Discuss
cycle
 in
Heating, Ventilation, and Air Conditioning (HVAC)
I turned the power off to the unit after not getting heat. The furnace cycles fine the first time but
Appliance Repair Forum > Appliance Repair Help > Heating, Ventilation, and Air Conditioning (HVAC) » cycle
  #1 (permalink)
Old 11-17-2007, 10:25 AM
esquino esquino is offline
Junior Member
esquino is on a distinguished road
Angry cycle
Model Number: GUI115D50A   Brand: Amana   Age: More than 10 years
I turned the power off to the unit after not getting heat. The furnace cycles fine the first time but will not recycle. If I turn the power on and off again the unit again cyles fine the first time but goes no further.
On cycles after the first, the plug glows, the burner fires but after a few seconds the burner cuts off. Again, it only does this after the first cycle sucessfully completes.
Basically, if I continue to reset the furnace after each cycle it works great. If I leave it alone it only cycles once then continue to try to fire without sucess.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 11-18-2007, 11:04 PM
kooler kooler is offline
Senior Expert
APP Volunteer
kooler is on a distinguished road
Default lockout
There's a safety device shutting this unit off and there's a lockout relay purposely leaving the unit off... You'll need a pro to troubleshoot this one... Turning the power off and back on resets the relay... Could be one of a number of problems or a combination... Search out all the safety devices in the wiring diagram and investigate each one is all I can recommend... good luck...
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dishwasher skips the wash cycle and stops at the rinse cycle jasporo Dishwasher Repair 1 11-16-2007 06:12 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
