPQ1 ROOM AIR CONDITIONER
General Electric AEL10APH1 ROOM AIR CONDITIONER
General Electric AEL12APL1 ROOM AIR CONDITIONER
General Electric AEL12APW1 ROOM AIR CONDITIONER
General Electric AEL14APL1 ROOM AIR CONDITIONER
General Electric AEL18DPQ1 ROOM AIR CONDITIONER
General Electric AEL25DPL1 ROOM AIR CONDITIONER
General Electric AEM05LML1 ROOM AIR CONDITIONER
General Electric AEM05LMS1 ROOM AIR CONDITIONER
General Electric AEM05LPQ1 ROOM AIR CONDITIONER
General Electric AEM05LPW1 ROOM AIR CONDITIONER
General Electric AEM06LMG1 ROOM AIR CONDITIONER
General Electric AEM06LML1 ROOM AIR CONDITIONER
General Electric AEM06LPL1 ROOM AIR CONDITIONER
General Electric AEM06LPQ1 ROOM AIR CONDITIONER
General Electric AEM08FLM1 ROOM AIR CONDITIONER
General Electric AEM08FMG1 ROOM AIR CONDITIONER
General Electric AEM08LNQ1 ROOM AIR CONDITIONER
General Electric AEM08LPH1 ROOM AIR CONDITIONER
General Electric AEM08LPQ1 ROOM AIR CONDITIONER
General Electric AEM09AAV1 Room air conditioner
General Electric AEM10AMG1 ROOM AIR CONDITIONER
General Electric AEM10AMS1 ROOM AIR CONDITIONER
General Electric AEM10ANH1 ROOM AIR CONDITIONER
General Electric AEM10ANW1 ROOM AIR CONDITIONER
General Electric AEM10APH1 ROOM AIR CONDITIONER
General Electric AEM12AMG1 ROOM AIR CONDITIONER
General Electric AEM12ANL1 ROOM AIR CONDITIONER
General Electric AEM12ANW1 ROOM AIR CONDITIONER
General Electric AEM12APL1 ROOM AIR CONDITIONER
General Electric AEM12APW1 ROOM AIR CONDITIONER
General Electric AEM14AAV1 Room air conditioner
General Electric AEM14ABV1 Room air conditioner
General Electric AEM14AMM1 ROOM AIR CONDITIONER
General Electric AEM14APL1 ROOM AIR CONDITIONER
General Electric AEM15DAV1 Room air conditioner
General Electric AEM15DBV1 Room air conditioner
General Electric AEM18DAV1 Room air conditioner
General Electric AEM18DBV1 Room air conditioner
General Electric AEM18DKG1 ROOM A/C
General Electric AEM18DLG1 ROOM AIR CONDITIONER
General Electric AEM18DMG1 ROOM AIR CONDITIONER
General Electric AEM18DPQ1 ROOM AIR CONDITIONER
Amana AEM197 WASHER-TOP LOADING
General Electric AEM23DAR1 Room air conditioner
General Electric AEM23DBR1 Room air conditioner
General Electric AEM25DKH1 ROOM AIR CONDITIONER
__________________
  #2 (permalink)
Old 07-30-2011, 11:27 AM
Senior Expert
APP Volunteer
Default
The micro switch is probably a momentary contact and I do not know whether holding holding it closed all the time would have any adverse effects.
Also I do not know what the default settings for the unit are when you first plug the unit in and they may not be what you want.
__________________
  #3 (permalink)
Old 07-31-2011, 12:03 PM
Senior Expert
APP Volunteer
Default
Cannot say as I do not have the required info.
It should be low voltage so should not cause a problem but I cannot be 100% sure.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE ASW12ALS1 Room Air conditioner. lsokhim Heating, Ventilation, and Air Conditioning (HVAC) 0 06-01-2010 12:09 AM
Amana portable room a/c araldrich Heating, Ventilation, and Air Conditioning (HVAC) 1 07-30-2009 06:58 AM
Blowing room temperature air whirlpool2002 Refrigerator & Freezer Repair 0 04-26-2009 02:44 PM
